Data sheet | Item number: 862-8693
4-conductor chassis-mount terminal strip; with ground contact; N-PE-L1; 3pole; 4 mm²; 4,00 mm²; white
www.wago.com/862-8693
Dimensions in mm
Dimensions in mm
for chassis-mount terminal strips
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/9
Dimensions in mm
for GND contact and snap-in mounting foot (Ø 5.2 mm)
Data
Electrical data
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
32 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
12
Total number of potentials
3
Ground function
with ground contact
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Push-button
Connectable conductor materials
Copper
Solid conductor
0.5 … 4 mm² / 20 … 12 AWG
Solid conductor; push-in termination
0.75 … 4 mm² / 18 … 12 AWG
Stranded conductor
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor; with ferrule; push-in termination
0.75 mm² / 18 AWG
Hansastr. 27
32423 Minden
07.10.2021 Page 2/9
0.75 mm² / 18 AWG
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross-section can also be inserted via push-in termination.
Strip length
10 … 11 mm / 0.39 … 0.43 inch
Pole No.
3
Wiring direction
Side-entry wiring
Physical data
Pin spacing
12 mm / 0.472 inch
Width
36 mm / 1.417 inch
Height from the surface
22.3 mm / 0.878 inch
Depth
35 mm / 1.378 inch
Mechanical data
Marking
N-⏚-L1
Mounting type
Snap-in foot at pos. 1+3
Material data
Color
white
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.322 MJ
Weight
21.2 g
Commercial data
PU (SPU)
250 Stück
Packaging type
bag
Country of origin
DE
GTIN
4044918510769
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
Certificate
name
NTR NL
6912
Hansastr. 27
32423 Minden
07.10.2021 Page 3/9
CCA
EN 60947
2146425.01
CSA
C22.2 No. 158
1505030
ENEC 15
UL International Germany GmbH
EN 60998
143856-01
Approval
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
UL-Approvals
Logo
Approval
Certificate
name
UL
UL 1059
E45172
Optional accessories
Marking accessories
Marking strip
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Hansastr. 27
32423 Minden
07.10.2021 Page 4/9
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent
www.wago.com/709-177
Ferrule
Ferrule
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 862-482
Jumper; for conductor entry; insulated; black
www.wago.com/862-482
Jumpers
Jumper
Tool
Operating tool
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Testing and measuring
Testing accessories
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Hansastr. 27
32423 Minden
07.10.2021 Page 5/9
Downloads
Documentation
Bid Text
862-8693
Feb 19, 2019
xml
3.7 kB
Download
Jun 13, 2017
doc
25.1 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
WSCAD Universe 862-8693
URL
Download
ZUKEN Portal 862-8693
URL
Download
EPLAN Data Portal 862-8693
URL
Download
URL
Download
X81 - Datei
862-8693
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 862-8693
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 862-8693
4-conductor chassis-mount terminal strip; with ground contact; N-PE-L1; 3-pole; 4
Installation Notes
Hansastr. 27
32423 Minden
07.10.2021 Page 6/9
Cost-effective features:
WAGO's 862 Series Chassis-Mount Terminal
Strips were developed specifically to
minimize wiring costs, while accommodating
requirements for flexible mounting, multiple
connection points and easy usage:
Equipped with Push-in CAGE
CLAMP®, the 862 Series connects
up to four conductors sized 0.5 to
4 mm² (20 … 12 AWG). Due to
multiple connection points per pole,
different conductor sizes can be
used within the same terminal block
position.
For factory wiring, Push-in CAGE
CLAMP® Connection Technology
allows solid conductors, finestranded conductors with ferrules or
ultrasonically bonded conductors
from 0.5 … 4 mm² (20 … 12 AWG) to
be terminated by simply pushing
them into unit (length of bonded
conductor end: min. 10 mm).
Convenient automatic grounding
contact (optional)
Snap-in mounting feet for fast
assembly
Push-buttons for easy installation
with an operating tool or by hand
Built-in test points simplify testing
with 2 mm Ø test plug
Standard marking for each pole, or
custom marking for large orders
Conductor termination
Hansastr. 27
32423 Minden
07.10.2021 Page 7/9
Terminating four conductors per pole – solid
and fine-stranded.
Inserting a conductor via push-button.
Commoning
Commoning using a comb-style jumper bar
(862‑482).
Testing
Testing with a 2 mm Ø test plug (max. 42 V).
Hansastr. 27
32423 Minden
07.10.2021 Page 8/9
Marking
Marking by direct, one-side printing and
marking strips
Hansastr. 27
32423 Minden
07.10.2021 Page 9/9
很抱歉,暂时无法提供与“862-8693”相匹配的价格&库存,您可以联系我们找货
