VPFEM5120GTCBMTL
VPFEM5120GTCBMTL
    VIKINGTECHNOLOGY
    SSD 120GB M.2 MLC SATAIII 3.3V
VPFEM5120GTCBMTL 数据手册
SATA 6Gb/s M.2 SATA Manual M.2 SATA is a non-volatile, solid-state storage device delivering Serial ATA performance, reliability and ruggedness for environmentally challenging applications. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 1 of 48 Revision History Date Revision 3/27/15 X1 5/07/15 A 5/13/15 B 7/30/15 3/1/16 C D 9/20/16 E 3/20/17 F Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com Description Initial Release from modified PSFEM4XXXGTXXX_X3 and PN table per PSG Add photo, update per psg. 4/29/15 Change all PN to VPxx., remove 42/60mm references. Change all PN to VPxx., remove 42/60mm references. Remove PFAIL/DATA Hardening signaling. Changed Absolute max Vin 3.6V. Reliability table changed from 72 bit per 1KB to 120 bit per 2KB page. Changed table 4-1 Signal and Power pin 58 to Reserved for MFG_CLOCK Revise power consumption table. IOPS per IOmeter8. Add notes to PN table Add 15nm PN’s Update PN table Revise logo and color scheme. Remove temp sensor and SATA attribute. Revise note 2 on Extended SMART Attribute Actual Data table Checked By 3/20/2017 Viking Technology Page 2 of 48 Legal Information Legal Information Copyright© 2017 Sanmina Corporation. All rights reserved. The information in this document is proprietary and confidential to Sanmina Corporation. No part of this document may be reproduced in any form or by any means or used to make any derivative work (such as translation, transformation, or adaptation) without written permission from Sanmina. Sanmina reserves the right to revise this documentation and to make changes in content from time to time without obligation on the part of Sanmina to provide notification of such revision or change. Sanmina provides this documentation without warranty, term or condition of any kind, either expressed or implied, including, but not limited to, expressed and implied warranties of merchantability, fitness for a particular purpose, and noninfringement. While the information contained herein is believed to be accurate, such information is preliminary, and should not be relied upon for accuracy or completeness, and no representations or warranties of accuracy or completeness are made. In no event will Sanmina be liable for damages arising directly or indirectly from any use of or reliance upon the information contained in this document. Sanmina may make improvements or changes in the product(s) and/or the program(s) described in this documentation at any time. Sanmina, Viking Technology, Viking Modular Solutions, and Element logo are trademarks of Sanmina Corporation. Other company, product or service names mentioned herein may be trademarks or service marks of their respective owners. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 3 of 48 Ordering Information: M.2 80mm SATA SSD Solid-State Drive Part Number Interface VPFEM5480GTCZMTK VPFEM5480GTCZMMC VPFEM5240GTCVMTK VPFEM5240GTCAMMC VPFEM5120GTCTMTK VPFEM5120GTCBMMC VPFEM5480GTCZMTL VPFEM5240GTCAMTL VPFEM5120GTCBMTL SATA 6GB SATA 6GB SATA 6GB SATA 6GB SATA 6GB SATA 6GB SATA 6GB SATA 6GB SATA 6GB User Capacity (GB) 480 480 240 240 120 120 480 240 120 NAND Temperature (C) MLC MLC MLC MLC MLC MLC MLC MLC MLC (0 to +70'c) (0 to +70'c) (0 to +70'c) (0 to +70'c) (0 to +70'c) (0 to +70'c) (0 to +70'c) (0 to +70'c) (0 to +70'c) NAND TSB A19nm K-die Micron 16nm L95B TSB A19nm K-die Micron 16nm L95B TSB A19nm K-die Micron 16nm L95B TSB 15nm L-die TSB 15nm L-die TSB 15nm L-die Notes: 1. Usable capacity based on a level of over-provisioning applied to wear leveling, bad sectors, index tables etc. 2. Higher capacity points may be available based on customer application. Consult your local Viking FAE Engineer. 3. SSD’s ship unformatted from the factory unless otherwise requested. 4. 1 GB = 1,000,000,000 Byte 5. One Sector = 512 Byte. . Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 4 of 48 Product Picture(s) M.2 2280 FRONT Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com M.2 2280 BACK 3/20/2017 Viking Technology Page 5 of 48 Enterprise SSD – An Enterprise SSD contains hardware and firmware that detect and manage power failures. This allows the drive to flush the controller cache and harden data to NAND flash. No data is lost or corrupted. . Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 6 of 48 Table of Contents 1 INTRODUCTION 10 1.1 Features 10 1.2 Block Diagram 11 1.3 SATA Interface 12 2 2.1 PRODUCT SPECIFICATIONS Performance 13 13 2.2 Timing 2.2.1 STANDBY IMMEDIATE Command 13 13 2.3 Electrical Characteristics 2.3.1 Absolute Maximum Ratings 2.3.2 Supply Voltage 2.3.3 Power Consumption 14 14 14 15 2.4 Environmental Conditions 2.4.1 Temperature and Altitude 2.4.2 Shock and Vibration 2.4.3 Electromagnetic Immunity 15 15 16 16 2.5 16 Reliability 2.6 Data Security 2.6.1 Encryption 2.6.2 Quick Erase 2.6.3 Military Secure Erase / Sanitization/ Purge Routines 16 16 17 18 3 29 MECHANICAL INFORMATION 3.1 Dimensions 29 3.2 Card Edge Detail 31 3.3 M.2 SSD Weight 33 4 PIN AND SIGNAL DESCRIPTIONS Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 33 3/20/2017 Viking Technology Page 7 of 48 4.1 Signal and Power Description Tables 33 4.2 Hot Plug Support 34 5 COMMAND SETS 34 5.1 ATA Commands 5.1.1 48-Bit Address Command Set 5.1.2 ATA General Feature Command Set 5.1.3 Device Configuration Overlay Command Set 5.1.4 General Purpose Log Command Set 5.1.5 Host Protected Area Command Set 5.1.6 Power Management Command Set 5.1.7 Security Mode Feature Set 5.1.8 Identify Device Data 5.1.1 S.M.A.R.T. Support 5.1.2 SATA 3.0 S.M.A.R.T. Command Set 34 35 36 36 36 36 37 37 38 42 43 5.2 SATA Commands 5.2.1 Native Command Queuing (NCQ) 47 47 6 REFERENCES 47 7 GLOSSARY 48 Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 8 of 48 Table of Tables Table 2-1: Maximum Sustained Read and Write Bandwidth ____________________________ 13 Table 2-2: Random Read and Write Input/Output Operations per Second (IOPS) ___________ 13 Table 2-3: Timing Specifications _________________________________________________ 13 Table 2-4: STANDBY IMMEDIATE Timing _________________________________________ 14 Table 2-5: Absolute Maximum Ratings ____________________________________________ 14 Table 2-6: Operating Voltage ____________________________________________________ 14 Table 2-7: Typical Power Consumption at 3.3V ______________________________________ 15 Table 2-8: Temperature and Altitude Related Specifications ____________________________ 15 Table 2-9: Shock and Vibration Specifications _______________________________________ 16 Table 2-10: Reliability Specifications ______________________________________________ 16 Table 2-11: Military Secure Erase / Sanitize Routines _________________________________ 18 Table 3-1: M.2 SSD weight ______________________________________________________ 33 Table 4-1: M.2 SATA Connector Pinouts ___________________________________________ 33 Table 5-1: Supported ATA Commands ____________________________________________ 34 Table 5-2: List of Device Identification _____________________________________________ 38 Table 5-3: S.M.A.R.T. Command Set ______________________________________________ 43 Table 5-4: Extended SMART Attribute Table ________________________________________ 43 Table 5-5: Extended SMART Attribute Actual Data ___________________________________ 44 Table 5-6: Supported S.M.A.R.T. EXECUTE OFF-LINE IMMEDIATE Subcommands ________ 47 Table of Figures Figure 1-1: High-Level Block Diagram _____________________________________________ 11 Figure 3-1: Dimensions ________________________________________________________ 29 Figure 3-2: Dimension Details for M.2 80mm length __________________________________ 30 Figure 3-3: Dimension Details for M.2 card edge _____________________________________ 31 Figure 3-4: Dimension Details for M.2 connector and notch ____________________________ 32 Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 9 of 48 1 Introduction Viking’s rugged industrial designed SSD’s offer the highest flash storage reliability and performance in harsh environments such as shock, vibration, humidity, altitude, ESD, and extreme temperatures. 1.1 Features The SSD delivers the following features:  Seamless SATA Revision 3.2 interface support for SATA up to 6Gb/s  Low overall SSD power consumption  Supports Native Command Queuing (NCQ) to 32 commands  Compatible with all major SLC and MLC flash technologies  S.M.A.R.T.  