Type PMA-DS-08-Q2S
Panel Mount Fuse Holder
¼” x 1¼” (6.3 x 32mm) Fuses
Driver / Screw
www.optifuse.com
(619) 593-5050
Electrical Rating: 10A 250VAC / 12VDC
Fuse Style: ¼” x 1¼” (6.3 x 32mm)
Material:
Frame: Polycarbonate (UL flame: 94V-2)
Cap: PBT (UL flame: 94V-0)
Terminals: Nickel-plated brass
Cap: Slotted Driver type, Screw type – Rated to IP-56
Mounting: by nut
Terminal: Solder/Quick-Connect 6.4mm / 0.250”
Product Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse.
-Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 02/2012 - Page: 1/1
Code S02-01H
很抱歉,暂时无法提供与“PMA-DS-08-Q2S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+112.05087
- 5+52.34877
