Type PHC
PCB Mounted Horizontal Fuse
Holder
5mm x 20mm
www.optifuse.com
(800) 621-0326
Electrical Rating: 6.3A, 250VAC
Operating Power: 2.5 W
Fuse Style: 5mm x 20mm
Material: Frame and Cap: Thermoplastic (UL Flame: 94V-0)
Terminal: Nickel Plated Copper Alloy
Panel Thickness: .031 Min / .177 Max [.08mm Min, 4.5mm Max]
Mounting: PCB mounting
Cap: Finger Grip / Screwdriver Slot Combo
Bayonet Knob
Agency Standards and Listings:
Product Dimensions: Inches[mm]
Mounting Holes: Inches[mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse.
-Avoid contact of Fuse Holder with chemical solvent. Prolonged contact will damage the device performance.
Note: All specifications subject to change without notice.
Rev B 02/2007 - Page: 1/1
Code: S03
很抱歉,暂时无法提供与“PHC-01”相匹配的价格&库存,您可以联系我们找货
