UMW
R
UMW APM4953
-30V P-Channel MOSFET
Features
D1
VDS (V) = -30V
D2
ID = -5.3A (VGS = 10V)
RDS(ON) < 41mΩ (VGS = -10V)
RDS(ON) < 75mΩ (VGS = -4.5V)
G1
G2
S1
S2
G2
S1
G1
S2
1
2
3
4
8
7
6
5
D2
D2
D1
D1
Absolute Maximum Ratings (TA=25oC, unless otherwise noted)
Symbol
Parameter
Ratings
Units
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
-5.3
A
ID
IDM
Drain Current (Continuous)
-20
A
PD
o
Total Power Dissipation @TA=25 C
2.0
W
IS
Maximum Diode Forward Current
-1.9
A
-55 to +150
°C
50
°C/W
Tj, Tstg
RθJA
Drain Current (Pulsed)
a
Operating Junction and Storage Temperature Range
b
Thermal Resistance Junction to Ambient (PCB mounted)
a: Repetitive Rating: Pulse width limited by the maximum junction temperation.
b: 1-in2 2oz Cu PCB board
www.umw-ic.com
1
UTD Semiconductor Co.,Limited
UMW
R
UMW APM4953
Electrical Characteristics (TA=25°C, unless otherwise noted)
Symbol
Characteristic
Test Conditions
Min.
Typ.
Max.
Unit
OFF CHARACTERISTICS
BVDSS
Drain-Source Breakdown Voltage
VGS=0V, ID=-250uA
-30
V
IDSS
Zero Gate Voltage Drain Current
VDS=-24V, VGS=0V
-1
uA
IGSS
Gate-Body Leakage Current
VGS=±20V, VDS=0V
±100
nA
VDS=VGS, ID=-250uA
-1
-1.5
-2.5
VGS=-10V, ID=-5.3A
38
41
VGS=-4.5V, ID=-3.9A
59
75
VDS=-10V, ID=-5.3A
11
504
68
56
12
2.3
b
ON CHARACTERISTICS
VGS(th)
Gate Threshold Voltage
RDS(on)
Drain-Source On-State Resistance
gFS
Forward Transconductance
V
mΩ
S
C
DYNAMIC CHARACTERISTICS
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
SWITCHING CHARACTERISTICS
VDS=-15V, VGS=0V, f=1MHz
C
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
1.4
td(on)
Turn-on Delay Time
8.1
tr
Turn-on Rise Time
VDD=-15V, RL=5Ω, ID=-3A,
3.3
td(off)
Turn-off Delay Time
VGEN=-10V, RG=6Ω
29.3
5.6
-1.3
tf
PF
VDS=-15V, ID=-3.6A, VGS=-10V
Turn-off Fall Time
nC
nS
Drain-Source Diode Characteristics
VSD
Drain-Source Diode Forward Voltage
VGS=0V, IS=-1.9A
V
Note: Pulse Test: Pulse Width ≤300us, Duty Cycle≤2%
www.umw-ic.com
2
UMW
R
UMW APM4953
Characteristics Curve
www.umw-ic.com
3
UMW
R
UMW APM4953
www.umw-ic.com
4
UMW
R
UMW APM4953
PACKAGE OUTLINE DIMENSIONS
SOP-8
Symbol
A
A1
A2
b
c
D
E
E1
e
L
θ
www.umw-ic.com
Dimensions In Millimeters
Min
Max
1.350
1.750
0.100
0.250
1.350
1.550
0.330
0.510
0.170
0.250
4.700
5.100
3.800
4.000
5.800
6.200
1.270(BSC)
0.400
1.270
0°
8°
5
Dimensions In Inches
Min
Max
0.053
0.069
0.004
0.010
0.053
0.061
0.013
0.020
0.006
0.010
0.185
0.200
0.150
0.157
0.228
0.244
0.050(BSC)
0.016
0.050
0°
8°
UMW
R
UMW APM4953
Marking
Ordering information
Order code
Package
Baseqty
Deliverymode
UMW APM4953
SOP-8
3000
Tape and reel
www.umw-ic.com
6
很抱歉,暂时无法提供与“APM4953”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+1.749003000+0.21183
- 6000+1.636166000+0.19816
- 15000+1.5233315000+0.18450
- 30000+1.4443430000+0.17493
- 国内价格 香港价格
- 1+4.937121+0.59794
- 10+4.2318210+0.51252
- 25+3.9476325+0.47810
- 100+3.15924100+0.38262
- 250+2.93373250+0.35531
- 500+2.48240500+0.30065
- 1000+1.918261000+0.23233
