VL-EPM-5G
VL-EPM-5G
    VERSALOGIC
    ROHS GX-500 W/256 MB RAM, P/T
VL-EPM-5G 数据手册
PUMA PC/104-Plus Single Board Computer  Low power AMD Geode™ GX 500 processor  256 MB soldered-on DDR RAM  Integrated video  PC/104-Plus expansion  CompactFlash socket  RoHS-compliant Highlights PC/104-Plus Form Factor Provides PC/104 and PC/104-Plus expansion on a compact, highly rugged format. AMD Geode GX 500 Processor 366 MHz performance with low power draw. High-performance Video Analog and LVDS at panel outputs for 18 and 24-bit displays. Network Support 10/100 Ethernet provides fast network access and boot ROM support. 4 USB Ports Multiple USB ports provide exible I/O options for keyboard, mouse, oppy drives, and other devices. Integrated I/O Three COM ports (one RS-232, two RS-422/485), one IDE interface, and one LPT port with SPP and enhanced modes. TVS Protection Enhanced ESD resistance. CompactFlash Socket Removable storage media has no moving parts and supports bootable media. Fanless Operation No moving parts required for CPU cooling. Power Management Suspend-to-RAM support allows extreme power savings during system standby. Watchdog Timer Provides hardware-level safety control for application run-away conditions. Embedded BIOS OEM embedded features and rmware support. Field-upgradeable. Customization available. Overview The Puma is an extremely compact and rugged single board computer that combines a high degree of functionality with low power requirements and no moving parts. The inherent ruggedness of the Puma’s PC/104 size combined with the low power AMD Geode GX 500 processor make this board a great fit for portable devices, vehicular/aircraft controls, medical electronics, and many other OEM applications. The Puma has an impressive list of on-board features, including integrated high-performance video with flat panel support, 10/100 Ethernet, four USB ports, three COM ports, LPT port, and an IDE interface. A CompactFlash socket provides bootable media storage, and TVS devices provide enhanced ESD protection on user I/O ports. The Puma includes 256 MB of soldered-on, high-speed RAM for optimum application performance. Like all VersaLogic products, this small and efficient SBC is designed to support OEM applications where high reliability and long-term availability are required. From application design-in to 5+ years production life, its quality and longevity provide a cost-effective, long-term solution. Customization is available on as few as 100 pieces. The Puma is manufactured and tested to the highest quality standards, is compliant with RoHS regulations, and is backed by a two year limited warranty. Details The Puma features the AMD Geode GX 500 processor, which offers excellent performance while drawing only one watt of power. This highly-integrated processor provides extremely fast on-board transfers (6 GB per second), high-speed memory access, and integrated highperformance video with LVDS flat panel support. The Puma can operate as a stand-alone SBC or can be combined with specialized PC/104 or PC/104-Plus I/O boards for additional functionality. Pass-through connectors for the PC/104 and PC/104-Plus interfaces provide support for many off-the-shelf I/O boards and also provide an interface for custom baseboards that may be larger than the Puma. The Puma includes several features to support the reliable operation of the board in the field, including TVS devices and self-resetting fuses on USB port power pins. The TVS devices provide enhanced ESD protection for the analog video output, USB, COM, LPT, and Ethernet ports. VersaLogic Corporation •  4211 West 11th Ave., Eugene, OR 97402 •  (541) 485-8575 •  Fax (541) 485-5712 •  info@VersaLogic.com •  www.VersaLogic.com PUMA PC/104-Plus Single Board Computer Specif ications The board features a General Software Embedded BIOS with OEM enhancements and power management. The suspend-to-RAM power management feature allows extremely low power usage between sessions. This field-reprogrammable BIOS supports custom defaults and the addition of firmware and firmbase applications for security processes, remote booting, and other pre-OS software functions. The Puma is compatible with a variety of popular operating systems, including Windows, Windows Embedded, Linux, and VxWorks. General Processor Chipset Power Requirements AMD Geode GX 500 AMD Geode CS5536 System Reset Watchdog timout VCC sensing (resets below 4.7V typ.) PC/104: footprint compatible. PC/104-Plus: supports 3.3V PCI signaling (2.1 compliant). RoHS: compliant. 