LPS-08
LPS-08
    OPTIFUSE
    MINI LP ADD-ON FUSEHOLDER 2 CKT
LPS-08 数据手册
Type LPS-08 “Add-On” Automotive Fuse Holder Mini Automotive Low Profile Blade Type Fuse www.optifuse.com (619) 593-5050 Rating: 58VDC Max Combined Current - Both Circuits - 30A Max Primary Circuit - 25A Max Auxiliary Circuit - 15A Body Material: Thermoplastic For use with Type APS Fuse (Mini-Automotive Low Profile Blade Type) Wire: 16 AWG Red Wire Connector: Butt-Splice Connector Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device is intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev B 11/2015 - Page: 1/1 Code G02-01H
LPS-08 价格&库存
很抱歉,暂时无法提供与“LPS-08”相匹配的价格&库存,您可以联系我们找货
