LPR-02B-12B
LPR-02B-12B
    OPTIFUSE
    REG. FUSEHOLDER, 30A-12AWG BLK
LPR-02B-12B 数据手册
Type LPR-02 In-Line Fuse Holder Automotive Blade Fuses - APRs Splashproof Type Ratings: Fuse Type: Automotive Blade – APRs, ANRs Electrical Rating: 58VDC Temperature Rating: -40° C to 85° C Body: PVC Contacts: Brass IP Rating: IP65 Wire Type: UL1015 rated to FT1 (VW1) – Stranded Standard Wire Sizes: #12 ~ #20 AWG Standard Wire Colors: Red, Black, Orange, Yellow Standard Body colors: Black Standard Wire Length: 4 inches www.optifuse.com (619) 593-5050 Part number format LPR-02B-##Z Where ## = Wire Gauge Z = Wire color (R, Y, OR, B) Wire Gauge #12 #14 #16 #18 #20 Max. Amperage 30A 20A 15A 10A 7.5A Available in various wire gauges and lengths, and body and wire colors. Contact factory for those not listed above. Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. -Not designed for prolonged liquid exposure or submersible applications. Note: All specifications subject to change without notice. Rev I 10/2017 - Page: 1/1 Code G02-01H
LPR-02B-12B 价格&库存
很抱歉,暂时无法提供与“LPR-02B-12B”相匹配的价格&库存,您可以联系我们找货
