UMW
R
UMW AO4410
N-Channel MOSFET
D
■ Features
● VDS (V) = 30V
● ID = 18 A (VGS = 10V)
● RDS(ON) < 5.5mΩ (VGS = 10V)
G
S
● RDS(ON) < 6.2mΩ (VGS = 4.5V)
■ Absolute Maximum Ratings Ta = 25℃
Parameter
Symbol
Rating
Drain-Source Voltage
VDS
30
Gate-Source Voltage
VGS
±12
Continuous Drain Current
TA=25℃
ID
TA=70℃
Pulsed Drain Current
Power Dissipation
Thermal Resistance.Junction- to-Ambient
IDM
TA=25℃
PD
TA=70℃
t ≤ 10s
RthJA
Steady-State
Thermal Resistance.Junction- to-Lead
Junction Temperature
Storage Temperature Range
www.umw-ic.com
1
Unit
V
18
15
A
80
3.1
2
W
40
75
RthJL
24
TJ
150
Tstg
-55 to 150
℃/W
UTD Semiconductor Co.,Limited
UMW
R
UMW AO4410
N-Channel MOSFET
■ Electrical Characteristics Ta = 25℃
Parameter
Drain-Source Breakdown Voltage
Symbol
VDSS
Zero Gate Voltage Drain Current
IDSS
Gate-Body Leakage Current
IGSS
Gate Threshold Voltage
VGS(th)
Test Conditions
ID=250 uA, VGS=0V
Min
Typ
30
1
VDS=24V, VGS=0V, TJ=55℃
5
VDS=0V, VGS=±12V
VDS=VGS , ID=250uA
RDS(On)
VGS=10V, ID=18A
0.8
ID(ON)
VGS=4.5V, VDS=5V
Forward Transconductance
gFS
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Gate Resistance
Rg
Total Gate Charge
Qg
Gate Source Charge
Qgs
±100
nA
1.5
V
7.4
TJ=125℃
VDS=5V, ID=18A
A
102
S
9130 10500
VGS=0V, VDS=15V, f=1MHz
pF
625
387
VGS=0V, VDS=0V, f=1MHz
VGS=10V, VDS=15V, ID=18A
0.4
0.5
72.4
85
Qgd
16.8
td(on)
11
15
Turn-On Rise Time
tr
7
11
Turn-Off DelayTime
td(off)
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Maximum Body-Diode Continuous Current
IS
Diode Forward Voltage
VSD
VGS=10V, VDS=15V, RL=0.83Ω,
RGEN=3Ω
IF= 18A, dI/dt= 100A/us
99
135
13
19.5
33
40
22.2
IS=1A,VGS=0V
Ω
nC
13.4
Turn-On DelayTime
tf
mΩ
6.2
80
Gate Drain Charge
Turn-Off Fall Time
uA
5.5
VGS=4.5V, ID=15A
On State Drain Current
Unit
V
VDS=24V, VGS=0V
VGS=10V, ID=18A
Static Drain-Source On-Resistance
Max
ns
30
nC
4.5
A
1
V
Note : The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AO4410”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+2.140753000+0.25908
- 6000+1.993106000+0.24121
- 15000+1.9192915000+0.23227
- 30000+1.8454730000+0.22334
- 国内价格 香港价格
- 1+5.547491+0.67136
- 10+4.8701610+0.58939
- 25+4.5780325+0.55403
- 100+3.73542100+0.45206
- 250+3.46932250+0.41986
- 500+2.95268500+0.35733
- 1000+2.362181000+0.28587
