Type TCD
Time-Delay High Breaking Capacity
5 x 20 mm Ceramic Fuse
www.optifuse.com
(619) 593-5050
Agency Standards and Listings:
Cartridge
Part number
CCC
CQC
SEMKO
VDE
BSI
UR/C-UR
PSE
KC
1A~6.3A
8A, 10A, 12.5A, 16A
1A~10A, 12.5A, 16A
1A~10A, 12.5A, 16A
1A~6.3A
200mA~15A
1A~15A
1A~10A
Interrupt Ratings:
1500Amperes at 250V AC
Time Characteristics
275%
Rated 210%
Current MAX MIN MAX
200mA~ 30 250 80
800mA min ms sec
30 750 80
1A~3.15A
min ms sec
30 750 80
4A~10A
min ms sec
30
1
80
12A~16A
min sec sec
400%
MIN MAX
50
5
ms sec
95
5
ms sec
150
5
ms sec
150
8
ms sec
1000%
MIN MAX
5
150
ms
ms
10 150
ms
ms
10 150
ms
ms
20 150
ms
ms
TCD-200mA
TCD-250mA
TCD-315mA
TCD-400mA
TCD-500mA
TCD-630mA
TCD-800mA
TCD-1A
TCD-1.25A
TCD-1.6A
TCD-2A
TCD-2.5A
TCD-3.15A
TCD-4A
TCD-5A
TCD-6.3A
TCD-8A
TCD-10A
TCD-12A
TCD-12.5A
TCD-15A
TCD-16A
Axial Lead
Part number
TCD-P-200mA
TCD-P-250mA
TCD-P-315mA
TCD-P-400mA
TCD-P-500mA
TCD-P-630mA
TCD-P-800mA
TCD-P-1A
TCD-P-1.25A
TCD-P-1.6A
TCD-P-2A
TCD-P-2.5A
TCD-P-3.15A
TCD-P-4A
TCD-P-5A
TCD-P-6.3A
TCD-P-8A
TCD-P-10A
TCD-P-12A
TCD-P-12.5A
TCD-P-15A
TCD-P-16A
Ampere
Rating
Voltage
Rating
200mA
250mA
315mA
400mA
500mA
630mA
800mA
1A
1.25A
1.6A
2A
2.5A
3.15A
4A
5A
6.3A
8A
10A
12A
12.5A
15A
16A
250V
Mechanical Dimensions: Inches [mm]
Operating Temperature:
-55ºC to +125ºC
Material:
Ceramic Body/Nickel Plated Brass Caps
Lead Wire Ø0.65mm - < 10A
Ø0.8mm - 10A ~ 12A
Ø1.0mm - > 12A
Packaging:
TCD 1000 pcs; TCD-P 500 pcs per box.
Note: All specifications subject to change without notice.
Rev D 01/2016 - Page: 1/2
Code: H01-01H
Type TCD
www.optifuse.com
(619) 593-5050
Part Number TCD
TIME CURRENT CURVES
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame.
-Glass Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip
are not anticipated.
-Avoid contact of Glass Fuse device with chemical solvent. Prolonged contact will damage the device performance.
Rev D 01/2016 - Page: 2/2
Code: H01-01H
很抱歉,暂时无法提供与“TCD-315MA”相匹配的价格&库存,您可以联系我们找货
