Plastic Push Pin Heat Sinks
960 Series
Wakefield-Vette’s 960 Series
Push Pin Heat Sinks have
plastic push pins that engage
with a hole in one application's
PCB design. The compression
spring presses the heatsink to
the device in which is being
cooled. Wakefield-Vette offers
a wide range of plastic push
pin sizes and footprints to
ensure the integrity of the PCB
contact PCB with optimal
cooling options.
Features & Benefits:
The 960 Series Push Pin Heat Sink
utilizes the plastic push pin offering
for any air flow conditions as it is
design in a cross-cut format. This
heat sink is ideal for many
industries including but not limited
to telecommunications, medical,
and military.
Wakefield-Vette’s 960 Series can be
modified to a customer’s
specification in addition to off the
shelf standard.
• Lightweight, Black Anodized, Cross Cut
Aluminum 6063
• Easy and Quick Attachment, Pre
Assembled Plastic Push Pin that have
flexible barb to engage precisely with the
PCB holes
• Compression Springs allow for a confident
grip to the PCB
• Heat Sink Design allows for all airflow
applications
Part Number Configurator:
Series Footprint Height Pin Location
960
Anodize
Interface Material
19
12
F (Front)
AB (Black)
0 (No)
21
15
S (Side)
A (No Anodize)
1 (Yes)
23
18
D (Diagonal)
27
21
29
23
31
28
33
19mm
Wakefield Part Number
Description
960-19-12-F-AB-0
HEATSINK 19X12MM FRONT PLASTIC PUSH PIN
Size (mm) Height (mm) Anodize Attachment Method Pin Location
19
12
Black
Push Pin
960-19-12-S-AB-0
HEATSINK 19X12MM SIDE PLASTIC PUSH PIN
19
12
Black
Push Pin
Sides
960-19-12-D-AB-0
HEATSINK 19X12MM DIAGONAL PLASTIC PUSH PIN
19
12
Black
Push Pin
Diagonal
960-19-15-F-AB-0
HEATSINK 19X15MM FRONT PLASTIC PUSH PIN
19
15
Black
Push Pin
Front
960-19-15-S-AB-0
HEATSINK 19X15MM SIDE PLASTIC PUSH PIN
19
15
Black
Push Pin
Sides
960-19-15-D-AB-0
HEATSINK 19X15MM DIAGONAL PLASTIC PUSH PIN
19
15
Black
Push Pin
Diagonal
960-19-18-F-AB-0
HEATSINK 19X18MM FRONT PLASTIC PUSH PIN
19
18
Black
Push Pin
Front
960-19-18-S-AB-0
HEATSINK 19X18MM SIDE PLASTIC PUSH PIN
19
18
Black
Push Pin
Sides
960-19-18-D-AB-0
HEATSINK 19X18MM DIAGONAL PLASTIC PUSH PIN
19
18
Black
Push Pin
Diagonal
960-19-21-F-AB-0
HEATSINK 19X21MM FRONT PLASTIC PUSH PIN
19
21
Black
Push Pin
Front
960-19-21-S-AB-0
HEATSINK 19X21MM SIDE PLASTIC PUSH PIN
19
21
Black
Push Pin
Sides
960-19-21-D-AB-0
HEATSINK 19X21MM DIAGONAL PLASTIC PUSH PIN
19
21
Black
Push Pin
Diagonal
960-19-23-F-AB-0
HEATSINK 19X23MM FRONT PLASTIC PUSH PIN
19
23
Black
Push Pin
Front
Front
960-19-23-S-AB-0
HEATSINK 19X23MM SIDE PLASTIC PUSH PIN
19
23
Black
Push Pin
Sides
960-19-23-D-AB-0
HEATSINK 19X23MM DIAGONAL PLASTIC PUSH PIN
19
23
Black
Push Pin
Diagonal
