ENTUBE DE-HB (1500V 10V SESC) 数据手册
Entube DE-HB
Specification Sheet for Verivolt Ultra-Compact,
High-Bandwidth, Differential Voltage Sensor
OVERVIEW
The Entube-DE-HB series was designed to enable measurement of fast high voltage signals in industrial and research environments. The output of the Entube-DE-HB is a linearly scaled down
version of the voltage difference between its two input terminals. This output can then be processed by a computer based measurement system. The Entube-DE-HB series covers multiple input
dynamic ranges (±100V, ±200V, ±300V, ±400V, ±500V, ±750V, ±1000V and ±1500V) with a 20MHz
bandwidth, and 0.2% accuracy.
In addition to multiple dynamic ranges, the Entube-DE-HB can be ordered to have a single-ended
or a differential-pair output. The single-ended version has a BNC connector at the output, and can
be ordered as ±10V, ±5V or ±1V.
SPECIFICATIONS
Entube DE-HB
100V
200V
300V
400V
Bandwidth (-3dB point)
1500V
< 290 μV
< 350 μV
< 350 μV
< 350 μV
< 370 μV
< 650 μV
< 700 μV
10
40
50
75
100
150
10MΩ||1pF
20MΩ||1pF
40MΩ||1pF
Input Inpedance
2 MΩ || 1pF
5M || 1pF
Eletrical
HARDWARE
DESCRIPTION
The high voltage input signal connects to the sensor via two
clamp cage connectors. Use appropriate wire jacket and gauge,
as well as creepage distance. For superior noise immunity, it is
recommended to use a twisted pair from the high voltage source
to the input of the sensor.
Performance
Accuracy (percentage of
reading)
Max total phase shift at 60Hz
Max Input delay
±0.2%
< 0.001°
< 20 ns
Withstanding common mode
surge voltage
4x Input Range for 0.1s
Withstanding differential mode
surge voltage
5x Input Range for 0.1s
Input-Output non-linearity
Output voltage
Gain temperature drift
Common mode rejection
at 60Hz
Power Supply Voltage
Output type
Mechanical
Output Offset Voltage
Output impedance
Mounting Type
DIN Rail
Connectivity In
Spring cage
Weight
1000V
< 380 μV
Gain
(Using 10V standard
output voltage)
Outer Dimensions
750V
20MHZ
Integrated sensor noise
(Referenced to output)
Connedtivity Out
500V
Spring cage / BNC
< 80 ppm
See notes
±40 ppm/°C
82 dB
8V to 28V
Single-ended or differential pair
< ±0.5mV
(on ±10V signal)
50Ω (-S) , 100Ω (-D)
Environmental
Operating temperature
Storage temperature
– 0 to 70 °C
Connections for Entube DE-HB
A spring cage connector is used to input power to the sensor. A single post screw terminal is
used to ground the secondary side of the sensor.
The signal out of the sensor comes in a BNC connector (singleended version), or a spring cage connector (differential-pair version). If signal reflections are a concern, place the sensor as close
as possible to the high voltage signal source, and use the appropriate cable and load termination. If using a digitizer with BNC
inputs, use a 50Ω coaxial cable and a 50Ω terminating load at the
digitizer end. If using a digitizer with differential inputs, use a 100
Ω twisted pair and a 100 Ω terminating load at the digitizer end.
– 65 to 90 °C
3.6” x 2.4” x 1.4”
198 g (7.0 oz)
The schematic on the figure above shows how to connect the
Entube-DE-HB between the high voltage signal source and the
digitizer.
650 Washington St, San Francisco, CA 94111
Phone: 70VERIVOLT / (708) 374-8658
1
MERCHANICAL
DIMENSIONS
HARDWARE
CONFIGURATION
A. Ground sensor by connecting a
wire from the ground to the standoff
located next to the two spring connectors. Connect any 8V to 28V external
power source to power the unit.
A
Standards and Certifications
● CE
B. Insert a wire pair between each of
these connectors and a corresponding
current input on the DAQ. The polarity of the signal out is aligned with the
input signals.
C. On the primary side, connect the
plus and minus signals. Use standard
twisted pair.
C
B
DANGER
THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the
failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage.
2
ENTUBE DE-HB (1500V 10V SESC) 价格&库存
很抱歉,暂时无法提供与“ENTUBE DE-HB (1500V 10V SESC)”相匹配的价格&库存,您可以联系我们找货
