Type LPX-23
In-Line Fuse Holder
Maxi Automotive Blade Fuses
Splashproof Cap
Ratings:
Fuse Type: Maxi Automotive Blade – ANX / APX
Amperage: Rated for current up to 80A
Voltage: Max 80VDC
Body: PVC
Contacts: Brass
Cap: Splashproof Cap
IP Rating: IP65
Standard Wire Size: #8 AWG
Standard Wire Color: Red
Standard Body Color: Black
Standard Wire Length: 12 inch Loop
www.optifuse.com
(619) 593-5050
Part number format
LPX-23B-8R-Loop
Available in various wire gauges and lengths, and body and wire colors.
Contact factory for those not listed above.
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
-Not designed for prolonged liquid exposure or submersible applications.
Note: All specifications subject to change without notice.
Rev A 07/2018 - Page: 1/1
Code G02-01H
很抱歉,暂时无法提供与“LPX-23B-08R-LOOP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+206.97853
- 3+119.27576
- 5+87.00115
