KTPS65-4813DT-3P-VI-C-P1 数据手册
KTPS65 Series
CEC/DoE Level VI
65 Watt
Universal Input, Desktop Adapter
INPUT SPECIFICATIONS
All specifications are typical at nominal input, full load.
Input Voltage
AC 100 – 240VAC
Input Frequency
50 – 60Hz
Input Current
65W: 1.4A Max / 72W: 1.6A Max
Protection
Internal Primary Current Fuse,
Inrush Limiting
OUTPUT SPECIFICATIONS
Output Voltage
See Chart
Efficiency
DoE Level VI, Energy Star, ErP
Stage 2, NRCan & GEMS Level
VI Certified
Protection
Short Circuit Protection
Over Current Protection
Over Voltage Protection
Ripple
1 - 2 % Vp-p (max)
Hold-Up Time
10 mS (min)
Transient Response
0.5mS for 50% Load Change(typ)
Load Regulation
± 5% (typ)
Leakage Current
0.25mA @ 2 pin / 3.5mA @ 3 pin
GENERAL SPECIFICATIONS
FEATURES
CEC/DoE LEVEL VI
UNIVERSAL INPUT (AC100-240V)
OVER VOLTAGE PROTECTION
OVER CURRENT PROTECTION
SHORT CIRCUIT PROTECTION
ROHS COMPLIANT
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature
0°C ~ +40°C
Storage Temperature
-20°C ~ +80°C
Cooling
Convection
Operating Humidity
20 – 80% Rh
Storage Humidity
10 – 90% Rh
MTBF(Calculated)
300,000 Calculated Hours at
25°C, by Telcordia SR-332
MECHANICAL SPECIFICATIONS
Dielectric Withstanding
Voltage
3,000 VAC Primary – Secondary
Case Dimension
L115 x W53 x H38(mm)
Input Configuration
EMI
Conduction & Radiation
Compliance to EN55022 Class B
IEC320-C14
(Optional C6)
DC Cord
Harmonic Current
Compliance to EN61000-3-2,3
18AWG
(Optional 16 AWG &
20AWG)
EMS Immunity
Compliance to EN61000-42,3,4,5,6,8,11
Output Connector
See Chart
Safety Approvals
UL/cUL/CE/CB/GS/PSE/FCC
Weight
310g (Ref)
Kaga Electronics (USA) Inc. 2480 N. First St., Suite #100, San Jose, CA 95131
Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436)
www.volgen.com
KTPS65 Series
CEC/DoE Level VI
Model Number
Output Voltage
Output Current
Max Output Power
KTPS65-1250DT-3P-VI
12.0V
5.00A
60W
KTPS65-13548DT-3P-VI
13.5V
4.82A
65W
KTPS65-1543DT-3P-VI
15.0V
4.30A
65W
KTPS65-1640DT-3P-VI
16.0V
4.00A
64W
KTPS65-1836DT-3P-VI
18.0V
3.60A
65W
KTPS65-1934DT-3P-VI
19.0V
3.40A
65W
KTPS65-2032DT-3P-VI
20.0V
3.25A
65W
KTPS65-2430DT-3P-VI
24.0V
3.00A
72W
KTPS65-2427DT-3P-VI
24.0V
2.71A
65W
KTPS65-2427DT-3P-VI*
24.0V
2.71A
65W
KTPS65-3021DT-3P-VI
30.0V
2.17A
65W
KTPS65-3220DT-3P-VI
32.0V
2.04A
65W
KTPS65-3220DT-3P-VI**
32.0V
2.04A
65W
KTS65-4813DT-3P-VI
48.0V
1.36A
65W
KTPS65-5611DT-3P-VI
56.0V
1.17A
* = 11A Peak Current
** = 3.9A Peak Currennt
65W
Part Number Key:
www.volgen.com
KTPS65 Series
CEC/DoE Level VI
Mechanical Drawing:
www.volgen.com
KTPS65-4813DT-3P-VI-C-P1 价格&库存
很抱歉,暂时无法提供与“KTPS65-4813DT-3P-VI-C-P1”相匹配的价格&库存,您可以联系我们找货
