LPT-08-3
LPT-08-3
    OPTIFUSE
    MICRO2 ADD-ON FUSEHOLDER, 3 CKT
LPT-08-3 数据手册
Type LPT-08-3 “Add-On” Automotive Fuse Holder Micro2 Automotive Blade Type Fuse Total 3 Circuits www.optifuse.com (619) 593-5050 For use with Type APT, ANT Fuses (Tiny, Micro2 Automotive Blade) Rating: 58V Max Installation Current Rating:  Existing Circuit: 30A  Add-on Circuit: 20A Body Material: Nylon with Glass Fiber (UL 94V-0), Black Terminals: Brass, Tin plated Wire: # 16 AWG UL 1015 Red Wire Connector: Butt-Splice Connector Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device is intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications and dimensions subject to change without notice. Rev A 07/2017 - Page: 1/1 Code G02-01H
LPT-08-3 价格&库存
很抱歉,暂时无法提供与“LPT-08-3”相匹配的价格&库存,您可以联系我们找货
