UMW
R
AO4405
P-Channel MOSFET
General Description
The AO4405 uses advanced trench technology to provide
excellent RDS(ON) with low gate charge. This device is
suitable for use as a load switch or in PWM applications.
General Features
VDS = -30V ID = -6 A
RDS(ON) < 45mΩ @ VGS=10V
A p p lic a tio n
Battery protection
Load switch
Uninterruptible power supply
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
TA=25°C
Continuous Drain
Current
TA=70°C
Pulsed Drain Current
Avalanche Current
C
Avalanche energy L=0.1mH
C
VDS Spike
10µs
TA=25°C
Power Dissipation B
TA=70°C
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
Maximum Junction-to-Ambient A D
Maximum Junction-to-Lead
www.umw-ic.com
Steady-State
Steady-State
V
A
IDM
-30
IAS, IAR
17
A
EAS, EAR
14
mJ
VSPIKE
-36
V
3.1
W
2
-55 to 150
TJ, TSTG
Symbol
t ≤ 10s
±20
-5.1
PD
Junction and Storage Temperature Range
Units
V
-6
ID
C
Maximum
-30
Typ
31
59
16
RθJA
RθJL
1
°C
Max
40
75
24
Units
°C/W
°C/W
°C/W
UTD Semiconductor Co.,Limited
UMW
R
AO4405
P-Channel MOSFET
Electrical Characteristics
(TC unless otherwise noted)
J=25°
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
ID=-250µA, VGS=0V
IDSS
Zero Gate Voltage Drain Current
IGSS
Gate-Body leakage current
VDS=0V, VGS= ±20V
VGS(th)
Gate Threshold Voltage
VDS=VGS ID=-250µA
-1
ID(ON)
On state drain current
VGS=-10V, VDS=-5V
-30
RDS(ON)
Static Drain-Source On-Resistance
Min
-30
Typ
VDS=-30V, VGS=0V
TJ=55°C
-1.5
53
75
mΩ
-0.8
IS
Ciss
Coss
Maximum Body-Diode Continuous Current
Input Capacitance
VGS=0V, VDS=-15V, f=1MHz
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Qg(10V)
Gate resistance
Total Gate Charge
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
trr
Body Diode Reverse Recovery Time
Qrr
V
VGS=-4.5V, ID=-5A
IS=-1A,VGS=0V
Turn-On DelayTime
-2.5
mΩ
Diode Forward Voltage
tD(on)
nA
45
VSD
Gate Drain Charge
±100
33
14
Qgd
µA
VGS=-10V, ID=-6A
VDS=-5V, ID=-6A
Gate Source Charge
-1
A
Forward Transconductance
Qgs
Units
V
-5
gFS
Qg(4.5V) Total Gate Charge
Max
VGS=0V, VDS=0V, f=1MHz
3.5
VGS=-10V, VDS=-15V, ID=-6A
S
-1
V
-3.5
520
A
pF
100
pF
65
pF
7.5
9.2
11.5
11
Ω
nC
4.6
6
nC
1.6
nC
2.2
ns nC
7.5
ns
5.5
ns
19
ns
7
ns
IF=-6A, dI/dt=100A/µs
11
Body Diode Reverse Recovery Charge IF=-6A, dI/dt=100A/µs
5.3
ns
nC
Ω,
=2.5
VGS=-10V, VDS=-15V, RL=2.5Ω,
RGEN=3Ω
A. The value of RθJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The
value in any given application depends on the user's specific board design.
B. The power dissipation PD is based on TJ(MAX)=150°C, using ≤ 10s junction-to-ambient thermal resistance.
C. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150°C. Ratings are based on low frequency and duty cycles to keep
initialTJ=25°C.
D. The RθJA is the sum of the thermal impedence from junction to lead RθJL and lead to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AO4405”相匹配的价格&库存,您可以联系我们找货
