Type PMA-PB-01-SOS
Panel Mount Fuse Holder
¼” x 1¼” (6.3 x 32mm) Fuses
Push Button / Bayonet
www.optifuse.com
(619) 593-5050
Electrical Rating: 10A, 250V AC
Fuse Style: ¼” x 1¼” (6.3 x 32mm)
Material:
Frame: Phenolic (UL flame: 94V-1)
Cap: Nylon (UL flame: 94V-2)
Terminals: Nickel-plated brass
Cap: Push Button to Release
Mounting: by metal nut with white washer
Terminal: Solder 3.8mm / 0.148”, Solder/Quick-Connect 4.0mm / 0.156”
Panel Thickness: 0.5 ~ 4.5mm
Agency Standards and Listings:
Product Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse.
-Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 01/2008 - Page: 1/1
Code S02-02D
很抱歉,暂时无法提供与“PMA-PB-01-SOS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+101.56011
- 5+50.95516
- 12+37.03442
