Liquid Cooling- Connectors
LP4C Series
Wakefield- Vette’s LP4C Series quick disconnect couplings provide
ultra-reliable, dripless connections and disconnections that protect
valuable electronics. Designed specifically for liquid cooling
applications, LP4C utilizes patent-pending valve technology that
eliminates drips and can withstand long-term use.
Specifications:
PRESSURE:
Vacuum to 120 psi, 8.3 bar
TEMPERATURE:
0°F to 240°F (-17°C to 115°C)
MAXIMUM FLOW AT DISCONNECT:
3.0 gal/min, 11.3L/min
MATERIALS:
Main housing components: Chrome-plated brass
Valves and thumb latch: Polysulfone
Valve spring (wetted): Stainless steel
External spring: Stainless steel
Seals: EPDM
COLOR:
Chrome with Cool Blue or Warm Red
TUBING SIZES:
1/4" to 3/8" ID, 6.4mm to 9.5mm ID
LUBRICANTS:
Krytox® PFPE
SPILLAGE:
0.025 cc per disconnect rated at 0 psi
0.055 cc per disconnect rated at 120 psi
INCLUSION:
0.025 cc per connect
WARNING: Pressure, temperature, chemicals, and operating
environment can affect the performance of couplings. It is
the customer’s responsibility to test the suitability of WakefieldVette’s products in their own application conditions
FEATURES & BENEFITS
• Non-spill design- Disconnect under
pressure with no spills
• Redundant sealing when connectedExtra protection from leaks
• Color-coding- Instant visual difference
in cooling lines
• Friction-free valve- Valving system
designed for extended periods in
connected state
• Ruggedness- Able to withstand longterm, repeated use
• Rotation allows movement- Eliminates
tube kinking
Performance:
www.wakefield-vette.com
LP4C Series
Coupling Bodies- Chrome Plated Brass:
WKV Vette Part
Number
LP4C-25-B-F-B
LP4C-25-B-F-R
LP4C-38-B-F-B
LP4C-38-B-F-R
LP4C-25-SAE-F-B
LP4C-25-SAE-F-R
LP4C-38-SAE-F-B
LP4C-38-SAE-F-R
Description
Liquid Connector 1/4 HB Valved InLine Body - Blue
Liquid Connector 1/4 HB Valved InLine Body - Red
Liquid Connector 3/8 HB Valved InLine Body - Blue
Liquid Connector 3/8 HB Valved InLine Body - Red
Liquid Connector 1/4 SAE Valved
In-Line Body - Blue
In-Line Body - Red
Liquid Connector 3/8 SAE Valved
In-Line Body - Blue
In-Line Body - Red
LP4C
Tubing/Thread Height Length
ID (inches)
(Inches) (Inches) Connector Type
In Line Hose
0.25
0.98
2.49
Barb
In Line Hose
0.25
0.98
2.49
Barb
In Line Hose
0.38
0.98
2.49
Barb
In Line Hose
0.38
0.98
2.49
Barb
In Line Thread
0.25
0.98
2.29
Port SAE
In Line Thread
0.25
0.98
2.29
Port SAE
In Line Thread
0.38
0.98
2.29
Port SAE
In Line Thread
0.38
0.98
2.29
Port SAE
Series
Tubing/Thread
ID (inches)
Height
(Inches)
LP4C
0.25
0.74
LP4C
0.25
0.74
LP4C
0.38
0.74
Series
LP4C
LP4C
LP4C
LP4C
LP4C
LP4C
LP4C
Body
Type
Color
Female
Blue
Female
Red
Female
Blue
Female
Red
Female
Blue
Female
Red
Female
Blue
Female
Red
Body
Type
Color
Male
Blue
Male
Red
Male
Blue
Male
Red
Male
Blue
Male
Red
Male
Blue
Male
Red
Coupling Inserts- Chrome Plated Brass:
WKV Vette Part
Number
Length Connector
(Inches)
Type
In Line Hose
2.22
Barb
In Line Hose
Barb
2.22
In Line Hose
2.22
Barb
LP4C-38-B-M-B
Description
Valved In-Line Insert - Blue
Valved In-Line Insert - Red
LP4C-38-B-M-R
LP4C
0.38
0.74
2.22
LP4C-25-SAE-M-B
LP4C
0.25
0.8
2.02
LP4C-25-SAE-M-R
LP4C
0.25
0.8
2.02
LP4C-38-SAE-M-B
LP4C
0.38
0.8
2.02
LP4C-38-SAE-M-R
LP4C
0.38
0.8
2.02
LP4C-25-B-M-B
LP4C-25-B-M-R
In Line Hose
Barb
In Line
Thread Port
SAE
In Line
Thread Port
SAE
In Line
Thread Port
SAE
In Line
Thread Port
SAE
很抱歉,暂时无法提供与“LP4C-25-SAE-F-B”相匹配的价格&库存,您可以联系我们找货
