CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS
Radial Lead
HSC
Series
・High reliability and high voltage are realized by hybrid electrolyte
・Endurance with ripple current : 4,000 hours at 125℃
・Rated voltage range : 25 to 63Vdc, Capacitance range : 100 to 330μF
・For high temperature and high reliability applications.
(Automotive equipment, Base station equipment, etc.)
・RoHS2 Compliant
・Halogen Free
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
HSC
Higher temperature
HSD
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +125℃
25 to 63Vdc
±20% (M)
I=0.05CV
Where, I : Max. leakage current (μA)
, C: Nominal capacitance(μF), V : Rated voltage(V)
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
(at 20℃, 120Hz)
Z(-25℃)/Z(+20℃)≦1.5
Z(-55℃)/Z(+20℃)≦2.0
(at 100kHz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 4,000 hours at 125℃.
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦ 200% of the initial specified value
ESR
Leakage current
≦ The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃
without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS
C 5101-4.
Capacitance change
D.F. (tanδ)
ESR
Leakage current
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage
at 85℃, 85% RH for 2,000 hours.
Appearance
No significant damage
Capacitance change
≦ ±30% of the initial value
D.F.(tanδ)
ESR
Leakage current
Bias Humidity Test
◆DIMENSIONS [mm]
◆MARKING
EX) 25V330µF
Code : E
φD'
φd
F±0.5
Coated Case
L'
15min.
4D8
Size Code
φD
φd
F
φD'
L'
4min.
◆PART NUMBERING SYSTEM
1
2
3
4
H HSC
5
6
7
8
E
(at 20℃ after 2 minutes)
0.16 max.
Shelf Life
●Terminal
(at 20℃, 120Hz)
9
10
11
12
13
14
15
16
17
18
M J C5 S
JC5
10
0.6
5.0
φD+0.5max.
L+1.5max.
330
E HC
●Rated
voltage symbol
Rated voltage (Vdc)
25
35
50
63
Symbol
E
V
H
J
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470, 100µF:101)
Lead forming Taping code
Terminal code
Voltage code (ex. 35V:350, 50V:500)
Series code
Category
Please refer to "Product code guide (conductive polymer hybrid type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001T
Radial Lead
HSCSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
ESR
(mΩ max./20℃, 100kHz)
Rated ripple current
(mArms/125℃, 100kHz)
Part No.
16
17
19
2,200
2,100
2,000
HHSC250E□□331MJC5S
HHSC350E□□271MJC5S
HHSC500E□□121MJC5S
HHSC630E□□101MJC5S
25
330
10×12.5
35
270
10×12.5
50
120
10×12.5
63
100
10×12.5
□□:Enter the appropriate lead forming or taping code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
100, 120
270, 330
120
0.10
0.13
1k
0.40
0.45
5k
0.60
0.65
10k
0.70
0.75
20k
0.80
0.85
30k
0.80
0.85
100k to 500k
1.00
1.00
CAT. No. E1001T
很抱歉,暂时无法提供与“HHSC500ELL121MJC5S”相匹配的价格&库存,您可以联系我们找货
