Data Sheet | Item Number: 2787-2348
Power supply; Pro 2; 3-phase; 24 VDC output voltage; 40 A output current; Top
Boost + PowerBoost; communication capability
https://www.wago.com/2787-2348
Features:
Power supply with TopBoost, PowerBoost and configurable overload behavior
Configurable digital signal input and output, optical status indication, function keys
Communication interface for configuration and monitoring
Optional connection to IO-Link, EtherNet/IP, Modbus TCP or Modbus RTU
Suitable for both parallel and series operation
Natural convection cooling when horizontally mounted
Pluggable connection technology
Electrically isolated output voltage (SELV/PELV) per EN 61010-2-201/UL 61010-2-201
Marker slot for WAGO marking cards (WMB) and WAGO marking strips
Technical data
Input
Output
Phases
3
Nominal output voltage Uo nom
DC 24 V (SELV)
Nominal input voltage Ui nom
3 x AC 400 … 500 V (Connection without
neutral conductor)
Output voltage range
DC 24 … 28 V (adjustable)
Default setting
DC 24 V
Input voltage range
3 x AC 340 … 550 V
40 A (24 VDC)
Nominal mains frequency range
50 … 60 Hz
Nominal output current Io nom
Nominal output power
960 W
Input current Ii
≤ 3 x 1.7 A (400 VAC; 24 VDC / 40 A)
Deviation
≤1%
Inrush current
≤ 15 A (after 1 ms)
Residual ripple
≤ 70 mV (Peak-to-peak)
Power factor correction (PFC)
active
Current limitation
Mains failure hold-up time
≥ 20 ms (3 x 400 VAC)
1.1 x Io nom (typ.)
Overload behavior
TopBoost/PowerBoost/Time-limited con
stant current mode (other overload beha
viors can be set)
Page 1/6
Version 11.02.2023
Continued on next page
Output
Signaling and Communication
PowerBoost
DC 60 A (5 s)
TopBoost
up to 600 %
Signaling
Optical status indication (DC OK; load;
warning and error states)
Digital signal input and output (DI/DO)
Communication
USB (Communication Cable 750-923)
Ethernet/IP (Communication Module
2789-9023)
IO-Link (Communication Module
2789-9080)
Modbus RTU (Communication Module
2789-9015)
Modbus TCP (Communication Module
2789-9052)
Efficiency/power losses
Efficiency (typ.)
Circuit protection
96.1 % (400 VAC; 40 A; 25 °C)
Internal fuse
3 x T 3.2 A / 500 VAC
Backup fusing (required)
An external DC fuse is required for the
DC input voltage.
Backup fusing (recommended)
3 x 16 A (for USA/Canada: 3 x 15 A)
Safety and protection
Isolation voltage (pri.-sec., AC)
3510 V
Isolation voltage (pri.-PE, AC)
2200 V
Isolation voltage (sec.-PE)
DC 0.5 kV
Isolation voltage (sec.-signal)
DC 0.5 kV
Protection class
I
Protection type
IP20; per EN 60529
Resistance to reverse feed
≤ DC 35 V
Overvoltage category
III (≤ 2000 m a.s.l.); II (> 2000 m a.s.l.)
Pollution degree
2
Transient suppression (primary)
Yes
Overvoltage protection; secondary
Internal protective circuit
≤ 35 VDC (in the event of a fault)
Short-circuit-protected
Yes
Open-circuit-proof
Yes
Parallel operation
Yes
Series operation
Yes
MTBF
> 800,000 h (per IEC 61709)
Connection data
Connection type 1
Input/signaling
Connection technology
CAGE CLAMP®
WAGO connector
WAGO 721 Series
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm² / 20 … 14 AWG
Strip length
8 … 9 mm / 0.31 … 0.35 inches
Connection type 2
Output
Connection technology 2
Push-in CAGE CLAMP®
WAGO connector 2
WAGO 831 Series
Solid conductor 2
0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor 2
Fine-stranded conductor; with insulated ferrule 2
0.5 … 6 mm²
Fine-stranded conductor; with uninsulated ferrule 2
0.5 … 6 mm²
Strip length 2
13 … 15 mm / 0.51 … 0.59 inches
Page 2/6
Version 11.02.2023
Physical data
Width
120 mm / 4.724 inches
Height
130 mm / 5.118 inches
Depth from upper-edge of DIN-rail
Note (dimensions)
Height without connector
Height with connector: 169 mm
Mechanical Data
Mounting type
DIN-35 rail
Material Data
Fire load
0 MJ
Weight
2000 g
Environmental requirements
Ambient temperature (operation at UN)
-25 … +70 °C (Device starts at −40 °C (type-tested))
Surrounding air temperature (storage)
-40 … +85 °C
Relative humidity
5 … 96 % (no condensation permissible)
Derating
See instruction leaflet
Operating altitude (max.)
