2001-1403
    WAGO(万可电子)
    端子块连接器 4 位置 馈通式 红色 14-22 AWG
2001-1403 数据手册
Data sheet | Item number: 2001-1403 TOPJOB®S feedthrough terminal block; rail mount; 4-conductor; 4.2 mm wide; red www.wago.com/2001-1403 Color: Data Electrical data IEC Approvals Ratings per IEC/EN 60947-7-1 Rated voltage (III / 3) 800 V Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 1/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Rated voltage (III / 3) 800 V Rated surge voltage (III/3) 8 kV Rated current 18 A Rated current 2 24 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 UL Approvals Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 15 A CSA Approvals Approvals per C22.2 No 158 Rated voltage CSA (Use Group B) 600 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group C) 600 V Rated current CSA (Use Group C) 15 A Ex information Ratings per ATEX: PTB 05 ATEX 1094 U / IECEx: PTB 05.0034U (Ex eb IIC Gb) Rated voltage EN (Ex e II) 550 V Rated current (Ex e II) 17 A Rated current (Ex e II) with jumper 16 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Open Tool Slot Connectable conductor materials Copper Nominal cross-section 1.5 mm² Solid conductor 0.25 … 2.5 mm² / 22 … 14 AWG Solid conductor; push-in termination 0.75 … 2.5 mm² / 18 … 14 AWG Fine-stranded conductor 0.25 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 1.5 mm² / 22 … 16 AWG Fine-stranded conductor; with ferrule; push-in termination 0.75 … 1.5 mm² / 18 … 16 AWG Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 2/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Fine-stranded conductor; with ferrule; push-in termination 0.75 … 1.5 mm² / 18 … 16 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 9 … 11 mm / 0.35 … 0.43 inch Total number of connection points 4 Total number of potentials 1 Number of levels 1 Wiring type Front-entry wiring Number of jumper slots 2 Physical data Width 4.2 mm / 0.165 inch Height 69.9 mm / 2.752 inch Depth from upper edge of DIN-rail 32.9 mm / 1.295 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Material data Color red Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.124 MJ Weight 5.2 g Commercial data Product Group 22 (TOPJOB S) Packaging type BOX Country of origin DE GTIN 4045454537418 Customs tariff number 8536904000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 3/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Logo Approval Additional Approval Text Certificate name ATEx Physikalisch Technische Bundesanstalt (PTB) EN 60079 PTB 05 ATEX 1094 U (II 2 G Ex e II bzw.I M 2 Ex e I) CCCEx CQST/CNEx CNCA-C23-01 2020312313000159 EAC Brjansker Zertifizierungsstelle TP TC 012/2011 RU C-DE.AM02.B. 00127/19 IECEx Physikalisch Technische Bundesanstalt (PTB) IEC 60079 IECEx PTB 05. 0034 U (Ex eb IIC Gb or Ex eb I Mb) Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 60947 2160584.07 CCA DEKRA Certification B.V. EN 60947 NTR NL7084 CSA DEKRA Certification B.V. C22.2 No. 158 1645434 Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 20HG1941090PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 Ship Approvals Logo LR EN 60947 Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Certificate name 91/20112 Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 4/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 LR Lloyds Register EN 60947 91/20112 (E9) UL-Approvals Logo Approval Additional Approval Text UL UL International Germany GmbH UL 1059 Certificate name 20190731E45172 Required accessories End plates Item no.: 2002-1491 TOPJOB®S end/intermediate plate; for 2002-14xx series terminal blocks; 0.8 mm wide; gray www.wago.com/2002-1491 Item no.: 2002-1492 TOPJOB®S end/intermediate plate; for 2002-14xx series terminal blocks; 0.8 mm wide; orange www.wago.com/2002-1492 Optional accessories Marking accessories Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-114 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/2009-114 Item no.: 2009-114/000-002 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/2009-114 /000-002 Item no.: 2009-114/000-005 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/2009-114 /000-005 Item no.: 2009-114/000-006 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/2009-114 /000-006 Item no.: 2009-114/000-007 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/2009-114 /000-007 Item no.: 2009-114/000-012 Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us www.wago.com/2009-114 Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 5/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Item no.: 2009-114/000-012 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/2009-114 /000-012 Item no.: 2009-114/000-023 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/2009-114 /000-023 Item no.: 2009-114/000-024 WMB-Inline; for