960-19-28-F-AB-0
HEATSINK 19X28MM FRONT PLASTIC PUSH PIN
19
28
Black
Push Pin
Front
960-19-28-S-AB-0
HEATSINK 19X28MM SIDE PLASTIC PUSH PIN
19
28
Black
Push Pin
Sides
960-19-28-D-AB-0
HEATSINK 19X28MM DIAGONAL PLASTIC PUSH PIN
19
28
Black
Push Pin
Diagonal
960-19-33-F-AB-0
HEATSINK 19X33MM FRONT PLASTIC PUSH PIN
19
33
Black
Push Pin
Front
960-19-33-S-AB-0
HEATSINK 19X33MM SIDE PLASTIC PUSH PIN
19
33
Black
Push Pin
Sides
960-19-33-D-AB-0
HEATSINK 19X33MM DIAGONAL PLASTIC PUSH PIN
19
33
Black
Push Pin
Diagonal
Front Pins
Side Pins
Diagonal Pins
19mm
Thermal Performance Based on Height
19x19 Push Pin BGA Heatsinks
9
Thermal Resistance (C/W)
8
7
12
15
6
18
21
5
23
28
4
31
3
2
200
250
300
350
400
Airflow (LFM)
450
500
550
600
21mm
Description
960-21-12-F-AB-0
HEATSINK 21X12MM FRONT PLASTIC PUSH PIN
21
12
Black
Push Pin
Front
960-21-12-S-AB-0
HEATSINK 21X12MM SIDE PLASTIC PUSH PIN
21
12
Black
Push Pin
Sides
960-21-12-D-AB-0
HEATSINK 21X12MM DIAGONAL PLASTIC PUSH PIN
21
12
Black
Push Pin
Diagonal
960-21-15-F-AB-0
HEATSINK 21X15MM FRONT PLASTIC PUSH PIN
21
15
Black
Push Pin
Front
960-21-15-S-AB-0
HEATSINK 21X15MM SIDE PLASTIC PUSH PIN
21
15
Black
Push Pin
Sides
960-21-15-D-AB-0
HEATSINK 21X15MM DIAGONAL PLASTIC PUSH PIN
21
15
Black
Push Pin
Diagonal
960-21-18-F-AB-0
HEATSINK 21X18MM FRONT PLASTIC PUSH PIN
21
18
Black
Push Pin
Front
960-21-18-S-AB-0
HEATSINK 21X18MM SIDE PLASTIC PUSH PIN
21
18
Black
Push Pin
Sides
960-21-18-D-AB-0
HEATSINK 21X18MM DIAGONAL PLASTIC PUSH PIN
21
18
Black
Push Pin
Diagonal
960-21-21-F-AB-0
HEATSINK 21X21MM FRONT PLASTIC PUSH PIN
21
21
Black
Push Pin
Front
960-21-21-S-AB-0
HEATSINK 21X21MM SIDE PLASTIC PUSH PIN
21
21
Black
Push Pin
Sides
960-21-21-D-AB-0
HEATSINK 21X21MM DIAGONAL PLASTIC PUSH PIN
21
21
Black
Push Pin
Diagonal
960-21-23-F-AB-0
HEATSINK 21X23MM FRONT PLASTIC PUSH PIN
21
23
Black
Push Pin
Front
960-21-23-S-AB-0
HEATSINK 21X23MM SIDE PLASTIC PUSH PIN
21
23
Black
Push Pin
Sides
960-21-23-D-AB-0
HEATSINK 21X23MM DIAGONAL PLASTIC PUSH PIN
21
23
Black
Push Pin
Diagonal
960-21-28-F-AB-0
HEATSINK 21X28MM FRONT PLASTIC PUSH PIN
21
28
Black
Push Pin
Front
960-21-28-S-AB-0
HEATSINK 21X28MM SIDE PLASTIC PUSH PIN
21
28
Black
Push Pin
Sides
960-21-28-D-AB-0
HEATSINK 21X28MM DIAGONAL PLASTIC PUSH PIN
21
28
Black
Push Pin
Diagonal
960-21-33-F-AB-0
HEATSINK 21X33MM FRONT PLASTIC PUSH PIN
21
33
Black
Push Pin
Front
960-21-33-S-AB-0
HEATSINK 21X33MM SIDE PLASTIC PUSH PIN
21
33
Black
Push Pin
Sides
960-21-33-D-AB-0
HEATSINK 21X33MM DIAGONAL PLASTIC PUSH PIN
21
33
Black
Push Pin
Diagonal
Front Pins
Side Pins
Diagonal Pins
21mm
21x21 Push Pin BGA Heatsinks
8
7
6
12
15
18
5
21
23
4
28
33
3
2
200
250
300
350
400
Airflow (LFM)
