KTPS36/40/50 Series
36 - 50 Watt
Universal Input, Desktop Adapter
INPUT SPECIFICATIONS
All specifications are typical at nominal input, full load.
Input Voltage
AC 100 – 240VAC
Input Frequency
50 – 60Hz
Input Current
1.2A Max
Protection
Internal Primary Current Fuse
Inrush Limiting
OUTPUT SPECIFICATIONS
Output Voltage
See Chart
Efficiency
CEC Level V, ErP Stage 2,
GEMS
Protection
Short Circuit Protection
Over Current Protection
Over Voltage Protection
Ripple
1 - 2 % Vp-p (max)
Hold-Up Time
10 mS (min)
Transient Response
0.5mS for 50% Load Change(typ)
Load Regulation
± 5% (typ)
Leakage Current
0.25mA @ 2 pin
3.5mA @ 3 pin
FEATURES
UNIVERSAL INPUT (AC100-240V)
CEC LEVEL V
OVER VOLTAGE PROTECTION
OVER CURRENT PROTECTION
SHORT CIRCUIT PROTECTION
ROHS COMPLIANT
NRCAN VERSION AVAILABLE
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature
0°C~+40°C
Storage Temperature
-20°C ~ +80°C
Cooling.
Convection
GENERAL SPECIFICATIONS
Operating Humidity
20 – 80% Rh
MTBF(Calculated)
300,000 Calculated hours at 25°C
by Telcordia SR-332
Storage Humidity
10 – 90% Rh
Dielectric Withstanding
Voltage
3,000 VAC Primary – Secondary
MECHANICAL SPECIFICATIONS
EMI
Conduction & Radiation
Compliance to EN55022 Class B
Harmonic Current
Compliance to EN61000-3-2,3
EMS Immunity
Compliance to EN61000-42,3,4,5,6,8,11
Safety Approvals
UL/cUL/CE/CB/GS/PSE/FCC
Case Dimension
L115 x W53 x H38(mm)
Input Configuration
IEC320-C14
(Optional C6 & C8)
DC Cord
18AWG
(Optional 20 AWG)
Output Connector
5.5 x 2.1 x 9.5 mm C+
Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131
Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436)
www.volgen.com
KTPS36/40/50 Series
Model Number
Output Voltage
Output Current
Max Output Power
KTPS36-0940DT-3P
9.0V
4.00A
36.0W
KTPS40-1233DT-3P
12.0V
3.30A
39.6W
KTPS45-0950DT-3P
9.0V
5.00A
45.0W
KTPS50-1242DT-3P
12.0V
4.20A
50.0W
KTPS50-13537DT-3P
13.5V
3.71A
50.0W
KTPS50-1533DT-3P
15.0V
3.34A
50.0W
KTPS50-1827DT-3P
18.0V
2.78A
50.0W
KTPS50-1926DT-3P
19.0V
2.64A
49.0W
KTPS50-2025DT-3P
20.0V
2.50A
50.0W
KTPS50-2421DT-3P
24.0V
2.10A
50.0W
KTPS50-4810DT-3P
48.0V
1.05A
48.0W
Mechanical Drawing:
www.volgen.com
很抱歉,暂时无法提供与“KTPS50-1533DT 3P”相匹配的价格&库存,您可以联系我们找货