Smart Printer; 2000 pieces on roll; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/2009-114 /000-024 Item no.: 793-4501 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/793-4501 Item no.: 793-4501/000-002 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/793-4501 /000-002 Item no.: 793-4501/000-005 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/793-4501 /000-005 Item no.: 793-4501/000-006 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/793-4501 /000-006 Item no.: 793-4501/000-007 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/793-4501 /000-007 Item no.: 793-4501/000-012 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/793-4501 /000-012 Item no.: 793-4501/000-017 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/793-4501 /000-017 Item no.: 793-4501/000-023 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; light green www.wago.com/793-4501 /000-023 Item no.: 793-4501/000-024 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/793-4501 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us www.wago.com/793-501 Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 6/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Testing accessories Item no.: 2001-511 TOPJOB® S modular connector; for 2001 series; for jumper contact slot; 1-pole; gray www.wago.com/2001-511 Item no.: 2001-549 TOPJOB®S spacer module; for 2001-511; 4.2 mm wide; gray www.wago.com/2001-549 Item no.: 2001-552 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 2-pole; gray www.wago.com/2001-552 Item no.: 2001-553 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 3-pole; gray www.wago.com/2001-553 Item no.: 2001-554 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 4-pole; gray www.wago.com/2001-554 Item no.: 2001-555 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 5-pole; gray www.wago.com/2001-555 Item no.: 2001-556 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 6-pole; gray www.wago.com/2001-556 Item no.: 2001-557 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 7-pole; gray www.wago.com/2001-557 Item no.: 2001-558 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 8-pole; gray Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us www.wago.com/2001-558 Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 7/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 8-pole; gray www.wago.com/2001-558 Item no.: 2001-559 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 9-pole; gray www.wago.com/2001-559 Item no.: 2001-560 TOPJOB® S connector strip; for 2001 series; for jumper contact slot; 10-pole; gray www.wago.com/2001-560 Item no.: 2009-174 TOPJOB®S test plug adapter; for test plug 4 mm Ø; for testing TOPJOB®S terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 TOPJOB®S testing tap; tool-free; 12 AWG max; for testing TOPJOB®S terminal blocks; gray www.wago.com/2009-182 Insulations stops Item no.: 2001-171 TOPJOB®S insulation stop; for 2001 series terminal blocks; 0.25 - 0.5 mm2; 5/strip; light gray www.wago.com/2001-171 Push-in type wire jumper Item no.: 2009-412 TOPJOB®S wire jumper; insulated; 60 mm long; conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 series terminal blocks; gray www.wago.com/2009-412 Item no.: 2009-414 TOPJOB®S wire jumper; insulated; 110 mm long; conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 series terminal blocks; gray www.wago.com/2009-414 Item no.: 2009-414/000-005 Push-in type wire jumper; 1.5 mm²; insulated; 110 mm long; black www.wago.com/2009-414 /000-005 Item no.: 2009-414/000-006 Push-in type wire jumper; insulated; 110 mm long; black www.wago.com/2009-414 /000-006 Item no.: 2009-416 TOPJOB®S wire jumper; insulated; 250 mm long; conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 series terminal blocks; gray www.wago.com/2009-416 Protective warning marker Item no.: 2001-115 TOPJOB®S protective warning marker; with high-voltage symbol, for 2001 series terminal blocks; for 5 www.wago.com/2001-115 terminal blocks End plates Item no.: 2002-1493 TOPJOB®S end/intermediate plate; for 2002-14xx series terminal blocks; 2.0 mm wide; gray www.wago.com/2002-1493 Item no.: 2002-1494 TOPJOB®S end/intermediate plate; for 2002-14xx series terminal blocks; 2.0 mm wide; orange www.wago.com/2002-1494 Item no.: 209-191 Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange www.wago.com/209-191 Ferrules Item no.: 216-241 Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 8/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Carrier rail Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured www.wago.com/210-647 Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 2001-402 TOPJOB®S jumper; for 2001 series; insulated; 2-way; light-gray www.wago.com/2001-402 Tools