450
500
550
600
23mm
Description
960-23-12-F-AB-0
HEATSINK 23X12MM FRONT PLASTIC PUSH PIN
23
12
Black
Push Pin
Front
960-23-12-S-AB-0
HEATSINK 23X12MM SIDE PLASTIC PUSH PIN
23
12
Black
Push Pin
Sides
960-23-12-D-AB-0
HEATSINK 23X12MM DIAGONAL PLASTIC PUSH PIN
23
12
Black
Push Pin
Diagonal
960-23-15-F-AB-0
HEATSINK 23X15MM FRONT PLASTIC PUSH PIN
23
15
Black
Push Pin
Front
960-23-15-S-AB-0
HEATSINK 23X15MM SIDE PLASTIC PUSH PIN
23
15
Black
Push Pin
Sides
960-23-15-D-AB-0
HEATSINK 23X15MM DIAGONAL PLASTIC PUSH PIN
23
15
Black
Push Pin
Diagonal
960-23-18-F-AB-0
HEATSINK 23X18MM FRONT PLASTIC PUSH PIN
23
18
Black
Push Pin
Front
960-23-18-S-AB-0
HEATSINK 23X18MM SIDE PLASTIC PUSH PIN
23
18
Black
Push Pin
Sides
960-23-18-D-AB-0
HEATSINK 23X18MM DIAGONAL PLASTIC PUSH PIN
23
18
Black
Push Pin
Diagonal
960-23-21-F-AB-0
HEATSINK 23X21MM FRONT PLASTIC PUSH PIN
23
21
Black
Push Pin
Front
960-23-21-S-AB-0
HEATSINK 23X21MM SIDE PLASTIC PUSH PIN
23
21
Black
Push Pin
Sides
960-23-21-D-AB-0
HEATSINK 23X21MM DIAGONAL PLASTIC PUSH PIN
23
21
Black
Push Pin
Diagonal
960-23-23-F-AB-0
HEATSINK 23X23MM FRONT PLASTIC PUSH PIN
23
23
Black
Push Pin
Front
960-23-23-S-AB-0
HEATSINK 23X23MM SIDE PLASTIC PUSH PIN
23
23
Black
Push Pin
Sides
960-23-23-D-AB-0
HEATSINK 23X23MM DIAGONAL PLASTIC PUSH PIN
23
23
Black
Push Pin
Diagonal
960-23-28-F-AB-0
HEATSINK 23X28MM FRONT PLASTIC PUSH PIN
23
28
Black
Push Pin
Front
960-23-28-S-AB-0
HEATSINK 23X28MM SIDE PLASTIC PUSH PIN
23
28
Black
Push Pin
Sides
960-23-28-D-AB-0
HEATSINK 23X28MM DIAGONAL PLASTIC PUSH PIN
23
28
Black
Push Pin
Diagonal
960-23-33-F-AB-0
HEATSINK 23X33MM FRONT PLASTIC PUSH PIN
23
33
Black
Push Pin
Front
960-23-33-S-AB-0
HEATSINK 23X33MM SIDE PLASTIC PUSH PIN
23
33
Black
Push Pin
Sides
960-23-33-D-AB-0
HEATSINK 23X33MM DIAGONAL PLASTIC PUSH PIN
23
33
Black
Push Pin
Diagonal
Front Pins
Side Pins
Diagonal Pins
23mm
23x23 Push Pin BGA Heatsinks
7
6
5
12
15
18
4
21
23
3
28
33
2
1
200
250
300
350
400
Airflow (LFM)
450
500
550
600
27mm
Description
960-27-12-F-AB-0
HEATSINK 27X12MM FRONT PLASTIC PUSH PIN
27
12
Black
Push Pin
960-27-12-S-AB-0
HEATSINK 27X12MM SIDE PLASTIC PUSH PIN
27
12
Black
Push Pin
Sides
960-27-12-D-AB-0
HEATSINK 27X12MM DIAGONAL PLASTIC PUSH PIN
27
12
Black
Push Pin
Diagonal
960-27-15-F-AB-0
HEATSINK 27X15MM FRONT PLASTIC PUSH PIN
27
15
Black
Push Pin
Front
960-27-15-S-AB-0
HEATSINK 27X15MM SIDE PLASTIC PUSH PIN
27
15
Black
Push Pin
Sides
960-27-15-D-AB-0
HEATSINK 27X15MM DIAGONAL PLASTIC PUSH PIN
27
15
Black
Push Pin
Diagonal
960-27-18-F-AB-0
HEATSINK 27X18MM FRONT PLASTIC PUSH PIN
27
18
Black
Push Pin
Front
960-27-18-S-AB-0
HEATSINK 27X18MM SIDE PLASTIC PUSH PIN
27
18
Black
Push Pin
