KTPS200 Series
200 Watt
Universal Input, Desktop Adapter
INPUT SPECIFICATIONS
All specifications are typical at nominal input, full load.
Input Voltage
AC 100 – 240VAC
Input Frequency
50 – 60Hz
Input Current
2.8A Max
Protection
Internal Primary Current Fuse
Inrush Limiting
OUTPUT SPECIFICATIONS
Output Voltage
See Chart
Efficiency
CEC Level V, ErP Stage 2
Protection
Short Circuit Protection
Over Current Protection
Over Voltage Protection
Over Temperature Protection
Ripple
3 – 5 % Vp-p (max)
Hold-Up Time
10 mS (min)
Transient Response
0.5mS for 50% Load Change(typ)
Load Regulation
± 5% (typ)
Leakage Current
3.5mA @ 3 pin
GENERAL SPECIFICATIONS
MTBF(Calculated)
50,000 Calculated hours at 25°C
by MIL-HDBK-217F
Dielectric Withstanding
Voltage
3,000 VAC Primary – Secondary
EMI
Conduction & Radiation
Compliance to EN55022 Class B
Harmonic Current
FEATURES
UNIVERSAL INPUT (AC100-240V)
ON/OFF SWITCH
OVER VOLTAGE PROTECTION
OVER CURRENT PROTECTION
OVER TEMPERATURE PROTECTION
ROHS COMPLIANT / CEC LEVEL V
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature
0°C~+40°C
Storage Temperature
-20°C ~ +80°C
Cooling.
Convection
Operating Humidity
20 – 80% Rh
Storage Humidity
10 – 90% Rh
MECHANICAL SPECIFICATIONS
Case Dimension
L183 x W81 x H42(mm)
L203 x W81 x H42(mm)
with Switch
Compliance to EN61000-3-2,3
Input Configuration
IEC320-C14
(Optional C6)
EMS Immunity
Compliance to EN61000-42,3,4,5,6,8,11
DC Cord
18AWG
(Optional 16 AWG)
Safety Approvals
UL/cUL/CE/CB/GS/PSE/FCC
Output Connector
4pin mini DIN
Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131
Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436)
www.volgen.com
KTPS200 Series
Model Number
Output Voltage
Output Current
Max Output Power
KTPS200-12160 / S*
12.0V
16.0A
192W
KTPS200-18110 / S*
18.0V
11.0A
200W
KTPS200-19105 / S*
19.0V
10.5A
200W
KTPS200-20100 / S*
20.0V
10.0A
200W
KTPS200-24083 / S*
24.0V
8.3A
200W
KTPS200-48042
48.0V
Note: “/S” Denotes an optional ON/OFF switch.
4.2A
200W
Mechanical Drawing:
www.volgen.com
KTPS200 Series
With Optional Switch:
www.volgen.com
很抱歉,暂时无法提供与“KTPS200-12160”相匹配的价格&库存,您可以联系我们找货
