LPR-06B-12R
LPR-06B-12R
    OPTIFUSE
    REG. FUSEHOLDER, 30A-12AWG
LPR-06B-12R 数据手册
Type LPR-06 In-Line Fuse Holder Automotive Blade Type www.optifuse.com Specifications: Rating: 32VDC Body Material: PVC IP Rating: IP50 For use with Type APR Fuse (Regular-Automotive Blade) Attached Protective Cap Standard Wire: #12 AWG – 6” – Red Color (Other wire sizes and colors are available as special order) Bracket attached to gang multiple fuse holders together Wire Gauge #12 #16 (619) 593-5050 Max. Amperage 30A 15A Part number format LPR-06B-##R Where ## = Wire Gauge Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev C 07/2018 - Page: 1/1 Code Y01-01H
LPR-06B-12R 价格&库存
很抱歉,暂时无法提供与“LPR-06B-12R”相匹配的价格&库存,您可以联系我们找货