Superior static and dynamic wear-leveling algorithm  Efficient error recovery  Power hold-up circuit technology ensures no data loss resulting from an unexpected power loss and is supported for industrial temperatures  TRIM Support  48-bit LBA Support Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 10 of 48 1.2 Block Diagram Figure 1-1: High-Level Block Diagram 3.3V Notes: Support for up to 8-channels and 32 CE in the NAND Flash interface Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 11 of 48 1.3 SATA Interface    The Serial ATA (SATA) interface is compliant with the SATA IO Serial ATA specification, revision 3.0 that supports SATA up to 6 Gbps. The SATA interface connects the host computer to the SSD subsystem. The SATA interface runs at a maximum speed of 6 Gbps (Giga-bits per second). If the host computer is unable to negotiate a speed of 6 Gbps, the SATA interface automatically renegotiates to a speed of 3 Gbps or 1.5 Gbps. For a list of supported commands and other specifics, please see Chapter 5. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 12 of 48 2 Product Specifications 2.1 Performance Table 2-1: Maximum Sustained Read and Write Bandwidth Access Type Sequential Read, 256K Sequential Write, 256K MB/s Up to 550 Up to 530 Notes: 1. Performance measured using Iometer 08 2. Performance may vary from flash configuration, SDR configuration, and platform. 3. Refer to Application Note AN0006 for Viking SSD Benchmarking Methodology. 4. Data is based on SSD’s using Toshiba A19nm Toggle NAND devices Table 2-2: Random Read and Write Input/Output Operations per Second (IOPS) Access Type Read, 4K Write, 4K IOPS Up to 100,000 Up to 90,000 Notes: 1. Performance measured using Iometer 08 with queue depth set to 32. 2. Write Cache enabled with DDR cache. 3. Random IOPS cover the entire range of legal logical block addresses (LBA’s). Measurements are performed on a full drive (all LBA’s have valid content). 4. Performance may vary by NAND type and host. 5. Refer to Application Note AN0006 for Viking SSD Benchmarking Methodology. 6. Data is based on SSD’s using Toshiba A19nm NAND devices 2.2 Timing Table 2-3: Timing Specifications Type Average Latency Read (at 64KB) 0.14mS Write (at 64KB) 2.12mS Power On Ready (POR) 436mS Notes: 1. Device measured using Drivemaster. 2. DRQ (Data Transfer Requested) bit being asserted 2.2.1 STANDBY IMMEDIATE Command The Power-On-to-Ready time assumes a proper shutdown (power removal preceded by STANDBY IMMEDIATE command. A STANDBY IMMEDIATE before power down always performs a graceful shutdown and does not require the use of the hold-up circuit. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 13 of 48 Table 2-4: STANDBY IMMEDIATE Timing Power Cycle Endurance STANDBY IMMEDIATE to WE completed Min - Max 72.9 Unit ms Notes: 1. From Standby Immediate command to NAND Write Protect enable. 2.3 Electrical Characteristics 2.3.1 Absolute Maximum Ratings Values shown are stress ratings only. Functional operation outside normal operating values is not implied. Extended exposure to absolute maximum ratings may affect reliability. Table 2-5: Absolute Maximum Ratings Description Maximum Voltage Range for Vin Maximum Temperature Range Min -0.2 -40 Max 3.6 85 Unit V c Min 3.135 Max 3.465 Unit V 2.3.2 Supply Voltage The operating voltage is 3.3V Table 2-6: Operating Voltage Description Operating Voltage for 3.3 V (+/- 5%) Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 14 of 48 2.3.3 Power Consumption All onboard power requirements of the SSD are derived from the SATA 3.3V rail. Table 2-7: Typical Power Consumption at 3.3V Capacity Flash: TSBA19 Read() Write 128GB 8GBx1Diex16CE 2.224 3.446 256GB 8GBx1Diex32CE 2.21 512GB 8GBx2Diex32CE 1TB 16GBx2Diex32CE Capacity Flash: M L95B 128GB Idle Partial Slumber 0.505 0.0911 0.0911 4.31 0.566 0.0695 0.068 2.335 4.431 0.632 0.0824 0.0798 2.481 4.234 0.651 0.1014 0.1009 Read() Write Idle Partial Slumber 16GBx1Diex8CE 2.193 2.524 0.625 0.1158 0.0716 256GB 16GBx1Diex16CE 2.161 3,624 0,571 0.0675 0,0659 512GB 16GBx2Diex16CE 2.39 3.971 0.567 0.1199 0.0968 Notes: 1. The average value of power consumption is achieved based on 100% conversion efficiency. 