Sides
960-27-18-D-AB-0
HEATSINK 27X18MM DIAGONAL PLASTIC PUSH PIN
27
18
Black
Push Pin
Diagonal
960-27-21-F-AB-0
HEATSINK 27X21MM FRONT PLASTIC PUSH PIN
27
21
Black
Push Pin
Front
Front
960-27-21-S-AB-0
HEATSINK 27X21MM SIDE PLASTIC PUSH PIN
27
21
Black
Push Pin
Sides
960-27-21-D-AB-0
HEATSINK 27X21MM DIAGONAL PLASTIC PUSH PIN
27
21
Black
Push Pin
Diagonal
960-27-23-F-AB-0
HEATSINK 27X23MM FRONT PLASTIC PUSH PIN
27
23
Black
Push Pin
Front
960-27-23-S-AB-0
HEATSINK 27X23MM SIDE PLASTIC PUSH PIN
27
23
Black
Push Pin
Sides
960-27-23-D-AB-0
HEATSINK 27X23MM DIAGONAL PLASTIC PUSH PIN
27
23
Black
Push Pin
Diagonal
960-27-28-F-AB-0
HEATSINK 27X28MM FRONT PLASTIC PUSH PIN
27
28
Black
Push Pin
Front
960-27-28-S-AB-0
HEATSINK 27X28MM SIDE PLASTIC PUSH PIN
27
28
Black
Push Pin
Sides
960-27-28-D-AB-0
HEATSINK 27X28MM DIAGONAL PLASTIC PUSH PIN
27
28
Black
Push Pin
Diagonal
960-27-33-F-AB-0
HEATSINK 27X33MM FRONT PLASTIC PUSH PIN
27
33
Black
Push Pin
Front
960-27-33-S-AB-0
HEATSINK 27X33MM SIDE PLASTIC PUSH PIN
27
33
Black
Push Pin
Sides
960-27-33-D-AB-0
HEATSINK 27X33MM DIAGONAL PLASTIC PUSH PIN
27
33
Black
Push Pin
Diagonal
Front Pins
Side Pins
Diagonal Pins
27mm
27x27 Push Pin BGA Heatsinks
6.0
5.5
5.0
4.5
12
4.0
15
18
3.5
21
3.0
23
28
2.5
33
2.0
1.5
1.0
200
250
300
350
400
Airflow (LFM)
450
500
550
600
29mm
Description
960-29-12-F-AB-0
HEATSINK 29X12MM FRONT PLASTIC PUSH PIN
29
12
Black
Push Pin
960-29-12-S-AB-0
HEATSINK 29X12MM SIDE PLASTIC PUSH PIN
29
12
Black
Push Pin
Sides
960-29-12-D-AB-0
HEATSINK 29X12MM DIAGONAL PLASTIC PUSH PIN
29
12
Black
Push Pin
Diagonal
960-29-15-F-AB-0
HEATSINK 29X15MM FRONT PLASTIC PUSH PIN
29
15
Black
Push Pin
Front
960-29-15-S-AB-0
HEATSINK 29X15MM SIDE PLASTIC PUSH PIN
29
15
Black
Push Pin
Sides
960-29-15-D-AB-0
HEATSINK 29X15MM DIAGONAL PLASTIC PUSH PIN
29
15
Black
Push Pin
Diagonal
960-29-18-F-AB-0
HEATSINK 29X18MM FRONT PLASTIC PUSH PIN
29
18
Black
Push Pin
Front
960-29-18-S-AB-0
HEATSINK 29X18MM SIDE PLASTIC PUSH PIN
29
18
Black
Push Pin
Sides
960-29-18-D-AB-0
HEATSINK 29X18MM DIAGONAL PLASTIC PUSH PIN
29
18
Black
Push Pin
Diagonal
960-29-21-F-AB-0
HEATSINK 29X21MM FRONT PLASTIC PUSH PIN
29
21
Black
Push Pin
Front
Front
960-29-21-S-AB-0
HEATSINK 29X21MM SIDE PLASTIC PUSH PIN
29
21
Black
Push Pin
Sides
960-29-21-D-AB-0
HEATSINK 29X21MM DIAGONAL PLASTIC PUSH PIN
29
21
Black
Push Pin
Diagonal
960-29-23-F-AB-0
HEATSINK 29X23MM FRONT PLASTIC PUSH PIN
29
23
Black
Push Pin
Front
960-29-23-S-AB-0
HEATSINK 29X23MM SIDE PLASTIC PUSH PIN
29
23
Black
Push Pin
Sides
960-29-23-D-AB-0
HEATSINK 29X23MM DIAGONAL PLASTIC PUSH PIN
29
23
Black
Push Pin
Diagonal
960-29-28-F-AB-0
HEATSINK 29X28MM FRONT PLASTIC PUSH PIN
29
28
Black