Jumpers Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 9/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Item no.: 2001-403 TOPJOB®S jumper; for 2001 series; insulated; 3-way; light-gray www.wago.com/2001-403 Item no.: 2001-404 TOPJOB®S jumper; for 2001 series; insulated; 4-way; light-gray www.wago.com/2001-404 Item no.: 2001-405 TOPJOB®S jumper; for 2001 series; insulated; 5-way; light-gray www.wago.com/2001-405 Item no.: 2001-405/011-000 TOPJOB®S jumper; Wye configuration; for 2001 series; insulated; 3-way (1-3-5); light-gray www.wago.com/2001-405 /011-000 Item no.: 2001-406 TOPJOB®S jumper; for 2001 series; insulated; 6-way; light-gray www.wago.com/2001-406 Item no.: 2001-406/020-000 TOPJOB®S jumper; Delta configuration; for 2001 series; insulated; 6-way (1-2, 3-4, 5-6); light-gray www.wago.com/2001-406 /020-000 Item no.: 2001-407 TOPJOB®S jumper; for 2001 series; insulated; 7-way; light-gray www.wago.com/2001-407 Item no.: 2001-408 TOPJOB®S jumper; for 2001 series; insulated; 8-way; light-gray www.wago.com/2001-408 Item no.: 2001-409 TOPJOB®S jumper; for 2001 series; insulated; 9-way; light-gray www.wago.com/2001-409 Item no.: 2001-410 TOPJOB®S jumper; for 2001 series; insulated; 10-way; light-gray www.wago.com/2001-410 Item no.: 2001-433 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-3); light-gray www.wago.com/2001-433 Item no.: 2001-434 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-4); light-gray www.wago.com/2001-434 Item no.: 2001-435 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-5); light-gray www.wago.com/2001-435 Item no.: 2001-436 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-6); light-gray www.wago.com/2001-436 Item no.: 2001-437 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-7); light-gray www.wago.com/2001-437 Item no.: 2001-438 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-8); light-gray www.wago.com/2001-438 Item no.: 2001-439 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-9); light-gray www.wago.com/2001-439 Item no.: 2001-440 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-10); light-gray Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us www.wago.com/2001-440 Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 10/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 TOPJOB®S jumper; for 2001 series; insulated; 2-way (1-10); light-gray www.wago.com/2001-440 Item no.: 2006-499 Step-down jumper; insulated; from 6/4 mm² to 4/2.5/1.5 mm²; Nominal current 32 A www.wago.com/2006-499 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Downloads Documentation Bid Text 2001-1403 Feb 19, 2019 xml 4.0 kB Download Aug 2, 2018 docx 15.1 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download EPLAN Data Portal 2001-1403 URL Download ZUKEN Portal 2001-1403 URL Download WSCAD Universe 2001-1403 URL Download URL Download X81 - Datei 2001-1403 docx - Datei Additional Information Technical explanations CAD files CAD data 2D/3D Models 2001-1403 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 2001-1403 Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 11/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Environmental Product Compliance 2001-1403 URL Download 4-conductor through terminal block; 1.5 mm²; suitable for Ex e II applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 1,50 mm²; red Installation Notes Inserting a conductor All conductor types at a glance Push-in termination of solid and ferruled conductors Inserting a conductor via push-in termination: Solid conductors with cross-sections from either one size above, or up to two sizes below, the rated cross-section can be simply pushed in – no tools needed. Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 12/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Inserting a conductor via operating tool: Conductor termination – insulation stop Connecting fine-stranded conductors without ferrules, or small cross-sectional conductors that cannot be pushed in, is performed similarly to the original CAGE CLAMP® – just use an operating tool. Advantage: To open the clamp, the operating tool is inserted vertically. The conductor entry is less than 15 degrees for easier wiring. Commoning Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 13/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 The push-in type jumper bar system is based on the common plug and socket principle. Each terminal block is spring-loaded with a double socket and a resilient CrNi steel spring. The jumper contact material is pure electrolytic copper, which allows for an extremely small design capable of carrying the full-rated current of the terminal block. Ground terminal blocks can also be commoned using the same jumper system. Custom jumpers are created by breaking and removing jumper