UT-P2019
UT-P2019
    USOUND
    通用 扬声器 顶部 矩形
UT-P2019 数据手册
MEMS SPEAKERS ADAP UT-P2019 | DATASHEET Adap MEMS speakers are ideal for free-field audio solutions such as wearables. Thanks to its small size and low weight, Adap offers maximum flexibility for outstanding design approaches. Providing a wide bandwidth, it enables high-res audio applications. Adap produces tangible, clear and rich sound, immersing the listener into their personal audio environment. FEATURES APPLICATIONS „ Enables modern, lightweight and ergonomic designs for sophisticated wearables Adap speakers can be used for free-field audio systems as well as wearables. For 2-way earphones Adap speakers are suitable as tweeters. „ Seamless integration into acoustic devices for everyday use „ Longer battery life due to the speaker’s low power consumption „ Enhanced cover for handling protection „ Competitive sound pressure level „ No magnetic field „ Low heat generation USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com CONTENT SPECIFICATIONS 3 MECHANICAL DIMENSIONS 4 FORCE ON SPEAKER 5 TEST CONDITIONS 6 ACOUSTIC PERFORMANCE 8 HANDLING 11 INTEGRATION 12 CONNECTIVITY 13 LABELLING 13 PACKAGING 14 REVISION HISTORY Released in January 2020 June 2020: Update in power consumption section 2 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com SPECIFICATIONS General acoustics fres @ 15 VP [kHz] 2.9 [-] 0.7 Effective membrane surface – SD [mm²] 12 Equivalent volume – VAS [mm³] 40 Front volume inside speaker [mm³] 5.6 Back volume inside speaker [mm³] 20 SPL @ 1 kHz / 15 VP [dB] 51 ±3.0 SPL @ 4 kHz / 15 VP [dB] 71 ±3.0 SPL @ 10 kHz / 15 VP [dB] 74 ±3.0 SPL @ 1 kHz / 5 VP [dB] 40 ±3.0 SPL @ 4 kHz / 5 VP [dB] 60 ±3.0 SPL @ 10 kHz / 5 VP [dB] 63 ±3.0 THD @ 1 kHz / 5 VP [%] 13 +20 THD @ 4 kHz / 5 VP [%] 4 +3 THD @ 10 kHz / 5 VP [%] 4 +3 [nF] 38 ±20% Q @ fres / 15 VP ±15% Acoustics in baffle (IEC 60268-5) Electronics Capacity @ 1 kHz / 15 VP Operating conditions Maximum AC voltage (peak) – up to 40 kHz [VP] 15 Maximum DC voltage [V] 15 [mAP] 200 [mW] 46 Maximum AC current (peak) Power consumption with IEC noise (60268-1) @ 60 dB *Power consumption test conditions can be found in page 6. 3 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com MECHANICAL DIMENSIONS Cover Membrane and plate Positive pole contact Negative pole contact Ring Back port Protection sheet Figure 1: Mechanical drawings: perspective view 0.90 ±0.02 1.30 ±0.15 BE 0 0.1 0± t por k c Ba .02 1 ±0 TE 5.50 ±0.02 0.18 ±0.06 Bottom to contact 2.78 ±0.04 4.70 ±0.10 1.60 ±0.03 1.58 ±0.15 0.80 ±0.05 3.60 ±0.03 DMC format: 8x18. Pixel size 0.2mm 3.50 ±0.02 0.8 1.12 ±0.05 1.40 ±0.05 6.70 ±0.10 Figure 2: Mechanical drawings: top/down/side view Mechanics Size [mm] 6.7 x 4.7 x 1.58 Total speaker weight [mg] 80 [mm³] 50 Total speaker cubic volume 4 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com FORCE ON SPEAKER Type of stress Maximum handling force [N] Maximum permanent force [N] Front face compression 20 13 Side face compression 20 13 3 point bending 10 5 Force on membrane 0 0 Figure 3: Left: front face compression, centre: side face compression, right: 3-point bending 5 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com TEST CONDITIONS ACOUSTICS General Measurement system Audio Precision APx Measurement signal Exp. Sweep Voltage levels – audio VDC + VAC 15 V + 15 VP Applied back volume Open (infinite) Baffle Baffle type IEC 60268-5 Mic distance 3 cm Reference distance 10 cm Microphone GRAS 46AC Microphone diameter 1/2” BAFFLE MEASUREMENT ADAPTER DETAIL A MEMS Speaker 4xPogo-pins 3 0.3 Sealing Gasket IEC Baffle A Sealing O-Ring Figure 4: The outlet through the baffle for the speaker has the same shape as the inside of the speaker cover 6 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com POWER CONSUMPTION AND REFERENCE DRIVING CIRCUIT Power consumption is measured with one Adap MEMS speaker, including the typical driving circuitry with the DC boost converter TPS61046 