HB-1250
HB-1250
    WAKEFIELD-VETTE
    ALVES ZERO BACKLASH U-JOINT
HB-1250 数据手册
Contact: Wakefield-Vette 33 Bridge St. Pelham, NH 03076 603-635-2800 info@Wakefield-Vette.com www.Wakefield-Vette.com Alves Blue Block Universal Joints… split block design makes the difference… Built Better and cost less… the ultimate products in motion linkage. All wear parts are heat treated for increased life. The split block design provides a positive lubrication reservoir for long life and low wear. The pins move resistance free within the bushings, while the bushings remained fixed with the yokes. Standard joints produced from high- grade alloy steel for extra durability and each part of the same joint is completely interchangeable. All parts are produced to extremely close tolerances, and fitted exactly to meet the most rigid backlash requirements. The Blue Block design is available in stainless steel, with keyways and with many custom configurations. Protective coverings are also available for use in contaminated atmospheres. Single Joints SPECIFICATIONS OF STANDARD JOINTS CAT CAT A NO NO O.D. B D D C APPROX STATIC HOLE WEIGHT BREAKING SOLID BORED 0 0.002 HUBS HUBS -0.015 +- 1/32 -0.001 0.002 DEPTH LBS -0.001 x BS-375 BB-375 3/8 1-3/4 3/16 1/4 19/32 LENGTH BORE MAX BORE TORQUE INCH/LBS .09 150 BS-500 BB-500 1/2 2 1/4 3/8 19/32 .12 410 BS-625 BB-625 5/8 2-1/4 5/16 1/2 23/32 .25 890 BS-750 BB-750 3/4 2-11/16 3/8 5/8 7/8 0.31 1,500 BS-875 BB-875 7/8 3 7/16 11/16 1 0.5 1,650 BS-1000 BB-1000 1 3-3/3 1/2 3/4 1-1/8 0.62 3,000 BS-1125 BB-1125 1-1/8 3-1/2 9/16 7/8 1-1/8 0.87 3,500 BS-1250 BB1520 1-1/4 3-3/4 5/8 1 1-1/8 1.13 5,400 BS-1500 BB-1500 1-1/2 4-1/4 3/4 1-1/8 1-1/8 1.75 8,800 BS-1750 BB-1750 1-3/4 5 7/8 1-1/4 1-7/16 2.93 14,500 ABOVE JOINTS DO NOT HAVE BEARINGS Note how the unique construction of the split block forms a lubrication chamber. The oil enters through the oil hole in one pin and into the reservoir. As the speed is increased, oil is thrown centrifugally to thoroughly lubricate each pin and bushing. BS-2000 BB-2000 2 6 1 1-1/2 1-13/16 4.5 22,000 BS-2500 BB-2500 2-1/2 7 1-1/4 1 3/4 1-7/8 7.25 31,500 BS3000 BB-3000 3 9 1-1/2 2 2-15/16 15.5 55,000 BS-4000 BB-4000 4 10-5/8 2 2-1/2 3-1/2 35.5 127,000 OUBLE U-JOINTS FOR MORE ANGULAR FLEXIBILITY AVAILABLE IN ABOVE SIZES Repair Kits Alves on site repair kits can be used to repair any size Blue Block U-Joint, Each kit contains (4) bushings, (3) solid bushing pins, (1) oilier bushing pin, (2) centering blocks, (1) nut and (1) bolt Alves Solid Block Universal Joints Standard pin and block type manufactured from high-grade alloy steel for extra durability, strength and long life. Ideal for angles up to 25 degrees and speeds to 1750 rpm. Available for greater angles and higher speeds; with heat-treated yokes and matched components for heavy-duty applications; and