5000 m
Standards and specifications
Conformity marking
CE
Standards/specifications
EN 61010-1
EN 61010-2-201
EN 61204-3
UL 61010-1
UL 61010-2-201
Commercial data
ETIM 8.0
EC002540
ETIM 7.0
EC002540
PU (SPU)
1 pcs
Packaging type
Box
Country of origin
CN
GTIN
4055143907422
Customs tariff number
85044083900
Approvals / Certificates
General approvals
Approvals for hazardous areas
Approval
Standard
Certificate Name
Approval
Standard
Certificate Name
UL
Underwriters Laboratories
Inc.
UL 61010-2-201
E255817
UL
Inc. (HAZARDOUS LOCA
TIONS)
UL 121201
A-E198726
Downloads
Page 3/6
Version 11.02.2023
Environmental Product Compliance
Compliance Search
Compliance 2787-2348
Documentation
Manual
Product Manual Power
Supply; Pro 2; 3-phase;
24 VDC; 40 A
Bid Text
V 1.1.0
15.02.2022
pdf
8570.51 KB
2787-2348_EUSA
04.07.2019
docx
22.77 KB
04.07.2019
xml
7.95 KB
2787-2348_EUSA
ausschreiben.de
2787-2348
Instruction Leaflet
WAGO Stromversor
gung Pro 2
V 1.1.0
26.04.2021
pdf
4610.56 KB
CAD/CAE-Data
CAD data
CAE data
2D/3D Models
2787-2348
EPLAN Data Portal
2787-2348
ZUKEN Portal
2787-2348
Engineering-Software
Software for Interface-Products
WAGO Interface Confi
guration Software G2
FULL
1.0.8.6
20.01.2022
exe
111289.67 KB
SMALL
1.0.8.6
20.01.2022
exe
29307.84 KB
V 010513
15.10.2021
zip
1087.29 KB
Runtime Software
Firmware
2787-2348, Stromver
sorgung; Pro 2
1 Compatible Products
1.1 Optional Accessories
1.1.1 Cables and connectors
Page 4/6
Version 11.02.2023
1.1.1.1 Communication cable
Item No.: 750-923/000-001
Configuration cable; USB connector;
Length: 5 m
1.1.2 Communication
1.1.2.1 Communication cable
Item No.: 750-923
Length: 2.5 m
1.1.2.2 Communication module
Item No.: 2789-9023
Communication module; EtherNet/IP;
Item No.: 2789-9080
Communication module; IO-Link; commu
nication capability
Item No.: 2789-9015
Communication module; Modbus RTU;
RJ45; communication capability
Item No.: 2789-9052
Communication module; Modbus TCP;
1.1.3 Marking
1.1.3.1 Marker
Item No.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces
on roll; stretchable 5 - 5.2 mm; plain; snapon type; white
1.1.3.2 Marker carrier
Item No.: 2789-1233
Marker carrier; for WMB or marking strips;
Length: 33 mm
1.1.3.3 Marking strip
Item No.: 2009-110
Marking strips; for Smart Printer; on reel;
not stretchable; plain; snap-on type; white
1.1.4 Tool
Page 5/6
Version 11.02.2023
1.1.4.1 Operating tool
Item No.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a
partially insulated shaft; multicoloured
Item No.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a
Subject to changes. Please also observe the further product documentation!
Current addresses can be found at:: w w w.wago.com
Page 6/6
Version 11.02.2023
很抱歉,暂时无法提供与“2787-2348”相匹配的价格&库存,您可以联系我们找货