and the amplifier TI LM4858. The main blocks are presented in Figure 2 and Figure 3. Condition: Supply voltage 3.6 V; speaker placed in baffle; all noise signals with high pass filter 2nd order @ 2 kHz. L1 10uH +1.8V to +5.5V A1 A2 C1 1uF 10V C1 U1 VIN SW GND VOUT EN FB +15V B2 C2 B1 TPS61046 VB_ENABLE GND C2 10uF 25V R1 536k R2 30k GND GND Figure 5: TPS61046 boost converter including needed passive components GND +2.5V to +5.5V C3 10uF 10V 4.7uH C4 1uF 10V GND C2 AMP_ENABLE B2 GAIN C6 A3 AUDIO_IN 1uF 6.3V B3 C9 1uF 6.3V GND C5 1uF 25V U2 C3 GND D1 L2 VDD SHDN_N GAIN IN+ IN- SW VBST VAMP OUT+ OUTSGND PGND D2 GND D1 C1 A1 C7 B1 C8 A2 D3 1uF 35V +15V R3 10K MEMs_BE MEMs_TE 1uF 35V R4 10K LM48580 GND GND Figure 6: LM48580 amplifier, including needed passive components The boost converter is configured to provide a constant 15 VDC offset for the amplifier. The amplifier circuit itself is based on the typical application diagram from the LM48580 datasheet. It is based on a single-ended input signal but can also be modified according to the datasheet to a differential input. 7 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com ACOUSTIC PERFORMANCE ACOUSTIC PERFORMANCE IN BAFFLE (IEC 60268-5) 90 80 SPL10cm [dB] 70 60 50 40 1000 2000 3000 5000 7000 Frequency [Hz] 10000 20000 30000 40000 20000 30000 40000 Figure 7: SPL @ 15 VP drive* 50 45 40 THD [%] 35 30 25 20 15 10 5 0 1000 2000 3000 5000 7000 Frequency [Hz] 10000 Figure 8: THD 60 dB SPL @ 4 kHz, corresponds to 5 VP Red lines in figure 7 indicate the limits. Test limits are used to establish incoming inspection acceptance/rejection criteria, correlation of test equipment with USound is also a requirement for elimination of equipment and test method variation.* 8 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com GROUP DELAY 1 Group Delay [ms] 0,8 0,6 0,4 0,2 0 1000 2000 3000 4000 5000 6000 8000 Frequency [Hz] 10000 20000 30000 40000 2,2 2,4 Figure 9: Sampling frequency 96 kHz. Time delay between speaker and microphone compensated. IMPULSE RESPONSE Impulse Response [Pa/V] 0,02 0,01 0 -0,01 -0,02 -0,2 0 0,2 0,4 0,6 0,8 1 1,2 Time [ms] 1,4 1,6 1,8 2 Figure 10: Sampling frequency 96 kHz. Time delay between speaker and microphone compensated. 9 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com ACOUSTIC PERFORMANCE USING THE CARME TEST BOX IN FREE FIELD To analyse the performance of the Adap MEMS speakers, the Carme test box is available. With a back volume of 100 mm³, Carme provides the necessary sealing to avoid an acoustic short circuit and offers a convenient way to connect Adap to USound‘s linear amplifier, Amalthea. To set up the Carme test box, unscrew and separate the PCB from the shell. Remove the housing gasket and place the MEMS speaker with the contact side up. Place the PCB by taking care to match the orientation marks with those on the speaker. Tighten the screws for proper sealing. Using the Carme test box, Adap MEMS speakers can be measured in free field. Figure 11: Positive input (+) blue and negative input (-) green. The colour coding matches the outputs of Amalthea 90 Reference adapter in baffle Carme-box in free field 80 SPL10cm [dB] 70 60 50 40 1000 2000 3000 4000 5000 6000 8000 Frequency [Hz] 10000 20000 30000 40000 Figure 12: Adap SPL measurement in the Carme test box (10 cm) in free field 10 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com HANDLING GENERAL It needs to be considered that MEMS devices consist of silicon structures, and therefore, they should be handled with care. Any bending of the MEMS speakers must be avoided while handling, during the assembly process and when permanently inside an application, otherwise the speaker can be damaged. TWEEZERS It is recommended to grab the speakers from the sides with blunt curved tweezers and avoid touching the membrane in any case to preserve its functionality and form. Using sharp tweezers while manipulating the speakers can lead to accidentally piercing the