LPR-12C-16R
LPR-12C-16R
    OPTIFUSE
    REG FUSEHOLDER-CLEAR, 15A-16AWG
LPR-12C-16R 数据手册
Type LPR-12 In-Line Fuse Holder Automotive Blade Fuses - APRs Splashproof Type Ratings: Fuse Type: Automotive Blade – APRs, ANRs Electrical Rating: 58VDC Body: PVC Contacts: Copper Alloy IP Rating: IP66 Wire Type: UL1015 Standard Wire Sizes: #12 ~ #18 AWG Standard Wire Colors: See Table Standard Body colors: Clear (for Indicating Fuses) Standard Wire Length: 4 inches www.optifuse.com (619) 593-5050 Part number format LPR-12C-##R Where ##= Wire gauge Wire Gauge #12 #14 #16 #18 Max. Amperage 30A 20A 15A 10A Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. -Not designed for prolonged liquid exposure or submersible applications. Note: All specifications subject to change without notice. Rev A 07/2015 - Page: 1/1 Code H02-01H
LPR-12C-16R 价格&库存
很抱歉,暂时无法提供与“LPR-12C-16R”相匹配的价格&库存,您可以联系我们找货
