KTPS40-1233DT 3P
KTPS40-1233DT 3P
    KAGA
    12V 40 W AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
KTPS40-1233DT 3P 数据手册
KTPS36/40/50 Series 36 - 50 Watt Universal Input, Desktop Adapter INPUT SPECIFICATIONS All specifications are typical at nominal input, full load. INPUT SPECIFICATIONS Input Voltage AC 100 – 240VAC Input Frequency 50 – 60Hz Input Current 1.2A Max Protection Internal Primary Current Fuse Inrush Limiting OUTPUT SPECIFICATIONS Output Voltage See Chart Efficiency CEC Level V, ErP Stage 2, GEMS Protection Short Circuit Protection Over Current Protection Over Voltage Protection Ripple 1 - 2 % Vp-p (max) Hold-Up Time 10 mS (min) Transient Response 0.5mS for 50% Load Change(typ) Load Regulation ± 5% (typ) Leakage Current 0.25mA @ 2 pin 3.5mA @ 3 pin FEATURES        UNIVERSAL INPUT (AC100-240V) CEC LEVEL V OVER VOLTAGE PROTECTION OVER CURRENT PROTECTION SHORT CIRCUIT PROTECTION ROHS COMPLIANT NRCAN VERSION AVAILABLE ENVIRONMENTAL SPECIFICATIONS Operating Temperature 0°C~+40°C Storage Temperature -20°C ~ +80°C Cooling. Convection GENERAL SPECIFICATIONS Operating Humidity 20 – 80% Rh MTBF(Calculated) 300,000 Calculated hours at 25°C by Telcordia SR-332 Storage Humidity 10 – 90% Rh Dielectric Withstanding Voltage 3,000 VAC Primary – Secondary MECHANICAL SPECIFICATIONS EMI Conduction & Radiation Compliance to EN55022 Class B Harmonic Current Compliance to EN61000-3-2,3 EMS Immunity Compliance to EN61000-42,3,4,5,6,8,11 Safety Approvals UL/cUL/CE/CB/GS/PSE/FCC Case Dimension L115 x W53 x H38(mm) Input Configuration IEC320-C14 (Optional C6 & C8) DC Cord 18AWG (Optional 20 AWG) Output Connector 5.5 x 2.1 x 9.5 mm C+ Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com KTPS36/40/50 Series Model Number Output Voltage Output Current Max Output Power KTPS36-0940DT-3P 9.0V 4.00A 36.0W KTPS40-1233DT-3P 12.0V 3.30A 39.6W KTPS45-0950DT-3P 9.0V 5.00A 45.0W KTPS50-1242DT-3P 12.0V 4.20A 50.0W KTPS50-13537DT-3P 13.5V 3.71A 50.0W KTPS50-1533DT-3P 15.0V 3.34A 50.0W KTPS50-1827DT-3P 18.0V 2.78A 50.0W KTPS50-1926DT-3P 19.0V 2.64A 49.0W KTPS50-2025DT-3P 20.0V 2.50A 50.0W KTPS50-2421DT-3P 24.0V 2.10A 50.0W KTPS50-4810DT-3P 48.0V 1.05A 48.0W Mechanical Drawing: Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com
KTPS40-1233DT 3P 价格&库存
很抱歉,暂时无法提供与“KTPS40-1233DT 3P”相匹配的价格&库存,您可以联系我们找货
