Type MSC / MSC-P
Medium Time Delay Glass Tube Fuse
5 x 20 mm
Agency Standards and Listings:
cULus Listed
cURus Recognized
CSA Certified
PSE
KC
100mA-1.6A, 10A
2A-8A
100mA-8A, 10A
1A-15A
100mA-10A
Interrupt Ratings:
100mA~1A
35A
1.2 A~3.5A
100A
4A~8A, 10A
200A
1A~15A
100A
100mA~10A
100A
@ 250VAC
@ 250VAC – CSA
@ 250VAC – CSA
@ 250VAC – PSE
@ 250VAC – KC
Operating Temperature:
-55C - +125C
Time Characteristics
135%
Max
1h
200%
Max
5s
Mechanical Dimensions: Inches [mm]
www.optifuse.com
Cartridge
Part No.
Axial Lead
Part No.
MSC-100mA
MSC-125mA
MSC-150mA
MSC-160mA
MSC-200mA
MSC-250mA
MSC-300mA
MSC-315mA
MSC-350mA
MSC-375mA
MSC-400mA
MSC-500mA
MSC-600mA
MSC-630mA
MSC-700mA
MSC-750mA
MSC-800mA
MSC-1A
MSC-1.2A
MSC-1.25A
MSC-1.5A
MSC-1.6A
MSC-2A
MSC-2.25A
MSC-2.5A
MSC-3A
MSC-3.15A
MSC-3.5A
MSC-4A
MSC-5A
MSC-6A
MSC-6.3A
MSC-7A
MSC-8A
MSC-9A
MSC-10A
MSC-12A
MSC-15A
MSC-P-100mA
MSC-P-125mA
MSC-P-150mA
MSC-P-160mA
MSC-P-200mA
MSC-P-250mA
MSC-P-300mA
MSC-P-315mA
MSC-P-350mA
MSC-P-375mA
MSC-P-400mA
MSC-P-500mA
MSC-P-600mA
MSC-P-630mA
MSC-P-700mA
MSC-P-750mA
MSC-P-800mA
MSC-P-1A
MSC-P-1.2A
MSC-P-1.25A
MSC-P-1.5A
MSC-P-1.6A
MSC-P-2A
MSC-P-2.25A
MSC-P-2.5A
MSC-P-3A
MSC-P-3.15A
MSC-P-3.5A
MSC-P-4A
MSC-P-5A
MSC-P-6A
MSC-P-6.3A
MSC-P-7A
MSC-P-8A
MSC-P-9A
MSC-P-10A
MSC-P-12A
MSC-P-15A
Amper
e
Rating
100mA
125mA
150mA
160mA
200mA
250mA
300mA
315mA
350mA
375mA
400mA
500mA
600mA
630mA
700mA
750mA
800mA
1A
1.2A
1.25A
1.5A
1.6A
2A
2.25A
2.5A
3A
3.15A
3.5A
4A
5A
6A
6.3A
7A
8A
9A
10A
12A
15A
(619) 593-5050
Voltage
Rating
(V)
250V
Nominal
Melting I2t
A2 Sec
0.01227
0.02530
0.02325
0.04315
0.08063
0.1341
0.2167
0.2393
0.3061
0.4017
0.3766
0.7704
0.6552
0.6880
0.7551
0.8669
1.165
2.112
3.608
3.962
6.713
7.795
4.888
6.383
10.49
15.50
17.41
27.88
33.47
51.13
75.02
84.15
112.1
167.0
190.3
257.8
408.1
731.9
Lead Wire: Tin Plated Copper
Dia. 0.65±0.02mm 100mA ~ 9A
Dia. 0.8±0.02mm 10A ~ 15A
Note: All specifications subject to change without notice.
Rev C 12/2015 - Page: 1/2
Code: H01-01H
Type MSC / MSC-P
5 x 20 mm
www.optifuse.com
(619) 593-5050
Part Number - MSC/MSC-P
Time Current Graph
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Fuses are intended for occasional overcurrent protection. Application for repeated overcurrent condition
and/or prolonged trip are not anticipated.
-Avoid contact of Fuse device with chemical solvent. Prolonged contact may damage the device performance.
Rev C 12/2015 - Page: 2/2
Code: H01-01H
很抱歉,暂时无法提供与“MSC-600MA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+40.06832
- 20+12.51042
- 26+9.18597
- 60+8.71355
