TPCC-R-500MA
TPCC-R-500MA
    OPTIFUSE
    CLASS CC FUSE, TIME DELAY 500MA
TPCC-R-500MA 数据手册
Type TPCC-R UL Class CC – Current Limiting Branch Circuit Protection Time Delay - 13/32”x 1-1/2” For use as branch circuit protection in general purpose, lighting, solenoid, control transformer and motor applications. This fuse provides high current limiting capabilities and a rejection style ferrule. Electrical: 600VAC – 250mA -30A 300VDC -250mA -30A Interrupt Ratings: 200,000A @ 600VAC (100mA-30A) 100,000A @ 300VDC (100mA-30A) Agency Standards and Listings: UL Listed to Standard 248-4 File 2137 CSA Certified Standard C22.2 No. 248.4 DC Listed to UL Standard 248 Mechanical Dimensions: Warning: www.optifuse.com Part Number TPCC-R-250mA TPCC-R-500mA TPCC-R-800mA TPCC-R-1A TPCC-R-1.125A TPCC-R-1.25A TPCC-R-1.4A TPCC-R-1.5A TPCC-R-1.6A TPCC-R-1.8A TPCC-R-2A TPCC-R-2.25A TPCC-R-2.5A TPCC-R-2.8A TPCC-R-3A TPCC-R-3.2A TPCC-R-3.5A TPCC-R-4A TPCC-R-4.5A TPCC-R-5A TPCC-R-5.6A TPCC-R-6A TPCC-R-6.25A TPCC-R-7A TPCC-R-7.5A TPCC-R-8A TPCC-R-9A TPCC-R-10A TPCC-R-12A TPCC-R-15A TPCC-R-17.5A TPCC-R-20A TPCC-R-25A TPCC-R-30A (619) 593-5050 Ampere Rating 250mA 500mA 800mA 1A 1.125A 1.25A 1.4A 1.5A 1.6A 1.8A 2A 2.25A 2.5A 2.8A 3A 3.2A 3.5A 4A 4.5A 5A 5.6A 6A 6.25A 7A 7.5A 8A 9A 10A 12A 15A 17.5A 20A 25A 30A -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of fuse with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 08/2008 - Page: 1/3 Code F02-01H Type TPCC-R UL Class CC – Current Limiting Branch Circuit Protection Time Delay - 13/32”x 1-1/2” Motor Full Load Amperes 0.71 - 0.89 0.90 - 1.19 1.20 - 1.34 1.35 - 1.79 1.80 - 2.25 2.26 - 2.69 2.70 - 2.90 2.91 - 3.20 3.21 - 3.75 3.76 - 4.50 4.51 - 5.34 5.35 - 5.69 5.70 - 6.70 6.71 - 7.79 7.80 - 8.88 8.89 - 11.1 11.2 - 13.3 13.4 - 15.2 www.optifuse.com (619) 593-5050 Fuse Rating* Minimum Duty 1.25 1.6 2 2.5 3 4 4 5 5 6 8 10 12 12 15 17.5 20 25 Maximum Duty 1.6 2 2.5 3 4 5 6 6 7 8 10 12 12 15 17.5 20 25 30 * The National Electrical Code allows time-delay Class CC fuses to be sized at up to 400% of motor FLA, if needed. Note: All specifications subject to change without notice. Rev A 08/2008 - Page: 2/3 Code F02-01H Type TPCC-R UL Class CC – Current Limiting Branch Circuit Protection Time Delay - 13/32”x 1-1/2” www.optifuse.com (619) 593-5050 Time Current Curve Graph Peak Let-Thru Current Graph Note: All specifications subject to change without notice. Rev A 08/2008 - Page: 3/3 Code F02-01H
TPCC-R-500MA 价格&库存
很抱歉,暂时无法提供与“TPCC-R-500MA”相匹配的价格&库存,您可以联系我们找货