Push Pin
Front
960-29-28-S-AB-0
HEATSINK 29X28MM SIDE PLASTIC PUSH PIN
29
28
Black
Push Pin
Sides
960-29-28-D-AB-0
HEATSINK 29x28MM DIAGONAL PLASTIC PUSH PIN
29
28
Black
Push Pin
Diagonal
960-29-33-F-AB-0
HEATSINK 29X33MM FRONT PLASTIC PUSH PIN
29
33
Black
Push Pin
Front
960-29-33-S-AB-0
HEATSINK 29X33MM SIDE PLASTIC PUSH PIN
29
33
Black
Push Pin
Sides
960-29-33-D-AB-0
HEATSINK 29X33MM DIAGONAL PLASTIC PUSH PIN
29
33
Black
Push Pin
Diagonal
Front Pins
Side Pins
Diagonal Pins
29mm
29x29 Push Pin BGA Heatsinks
5.5
5.0
4.5
4.0
12
3.5
15
18
3.0
21
2.5
23
28
2.0
33
1.5
1.0
0.5
200
250
300
350
400
Airflow (LFM)
450
500
550
600
31mm
Description
960-31-12-F-AB-0
HEATSINK 31X12MM FRONT PLASTIC PUSH PIN
31
12
Black
Push Pin
Front
960-31-12-S-AB-0
HEATSINK 31X12MM SIDE PLASTIC PUSH PIN
31
12
Black
Push Pin
Sides
960-31-12-D-AB-0
HEATSINK 31X12MM DIAGONAL PLASTIC PUSH PIN
31
12
Black
Push Pin
Diagonal
960-31-15-F-AB-0
HEATSINK 31X15MM FRONT PLASTIC PUSH PIN
31
15
Black
Push Pin
Front
960-31-15-S-AB-0
HEATSINK 31X15MM SIDE PLASTIC PUSH PIN
31
15
Black
Push Pin
Sides
960-31-15-D-AB-0
HEATSINK 31X15MM DIAGONAL PLASTIC PUSH PIN
31
15
Black
Push Pin
Diagonal
960-31-18-F-AB-0
HEATSINK 31X18MM FRONT PLASTIC PUSH PIN
31
18
Black
Push Pin
Front
960-31-18-S-AB-0
HEATSINK 31X18MM SIDE PLASTIC PUSH PIN
31
18
Black
Push Pin
Sides
960-31-18-D-AB-0
HEATSINK 31X18MM DIAGONAL PLASTIC PUSH PIN
31
18
Black
Push Pin
Diagonal
960-31-21-F-AB-0
HEATSINK 31X21MM FRONT PLASTIC PUSH PIN
31
21
Black
Push Pin
Front
960-31-21-S-AB-0
HEATSINK 31X21MM SIDE PLASTIC PUSH PIN
31
21
Black
Push Pin
Sides
960-31-21-D-AB-0
HEATSINK 31X21MM DIAGONAL PLASTIC PUSH PIN
31
21
Black
Push Pin
Diagonal
960-31-23-F-AB-0
HEATSINK 31X23MM FRONT PLASTIC PUSH PIN
31
23
Black
Push Pin
Front
960-31-23-S-AB-0
HEATSINK 31X23MM SIDE PLASTIC PUSH PIN
31
23
Black
Push Pin
Sides
960-31-23-D-AB-0
HEATSINK 31X23MM DIAGONAL PLASTIC PUSH PIN
31
23
Black
Push Pin
Diagonal
960-31-28-F-AB-0
HEATSINK 31X28MM FRONT PLASTIC PUSH PIN
31
28
Black
Push Pin
Front
960-31-28-S-AB-0
HEATSINK 31X28MM SIDE PLASTIC PUSH PIN
31
28
Black
Push Pin
Sides
960-31-28-D-AB-0
HEATSINK 31X28MM DIAGONAL PLASTIC PUSH PIN
31
28
Black
Push Pin
Diagonal
960-31-33-F-AB-0
HEATSINK 31X33MM FRONT PLASTIC PUSH PIN
31
33
Black
Push Pin
Front
960-31-33-S-AB-0
HEATSINK 31X33MM SIDE PLASTIC PUSH PIN
31
33
Black
Push Pin
Sides
960-31-33-D-AB-0
HEATSINK 31X33MM DIAGONAL PLASTIC PUSH PIN
31
33
Black
Push Pin
Diagonal
Front Pins
Side Pins
Diagonal Pins
31mm
31x31 Push Pin BGA Heatsinks
5.5
5.0
4.5
4.0
12
3.5
15
18
3.0
21
2.5
23
28
2.0
33
1.5
1.0
0.5
200
250
300
350
400
Airflow (LFM)
450
500
550
600
很抱歉,暂时无法提供与“960-21-21-S-AB-0”相匹配的价格&库存,您可以联系我们找货