3.55” x 3.78” (90 mm x 96 mm) with 0.20” connector overhangs in the designated connector areas -40° to +85°C Compatibility Mechanical Board Size Storage Temperature Operating Temperature Thermal Shock Vibration, Sinusoidal Sweep Vibration, Random Memory Humidity System RAM Flash Interface Video General Desktop Display Interface* OEM Flat Panel Interface Ordering Information VL-EPM-5g ............................ AMD Geode GX 500, 366 MHz, Standard Temp. VL-EPM-5h ........................... AMD Geode GX 500, 333 MHz, Extended Temp. Network Interface Ethernet* Device I/O USB*‡ IDE Interface Network Boot Option Accessories VL-CBR-0803 .........................................Audio cable, stereo in/out (RoHS) VL-CBR-1008* ........................................ ATX power adapter cable (RoHS) VL-CBR-1201* ................................... Analog video interface cable (RoHS) VL-CBR-2003*..................................................LPT interface cable (RoHS) VL-CBR-2010 ..........................LVDS / FPD interface cable (Hirose) (RoHS) VL-CBR-2011 ...............................LVDS / FPD interface cable (JAE) (RoHS) VL-CBR-4404 .............................................44-pin 2 mm IDE cable (RoHS) VL-CBR-4405*.............................. 1” connector IDE adapter board (RoHS) VL-CBR-4406*................................................................. IDE cable (RoHS) VL-CBR-5009A................................................18” I/O ribbon cable (RoHS) VL-CBR-5010* .............................................................I/O cable set (RoHS) VL-CDD-IDE1 ...................................................... CD-RW, DVD-ROM drive VL-CF-CLIP1 ...................................................CompactFlash retention clip VL-CFM-xxxx ........................................................... CompactFlash module VL-CKR-PUMA ............................................ Development cable kit (RoHS) VL-DEV-CD-L3 ................................ Debian Linux Board Support Package VL-ENCL-4 (VersaTainer) .........................................Ruggedized enclosure VL-ENCL-5c ............................................................Development enclosure VL-FDD-144U ....................................................................USB floppy drive VL-HDD35-xxx .............................................................. 3.5” IDE hard drive VL-HDW-101*..........................................Mounting standoffs, metric thread VL-XCC104A .......................................64-pin, 8-bit, PC/104 spacer (RoHS) VL-XCC104B .....................................40-pin, 16-bit, PC/104 spacer (RoHS) VL-XCC104P .......................... 120-pin, 32-bit, PC/104-Plus spacer (RoHS) * Included in VL-CKR-PUMA Cable Kit COM 1 Interface* COM 2 Interface COM 3 & 4 Interface* LPT Interface* Audio Software +5V ±5% @1A (5W) typ. operating +5V ±5% @160 mA (800 mW) typ. standby 0° to +60°C (VL-EPM-5g) -40° to +85°C (VL-EPM-5h) 5°C/min. over operating temperature 2g constant acceleration from 5 to 500Hz, 20 minutes per axis, MIL-STD202G, Method 204, Modified Condition A .02g2/Hz (5.35g rms) 15 minutes per axis, MIL-STD-202G, Method 214A, Condition A Less than 95%, noncondensing 256 MB Soldered-on DDR SDRAM High-retention CompactFlash socket. Type I or II supported. Integrated high-performance video. Up to 1280 x 1024 with 24-bit color. MMX™ + 3D Now!™ Standard analog output. 2 mm IDC connector. 18/24-bit LVDS interface. CMOSselectable TFT panel types. Autodetect 10BaseT/100BaseTX port. Right angle connector. Firmware-based Argon Managed Boot Agent. Supports PXE, RPL, NetWare, TCP/IP (DHCP, BOOTP) remote boot protocols 4 USB 2.0 ports ATA-5, UDMA66 interface. 44-pin 2 mm connector. RS-232 compatible, standard PC serial connector. 115 Kbps. N/A RS-422/485 selectable. 460 Kbps. Standard PC parallel port. 2 mm 20-pin latching connector. SPP and enhanced modes supported. AC’97 stereo line in/out Other Floppy, mouse, and keyboard support provided via USB Operating Systems Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, and VxWorks BIOS General Software’s Embedded BIOS with OEM enhancements. Field reprogrammable. User-configurable CMOS defaults. *TVS protected port (Enhanced ESD protection). ‡ Power pins on this port are protected with a self-resetting fuse. Data represents standard operation at 25°C with +5V supply unless otherwise noted. Specifications are subject to change without notification. PC/104 is a trademark of the PC/104 Consortium. 06/08/10 VersaLogic Corporation •  4211 West 11th Ave., Eugene, OR 97402 •  (541) 485-8575 •  Fax (541) 485-5712 •  info@VersaLogic.com •  www.VersaLogic.com
VL-EPM-5G 价格&库存
很抱歉,暂时无法提供与“VL-EPM-5G”相匹配的价格&库存,您可以联系我们找货
