VL-CFA-1C
VL-CFA-1C
    VERSALOGIC
    COMPACTFLASH ADAPTER REMOTE .1"
VL-CFA-1C 数据手册
VL-CFA-1CompactFlash Adapter Adapter for Type I and II CompactFlash cards and drives. Features Access CompactFlash cards like an IDE Drive via direct cable connection Compatible with Type I and II CompactFlash™ standards Mounting holes for rigid attachment Push button module ejector Power and drive activity LEDs CompactFlash card may be selected as either master or slave drive Works with any operating system having IDE support Description The CFA-1 CompactFlash Adapter provides a low cost, rugged, and flexible means to add a socket for removable CompactFlash cards to an embedded computer. CompactFlash cards have a system interface that is electrically and functionally identical to that of normal (magnetic media) IDE hard disk drives, so they are fully supported by all operating systems and application programs. The CompactFlash Adapter is compatible with both Type I and Type II CompactFlash modules. Type II modules include IBM Microdrives and larger capacity Flash modules. The CFA-1 is available in two versions: one with a 40-pin, 0.1-inch IDE connector for direct cabling to a 3.5” IDE interface; the other with a 44-pin, 2mm IDE connector for direct cabling to an 2.5” IDE interface. Specifications Specifications are typical at 25°C with 5.0V supply unless otherwise noted. Ordering Information VL-CFA-1a . . . . . . . . . . . . . Mezzanine module for VSBC-7 VL-CFA-1b . . . . . . . . . . . . . Adapter with a 2mm IDE connector VL-CFA-1c . . . . . . . . . . . . . Adapter with a 0.1” IDE connector CFD-0320 . . . . . . . . . . . . . 320 MB Micro Drive. Type II module CFM-xxxx . . . . . . . . . . . . . 16/32/64/128 MB CompactFlash module Specifications [Specifications are typical at 25°C with 5.0V supply unless otherwise noted] Board Size (including ejector): 2.73” x 2.625” x 0.4” Storage and Operating Temperature: Depends on specific CompactFlash card requirements Power Requirements: Depends on specific CompactFlash card requirements Compatibility: Type I and II CompactFlash cards Specifications are subject to change without notice. https://web.archive.org/web/20010201211200/http://versalogic.com:80/Ds/cfa.htm
VL-CFA-1C 价格&库存
很抱歉,暂时无法提供与“VL-CFA-1C”相匹配的价格&库存,您可以联系我们找货