membrane and to a loss of functionality. The risk to damage the speaker can be further minimized if the speaker is handled with the membrane facing down, as shown in the picture below. Figure 13: Left: Recommended tweezer type. Right: Not recommended tweezer type 11 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com INTEGRATION It needs to be considered that MEMS devices consist of silicon structures, and therefore, they should be handled with care. Any bending of the MEMS speakers must be avoided while handling, during the assembly process and when permanently inside an application, otherwise the speaker can be damaged. To avoid bending of the speaker, it’s recommended that just the defined contact areas are in touch with the application at front side and back side of the speaker. Contact area 0,81 0,89 Contact area 0,81 0,89 Figure 14: Recommended contact surfaces at back side (right) and front side (left) of MEMS speaker 12 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com CONNECTIVITY + The speaker is driven by applying voltage between the + and the - connection. The potential of + has to be always equal or higher than the -. To ensure this a DC voltage together with the AC signal has to be applied on +. Attention: The AC peak voltage must always be smaller than or equal to the DC voltage. The membrane will move downwards/inside by applying a positive voltage on the + connection. _ Figure 15: Electrical connections of the speaker back side Each speaker is equipped with an 8 x 18 digital matrix code (DMC) „ DMC Size: 3.6 mm x 1.6 mm 3.60 ±0.03 DMC format: 8x18. Pixel size 0.2mm LABELLING „ Pixel size: 0.2 mm „ Data format corresponds to the production date: NNYCCDSSSS. For example: 0191024022 1.60 ±0.03 Figure 16: DMC at speaker backside 02 NN Speaker type (01 = Adap; 02= Achelous) 13 9 Y 10 2 4022 CC D SSSS Week day (First day starts on Sunday) Serial number Year Calendar week (Last digit of the year) USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com PACKAGING Thickness: 0.5 mm QTY 150 PCS 82,26 7 ESD FOAM SUPPORT SIZE: 325 X 138 X 13 136 ±0,8 68 ±0,8 161 ±0,8 322 ±0,8 10,90 85 150 X 5 = 750 PCS plus 1 x empty top tray 158 342 200 750 X 9 = 6750 PCS 40 0 600 Figure 17: Packaging in tray and carton 14 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com IMPORTANT NOTICE AND DISCLAIMER USound GmbH (“USound”) makes no warranties for the use of USound products, other than those expressly contained in USound’s applicable General Terms of Sale, located at www.usound.com. USound assumes no responsibility for any errors which may have crept into this document, reserves the right to change devices or specifications detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No license to patents or other intellectual property rights of USound are granted in connection with the sale of USound products, neither expressly nor implicitly. In respect of the intended use of USound products by the customer, the customer is solely responsible for observing existing patents and other intellectual property rights of third parties and for obtaining, as the case may be, the necessary licenses. For more information about USound patents visit https://www.usound.com/patents/. Important note: The use of USound products as components in medical devices and/or medical applications, including but not limited to, safety and life supporting systems, where malfunctions of such USound products might result in damage to and/or injury or death of persons is expressly prohibited, as USound products are neither destined nor qualified for use as components in such medical devices and/or medical applications. The prohibited use of USound products in such medical devices and/or medical applications is exclusively at the risk of the customer. 15 USound GmbH | Adap UT-P2019 Datasheet Released in January 2020 | Updated in June 2020 www.usound.com | sales@usound.com
UT-P2019 价格&库存
很抱歉,暂时无法提供与“UT-P2019”相匹配的价格&库存,您可以联系我们找货