with round, hex, splined, or keyway bores. Also available in stainless steel alloys, bronze and other materials for corrosive, sanitation or similar applications. Single Joints Specifications Of Standard Joints CAT CAT A B D D C NO NO O.D. LENGTH BORE MAX BORE HOLE APPROX STATIC SOLID BORED 0 0.002 0.002 DEPTH WEIGHT TORQUE HUBS HUBS -0.015 -0.001 -0.001 0.03125 LBS INCH/LBS SS-375 SB-375 3/8 1-3/1 3/16 1/1 19/32 0.09 150 SS-500 SB-500 1/2 2 1/4 3/8 19/32 0.12 410 SS-625 SB-625 5/8 2-1/4 5/16 1/2 23/32 0.25 890 SS-750 SB-750 3/4 2-11/16 3/8 5/8 7/8 0.31 1,500 SS-875 SB-875 7/8 3 7/16 11/16 1 0.5 1,650 SS-1000 SB-1000 1 3-3/8 1/2 3/4 1-1/8 0.62 3,000 BREAKING SS-1125 SB-1 25 1-1/8 3-1/2 9/16 7/8 1-1/8 0.87 3,500 SS-1250 SB-1250 1-1/4 3-3/4 5/8 1 1-1/8 1.13 5,400 SS-1500 SB-1500 1-1/2 4-1/4 3/4 1-1/8 1-1/8 1.75 8,800 SS-1750 SB-1750 1-3/4 5 7/8 1-1/4 1-7/16 2.93 14,500 SS-2000 SB-2000 2 6 1 1-1/2 1-13/16 4.5 22,000 SS-2500 SB-2500 2-1/2 7 1-1/4 1-3/4 1-7/8 7.25 31,500 SS-3000 SB-3000 3 9 1-1/2 2 2-15/16 15.5 55,000 SS-4000 SB-4000 4 10-5/8 2 2-1/2 3-1/2 35.5 127,000 DOUBLE U JOINTS FOR MORE ANGULAR FLEXIBILITY AVAILABLE IN BOTH SIZES Alves “Double” Universal Joints SINGLE JOINTS Connects two Blue Block, Hex Block or Solid Block Joints to compensate for shaft separation and parallel misalignment. Available with round hex, splined or keyway bores. Catalog numbers in table are for Blue Block style, Butt type. Consult factory for Hex and Solid Block styles, Shaft and Center Types, and for spring loaded assemblies, such as those used for multi-spindle drills. SPECIFICATIONS OF STANDARD JOINTS CAT CAT A B D DEPTH C APPROX NO NO O.D. LENGTH BORE MAX HOLE WEIGHT SOLID BORED +.000 +.002 BORE DEPTH LBS HUBS HUBS -0.015 + 1/32 -.001 +.002 + 1/32 BS-375 -D BB-375 -D 3/8 3-1/2 3/16 1/4 19/32 .13 BS-500 -D BB-500 -D 1/2 4 1/4 3/8 19/32 .20 BS-625 -D BB-625 -D 5/8 4-1/2 1/2 1/2 23/32 .40 ABOVE JOINTS DO NOT HAVE BEARINGS BS-750 -D BB-750-D 3/4 5-3/8 3/8 5/8 7/8 .56 BS-875 -D BB-875-D 7/8 6 7/16 11/16 1 .87 BS-1000-D BB-1000-D 1 6-3/4 1/2 3/4 1-1/8 1.17 BS-1125-D BB-1125-D 1-1/8 7 9/16 7/8 1-1/8 1.58 BS-1250D BB-1250-D 1-1/4 7-1/2 5/8 1 1-1/8 2.07 BS-1500-D BB-1500-D 1-1/2 8-1/2 3/4 1-1/8 1-1/8 3.25 BS-1750-D BB-1750-D 1-3/4 10 7/8 1-1/4 1-7/16 5.43 BS-2000-D BB-2000-D 2 12 1 1-1/2 1-13/16 8.00 BS-2500-D BB-2500-D 2-1/2 14 1-1/4 1-0/4 1-7/8 14.45 BS-3000-D BB-3000-D 3 18 1-1/22 2 2-15/16 28.50 BS-4000-D BB-4000-D 4 21-1/4 2 2-1/2 3-1/2 63.00 Note: Both input and output speeds are near constant velocity. Alves Low Cost, Self Lubricating, Hex Block Universal Joint SINGLE JOINTS SPECIFICATIONS OF STANDARD CAT CAT A B D D C NO NO O.D LENGTH BORE MAX BORE HOLE SOLID BORED 0 0.002 0.002 DEPTH HUBS HUBS -0.015 + 1/32 -0.001 -0.001 + 1/32 SOLID BORED HS-625 HB-625 5/8 2-1/4 5/16 1/2 51/64 19 15 HS-750 HB-750 