2. The measured power voltage is 5V. 3. Samples were built of Toshiba A19nm Toggle MLC NAND flash and measured under ambient temperature. 4. Sequential R/W is measured while testing 400MB sequential R/W 5 times by CrystalDiskMark. 5. Power Consumption may differ according to flash configuration and platform. 2.4 Environmental Conditions 2.4.1 Temperature and Altitude Table 2-8: Temperature and Altitude Related Specifications Conditions Commercial Temperature- Ambient Industrial Temperature- Ambient Humidity (noncondensing) Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com Operating 0 to 70°C Shipping -40 to 85°C Storage -40 to 85°C -40 to 85°C -40 to 85°C -40 to 85°C 90% under 40C 93% under 40C 93% under 40C 3/20/2017 Viking Technology Page 15 of 48 2.4.2 Shock and Vibration SSD products are tested in accordance with environmental specification for shock and vibration Table 2-9: Shock and Vibration Specifications Stimulus Shock Description 500G, 2ms 20 – 80 Hz/1.52mm 80 – 2000 Hz/20G (X,Y,Z axis / 30 min for each) Vibration 2.4.3 Electromagnetic Immunity M.2 is an embedded product for host systems and is designed not to impair with system functionality or hinder system EMI/FCC compliance. 2.5 Reliability Table 2-10: Reliability Specifications Parameter Description ECC 120 bit per 2KB page Read Endurance Write Endurance Unlimited 32GB 64GB 128GB 256GB 512GB 1024GB 79 TBW 158 TBW 317 TBW 635 TBW 1272 TBW 2548 TBW Data retention > 90 days at NAND expiration 2.6 Data Security 2.6.1 Encryption The SSD drive is a self-encrypting drive (SED), with a bulk data encryption feature that provides automatic hardware-based data security and enhanced secure erase capability. A self-encrypting drives, scrambles data using a data encryption key as it is written to the drive and then descrambles it with the key as it is retrieved. This gives the user the highest level of data protection available and provides a fast Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 16 of 48 erase simply by deleting the encryption key, eliminating the need for time consuming data-overwrite. Data on the drive is instantly rendered unreadable. The SSD supports AES-256 encryption and ATA Secure Erase features to protect sensitive data. The SSD drives support the following security features:  AES 256 on the fly support.  RSA 512/1024/2048  SHA 160/256/512  TCG OPAL SSC V1.0 2.6.2 Quick Erase Quick Erase has been designed to remove data under prompt and urgent situation and is triggered by sending an ATA Command. Input Info of Executing Quick Erase Command Normal Output Info of Executing Quick Erase Command Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 17 of 48 Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. 2.6.3 Military Secure Erase / Sanitization/ Purge Routines Many government and military organizations such as NIST/NSA define their own standard and procedures for performing a Military Secure Erase which overwrite different patterns to sanitize the flash media. Some of the more common military or government purge routines are defined in the following table and the data security features of the drive comply with Department of Defense (DoD) and US military data security standards. Table 2-11: Military Secure Erase / Sanitize Routines Standard Action SSD 1 Code NSA/CSS 9-12 Erase and overwrite all locations with a known unclassified pattern. Verify the overwrite procedure by randomly rereading the overwritten information to confirm that only the known pattern can be recovered. Note 1 NSA/CSS 130-2 Erase the media and overwrite with random data 2 times, then erase and overwrite with a character Note 1 DoD5220.22-M Erase the media and overwrite with single character, then erase again Note 1 NISPOMSUP Chap 8, Sect.8-501 Erase the media and overwrite with single character, then erase again and overwrite with single character, then erase again and overwrite with random character then erase again Note 1 USA Army 380-19 Erase the media and overwrite with random data, erase and overwrite with a character, then erase and overwrite with complement of the character Note 1 Navy NAVSO P-523926 Erase the media and overwrite with random data, then erase again Note 1 Air Force AFSSI 5020 Erase the media and overwrite with pattern, repeat 3 times Note 1 Air Force AFSSI 8580 TBD Note 1 Notes: 1. Enabled using ATA commands Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 18 of 48 Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 19 of 48 2.6.3.1 AFSSI 5020 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. Input Info of Executing AFSSI 5020 Command Normal Output Info of Executing AFSSI 5020 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 20 of 48 2.6.3.2 DOD 5220.22-M Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. 