Liquid Cooling- Connectors
LP6C Series
Wakefield- Vette’s LP6C Series quick disconnect couplings provide
ultra-reliable, dripless connections and disconnections that protect
valuable electronics. Designed specifically for liquid cooling
applications, LP6C utilizes patent-pending valve technology that
eliminates drips and can withstand long-term use.
Specifications:
PRESSURE:
Vacuum to 120 psi, 8.3 bar
TEMPERATURE:
0°F to 240°F (-17°C to 115°C)
MAXIMUM FLOW AT DISCONNECT:
4.0 gal/min, 15.1L/min
MATERIALS:
Main housing components: Chrome-plated brass
Valves and thumb latch: Polysulfone
Valve spring (wetted): Stainless steel
External spring: Stainless steel
Seals: EPDM
COLOR:
Chrome with Cool Blue or Warm Red
TUBING SIZES:
3/8" to 1/2" ID, 9.5mm to 12.7mm ID
LUBRICANTS:
Krytox® PFPE
SPILLAGE:
0.05 cc per disconnect rated at 0 psi
0.125 cc per disconnect rated at 120 psi
INCLUSION:
0.42 cc per connect
WARNING: Pressure, temperature, chemicals, and operating
environment can affect the performance of couplings. It is
the customer’s responsibility to test the suitability of WakefieldVette’s products in their own application conditions
FEATURES & BENEFITS
• Non-spill design- Disconnect under
pressure with no spills
• Redundant sealing when connectedExtra protection from leaks
• Color-coding- Instant visual difference
in cooling lines
• Friction-free valve- Valving system
designed for extended periods in
connected state
• Ruggedness- Able to withstand longterm, repeated use
• Rotation allows movement- Eliminates
tube kinking
Performance:
www.wakefield-vette.com
LP6C Series
Coupling Bodies- Chrome Plated Brass:
WKV Vette Part
Number
Description
Series
Tubing/Thread
ID (inches)
Height
(Inches)
Length
(Inches)
Connector Type
Body
Type
Color
LP6C-38-B-F-B
Liquid Connector 3/8 HB Valved In-Line Body - Blue LP6C
0.38
1.185
2.73
In Line Hose Barb
Female
Blue
LP6C-38-B-F-R
Liquid Connector 3/8 HB Valved In-Line Body - Red LP6C
0.38
1.185
2.73
In Line Hose Barb
Female
Red
LP6C-50-B-F-B
Liquid Connector 1/2 HB Valved In-Line Body - Blue LP6C
0.5
1.185
2.73
In Line Hose Barb
Female
Blue
LP6C-50-B-F-R
Liquid Connector 1/2 HB Valved In-Line Body - Red LP6C
0.5
1.185
2.73
In Line Hose Barb
Female
Red
LP6C-38-SAE-F-B Liquid Connector 3/8 SAE Valved In-Line Body - Blue LP6C
0.38
1.185
2.48
In Line Thread Port
SAE
Female
Blue
2.48
In Line Thread Port
SAE
Female
Red
2.5
In Line Thread Port
SAE
Female
Blue
Female
Red
LP6C-38-SAE-F-R Liquid Connector 3/8 SAE Valved In-Line Body - Red LP6C
LP6C-50-SAE-F-B Liquid Connector 1/2 SAE Valved In-Line Body - Blue LP6C
0.38
0.5
1.185
1.185
0.5
1.185
2.5
In Line Thread Port
SAE
Tubing/Thread
ID (inches)
Height
(Inches)
Length
(Inches)
Connector Type
Body Type
Color
LP6C-38-B-M-B Liquid Connector 3/8 HB Valved In-Line Insert - Blue LP6C
0.38
0.93
2.47
In Line Hose Barb
Male
Blue
LP6C-38-B-M-R Liquid Connector 3/8 HB Valved In-Line Insert - Red LP6C
0.38
0.93
2.47
In Line Hose Barb
Male
Red
LP6C-50-B-M-B Liquid Connector 1/2 HB Valved In-Line Insert - Blue LP6C
0.5
0.93
2.47
In Line Hose Barb
Male
Blue
LP6C-50-B-M-R Liquid Connector 1/2 HB Valved In-Line Insert - Red LP6C
0.5
0.93
2.47
In Line Hose Barb
Male
Red
LP6C-38-SAE-M-B Liquid Connector 3/8 SAE Valved In-Line Insert - Blue LP6C
0.38
1.025
2.3
In Line Thread Port SAE
Male
Blue
LP6C-38-SAE-M-R Liquid Connector 3/8 SAE Valved In-Line Insert - Red LP6C
0.38
1.025
2.3
Male
Red
LP6C-50-SAE-M-B Liquid Connector 1/2 SAE Valved In-Line Insert - Blue LP6C
0.5
1.025
2.3
Male
Blue
LP6C-50-SAE-M-R Liquid Connector 1/2 SAE Valved In-Line Insert - Red LP6C
0.5
1.025
2.3
Male
Red
LP6C-50-SAE-F-R Liquid Connector 1/2 SAE Valved In-Line Body - Red LP6C
Coupling Inserts- Chrome Plated Brass:
WKV Vette Part
Number
Description
Series
很抱歉,暂时无法提供与“LP6C-50-B-M-B”相匹配的价格&库存,您可以联系我们找货
