RS30-110
RS30-110
    OPTIFUSE
    PTC FUSE-THRU HOLE , 1.1A 30VDC
RS30-110 数据手册
Type RS30 Resettable Fuse (PTC’s) Radial Leaded www.optifuse.com (619) 593-5050 Application: Wide variety of electronic equipment Product Features: Low resistance, High hold current, Solid State Radial-leaded product ideal for up to 30V Operation Current: 900mA~9A Maximum Voltage: 30V Temperature Range: -40ºC to 85 ºC Agency Standards and Listings: Electrical Characteristics (23ºC) Part Number RS30-090 RS30-110 RS30-135 RS30-160 RS30-185 RS30-250 RS30-300 RS30-400 RS30-500 RS30-600 RS30-700 RS30-800 RS30-900 Hold Current Trip Current IH, A 0.90 1.1 1.35 1.60 1.85 2.50 3.00 4.00 5.00 6.00 7.00 8.00 9.00 IT, A 1.80 2.20 2.70 3.20 3.70 5.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 Max. Time To Trip Maximum Current at 5xIH, S IMAX, A 5.9 100 6.6 100 7.3 100 8.0 100 8.7 100 10.3 100 10.8 100 12.7 100 14.5 100 16.0 100 17.5 100 18.8 100 20.0 100 Rated Voltage Typical Power VMAX, Vdc 30 30 30 30 30 30 30 30 30 30 30 30 30 Pd, W 0.6 0.7 0.8 0.9 1.0 1.2 2.0 2.5 3.0 3.5 3.8 4.0 4.2 Resistance Tolerance RMIN Ω 0.070 0.050 0.040 0.030 0.030 0.020 0.020 0.010 0.010 0.005 0.005 0.005 0.005 R1MAX Ω 0.22 0.17 0.13 0.11 0.09 0.07 0.08 0.05 0.05 0.04 0.03 0.02 0.02 IH = Hold Current – Maximum current at which the device will not trip at 23ºC still air. IT = Trip Current – Minimum current at which the device will always trip at 23ºC still air. VMAX = Maximum voltage device can withstand without damage at it’s rated current. IMAX = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Maximum power dissipated from device when in the tripped state in 23ºC still air environment. RMIN = Minimum device resistance at 23ºC. R1MAX = Maximum device resistance at 23ºC, 1 hour after tripping. Note: All specifications subject to change without notice. Rev B 09/2015 - Page: 1/3 Code:F01-01W Type RS30 Resettable Fuse (PTC’s) Radial Leaded www.optifuse.com (619) 593-5050 Physical Specifications: Lead Material: RS30-090 ~ RS30-250: Tin plated copper, 24 AWG. RS30-300 ~ RS30-900: Tin plated copper, 20 AWG. Soldering Characteristics: MIL-STD-202, method 208E. Insulating Coating: Flame retardant epoxy, meet UL-94V-0 requirement. RS30 Product Dimensions (millimeters) RS30-090 ~ RS30-250 Lead Size: 24AWG, 0.51 mm Diameter Part Number RS30-090 RS30-110 RS30-135 RS30-160 RS30-185 RS30-250 RS30-300 RS30-400 RS30-500 RS30-600 RS30-700 RS30-800 RS30-900 Warning: A Maximum 7.4 7.4 8.9 8.9 10.2 11.4 11.4 14.0 14.0 16.5 19.1 21.6 24.1 B Maximum 12.2 14.2 13.5 15.2 15.7 18.3 17.3 20.1 24.9 24.9 26.7 29.2 29.7 RS30-300 ~ RS30-900 Lead Size: 20AWG, 0.81 mm Diameter C Typical 5.1 5.1 5.1 5.1 5.1 5.1 5.1 5.1 10.2 10.2 10.2 10.2 10.2 D Minimum 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 7.6 E Maximum 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 F Typical 0.9 0.9 0.9 0.9 0.9 0.9 1.2 1.2 1.2 1.2 1.2 1.2 1.2 -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip is not anticipated. -Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev B 09/2015 - Page: 2/3 Code:F01-01W Type RS30 Resettable Fuse (PTC’s) Radial Leaded www.optifuse.com (619) 593-5050 Thermal Derating Curve – RS30 Series A = RS30-090 B = RS30-110 C = RS30-135 D = RS30-160 E = RS30-185 F = RS30-250 G = RS30-300 H = RS30-400 I = RS30-500 J = RS30-600 K = RS30-700 L = RS30-800 M = RS30-900 Time-to-Trip (S) Typical Time-To-Trip at 23ºC Standard Package Part Number RS30-090 RS30-110 RS30-135 RS30-160 RS30-185 RS30-250 RS30-300 Pcs/Bag 500 500 300 300 300 300 200 Reel/Tape 3K 3K 3K 3K 3K 3K 1.5K Part Number RS30-400 RS30-500 RS30-600 RS30-700 RS30-800 RS30-900 Note: All specifications subject to change without notice. Pcs/Bag 200 200 100 100 100 100 Reel/Tape 1.5K ----------- Rev B 09/2015 - Page: 3/3 Code:F01-01W
RS30-110 价格&库存
很抱歉,暂时无法提供与“RS30-110”相匹配的价格&库存,您可以联系我们找货