3/4 2-11/16 3/8 5/8 31/32 31 25 APPROX WEIGHT IN LBS HS-875 HB-875 7/8 3 7/16 11-16 1- 5/64 46 32 HS-1000 HB-1000 1 3-3/8 1/2 3/4 1- 11/16 67 61 HS-1250 HB-1250 1-1/4 3-3/4 5/8 1 2- 1/4 1.17 90 DOUBLE U-JOINTS FOR MORE ANGULAR FLEXIBILITY AVAILABLE IN ABOVE SIZES An inexpensive riveted joint, designed for low torque…manual, intermittent or light duty. Unique center block is produced from out own proprietary powdered metal formulation and sintering process. With its own selfcontained oil supply the block not only acts as a carrying member for the cross-pins, but are also as a continuous lubricates bearing block. As a result, the Hex Block Joint lasts longer than other comparable units and is ideal for applications where oiling is required but impractical because of the universal joint location. Maximum operating angle on standard models is 35 degrees. Hex Block Joints can be special ordered for greater angles and other characteristics. Alves Needle Bearing Universal Joints SINGLE JOINTS Boot Kits SPECIFICATIONS OF STANDARD JOINTS CAT CAT A B D D C NO NO O.D LENGTH BORE MAX BORE HOLE SOLID BORED 0 0.002 0.002 DEPTH SWING WEIGHT HUBS HUBS -0.015 + 1/32 -0.001 -0.001 + 1/32 DIA LBS APPROX BS-750-N BB-750-N 3/4 2-1/4 5/16 1/2 51/64 7/8 15 BS-1000-N BB-1000-N 1 2-11/16 3/8 5/8 31/32 1-1/8 25 BS-1250-N BB-1250-N 1-1/4 3 7/16 11/16 1-5/64 1-1/8 32 BS-1500-N BB-1500-N 1-1/2 3-3/8 1/2 3/4 1-13/64 1-1/8 61 BS-2000-N BB-2000-N 2 3/4 5/8 1 1-7/32 1-13/16 90 These are the only repairable needle bearing joints on the market. Using the Alves Blue Block design, with modified and special hardened pins, and the highest quality pre-lubricated and sealed needle bearings in the hubs, they are easily repaired on site using the inexpensive special repair kit available from your local distributor, or from Alves direct. They are physically interchangeable with competing units and provide the precision and reliability required for demanding applications requiring speeds to 6,000 rpm and operating angles to 25 degrees. Greater angular operation can be achieved by utilizing a double universal joint. Protects joints from dirt and contaminants. Adds lubrication capacity, quickly and easily replaced in the field. Plastic straps standard. Stainless steel straps available. BOOT NO. U-Joint Std. Boot 375- Boot 3/8 1-1/32 500- Boot 1/2 1-1/4 625- Boot 5/8 1-1/2 750- Boot 3/4 1-3/4 875- Boot 7/8 2 1000- Boot 1 2-9/32 1125- Boot 1-1/8 2-9/16 1250- Boot 1-1/4 2-7/8 1500- Boot 1-1/2 3-1/4 1750- Boot 1-3/4 3-5/8 2000- Boot 2 4-17/32 2500- Boot 2-1/2 3000- Boot 3 4000- Boot 4 Universal Joint Cross Reference Guide Custom Universal Joint Drawings BB-1250-032-01A BB-1250-276-01A BB-1250-032-03A BB-1250-276-02A Custom Universal Joint Drawings BB-1250-010-02A BB-1250 BB-1000 BS-1250
HB-1250 价格&库存
很抱歉,暂时无法提供与“HB-1250”相匹配的价格&库存,您可以联系我们找货
