Type PMC-DS-04-SOS
Panel Mount Fuse Holder
5 x 20 mm Fuses
Driver / Screw
www.optifuse.com
(619) 593-5050
Electrical Rating: 6.3A, 250V AC; 10A, 125V AC
Fuse Style: 5 x 20mm
Material:
Frame and Cap: Nylon (UL flame: 94V-2)
Terminals: Nickel-plated brass
Cap: Slotted Driver type, Screw type
Mounting: Snap-in mounting
Terminal: Solder 2.8mm / 0.109”
Panel Thickness: 0.7 ~ 3.5mm
Agency Standards and Listings:
UL Recognized 6.3A 250V, 10A 125V
VDE
6.3A 250V
Product Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse.
-Avoid contact of Fuse Holder with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 01/2008 - Page: 1/1
Code S02-02D
很抱歉,暂时无法提供与“PMC-DS-04-SOS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+85.88834
- 7+36.94687
- 16+34.84563