contacts (2000, 2001, 2002, 2004 Series). Removing a push-in type jumper bar: Insert the operating tool between the jumper and partition wall of the dual jumper slots, then lift up the jumper. Place the operating tool in the center of jumpers for up to five contacts (see above), or alternately on both sides for jumpers with more than five contacts. Commoning This star point jumper has been specially developed to create a “star point” and is used on motor terminal boards equipped with TOPJOB® S Rail-Mount Terminal Blocks. This delta jumper has been specially developed to create a delta configuration and is used on motor terminal boards equipped with TOPJOB® S rail-mount terminal blocks. Push down the wire jumper until fully inserted. Lift the jumper with an operating tool for rewiring. Commoning Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 14/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Step-down jumpers common terminal blocks of different sizes, without losing a conductor clamping point. This can be beneficial on long conductor runs where voltage drop can be a problem. A large conductor can be easily connected to smaller conductors at the distribution point. Using step-down jumpers, an end plate must be inserted between the terminal blocks to be commoned. Step-down jumper (2006-499) commons 6 /4 mm² (10/12 AWG) terminal blocks (2006 /2004 Series) with 4/2.5/1.5 mm² (AWG 12/14 /16) terminal blocks (2004/2002/2001 Series). Commoning may be made in either direction using the special thin end plate to cover the open side. Additional through terminal blocks having a smaller cross-section may be commoned using push-in type jumper bars. Step-down jumper (2016‑499) commons 16 /10 mm² (16/8 AWG) terminal blocks (2016 /2010 Series) with 10/6/4/2.5 mm² (8/10/12 /14 AWG) terminal blocks (2010/2006/2004 /2002 Series). Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 15/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Stepping down via push-in type jumper bar: Stepping down via push-in type jumper bar: Note: Commoning via open terminal side with end plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and 10 mm² (8 AWG) and one cross-section size for 6/4/2.5 mm² (10/12/14 AWG). An example: from 16 mm² (6 AWG) to 6 mm² (10 AWG) (see illustration above) or from 10 mm² (8 AWG) to 4 mm² (12 AWG). Commoning via closed terminal side with end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to 6 mm² (10 AWG) or from 6 mm² (10 AWG) to 2.5 mm² (14 AWG) (see illustration above). The total current of the outgoing circuits must not exceed the nominal current of the step-down jumper/push-in type jumper bar. TOPJOB® S Connectors with a 2 mm Ø test socket for testing voltage via 2-pole voltage tester Rail-mount terminal block assembly for electric motor wiring Testing The modular TOPJOB® S connectors also connect conductors of the same size as the terminal blocks being used. Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 16/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Test plug adapter (2009‑174, CAT I) for 4 mm Ø plugs – compatible with 2000 to 2016 Series Testing tap (2009‑182) for tool-free connection of test cables up to 2.5 mm² (12 AWG) – compatible with 2000 to 2016 Series Marking Snapping WMB Inline markers into marker slots. TOPJOB® S 2009‑193 Group Marker Carrier (equipped with a marking strip) for all 2001 to 2016 Series TOPJOB® S Rail-Mount Terminal Blocks Do not use on an end plate! Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 17/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Through terminal blocks with a blue insulated housing are suitable for Ex i applications. All through and ground conductor terminal blocks are suitable for Ex e II applications. Separator plate for Ex e/Ex i applications An end plate must be applied to the terminal block located directly behind an Ex e/Ex i separator plate. Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 18/19 Data sheet | Item number: 2001-1403 www.wago.com/2001-1403 Ex e II/Ex i terminal strip A separator plate is located between the Ex e II and Ex i terminal strip. Note: End plate The movable feet of terminal blocks and separator plates must face the same direction. Ex e II terminal blocks Separator plate for Ex e/Ex i applications End plate Ex i terminal blocks According to EN 50020, a minimum distance of 50 mm must be kept between live parts of Ex e and Ex i circuits. The use of Ex e/Ex i separators is a space-saving solution when Ex e and Ex i terminal blocks are mounted on a common DIN-rail. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at (262) 255-6222 or 1 800-DINRAIL. 18.06.2021    Page 19/19
2001-1403 价格&库存
很抱歉,暂时无法提供与“2001-1403”相匹配的价格&库存,您可以联系我们找货
    • 1+894.22621
      • 1+89.42367