2) To erase the whole disk. Input Info of Executing DoD 5220.22-M Command Normal Output Info of Executing DoD 5220.22-M Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 21 of 48 2.6.3.3 USA NAVY NAVSO P-5239-26 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. 3) To erase the whole disk again. Input Info of Executing USA Navy NAVSO P-5239-26 Command Normal Output Info of Executing USA Navy NAVSO P-5239-26 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 22 of 48 2.6.3.4 NSAMANUAL 130-2 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. 3) To fill the whole disk with random data one more time. 4) To erase the whole disk again. 5) To fill the whole disk with fixed character pattern of 0x55. Input Info of Executing NSA Manual 130-2 Command Normal Output Info of Executing NSA Manual 130-2 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 23 of 48 ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 24 of 48 2.6.3.5 USA-ARMY 380-19 Pattern: 1) To erase the whole disk. 2) To fill the whole disk with random data. 3) To fill the whole disk with fixed character pattern of 0x55. 4) To fill the whole disk with fixed character pattern of 0xAA. Input Info of Executing USA-Army 380-19 Command Normal Output Info of Executing USA-Army 380-19 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 25 of 48 2.6.3.6 NISPOMSUP CHAP 8, SECT. 8-501 Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. 2) To fill the whole disk with fixed character pattern of 0xAA. 3) To fill the whole disk with random data. Input Info of Executing NISPOMSUP chap 8, Sect. 8-501 Command Normal Output Info of Executing NISPOMSUP chap 8, Sect. 8-501 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 26 of 48 2.6.3.7 NSA/CSS 9-12 Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. Input Info of Executing NSA/CSS 9-12 Command Normal Output Info of Executing NSA/CSS 9-12 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 27 of 48 2.6.3.8 AFSSI 8580 Pattern: 1) To fill the whole disk with fixed character pattern of 0x55. 2) To fill the whole disk with fixed character pattern of 0xAA. 3) To fill the whole disk with random data. Input Info of Executing AFSSI 8580 Command Normal Output Info of Executing AFSSI 8580 Command Device/Head Register: DEV shall indicate the selected device. Status Register: BSY shall be cleared to zero indicating command completion. DRDY shall be set to one. DF (Device Fault) shall be cleared to zero. DRQ shall be cleared to zero. ERR shall be cleared to zero. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 28 of 48 3 Mechanical Information 3.1 Dimensions Figure 3-1: Dimensions d VRFEM6xxx Note2 VRFEM4xxx Note2 VPFEM5xxx Note2 Notes: 1. All dimensions are in millimeter. General tolerance is ± 0.15. PCB thickness 0.8 ± 0.08 2. Refer to Ordering Information table for the complete Viking part number that describes the “xxx”. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 29 of 48 Figure 3-2: Dimension Details for M.2 80mm length VPFEM5xxx Note2 FOR CARD EDGE DETAIL SEE SECTION 3.2 Notes: 1. All dimensions are in millimeter. General tolerance is ± 0.15. PCB thickness 0.8 ± 0.08 2. Refer to Ordering Information table for the complete Viking part number that describes the “xxx”. Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 30 of 48 3.2 Card Edge Detail Figure 3-3: Dimension Details for M.2 card edge Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 31 of 48 Figure 3-4: Dimension Details for M.2 connector and notch Key notch detail Manual PSFEM5xxxGTxxx Revision F www.vikingtechnology.com 3/20/2017 Viking Technology Page 32 of 48 3.3 M.2 SSD Weight Table 3-1: M.2 SSD weight Length 80 mm Weight
VPFEM5120GTCBMTL 价格&库存
很抱歉,暂时无法提供与“VPFEM5120GTCBMTL”相匹配的价格&库存,您可以联系我们找货
