High Performance Compact Re-Circulating Liquid Chillers
HPLC Series
Wakefield-Vette’s High Performance HPLC Series Compact Liquid Chiller, with circulating fluid
temperature controller. CE marking and UL compliant with timer operations and alarming
codes on 7 segment / 4 digit 2 row display. The HRS chiller has both air cooled and water
cooled options available. Two power supplies are also available, 115VAC and 230 VAC single
phase.
Features:
Easy Maintenance, Tool-less Filter Replacement
Operating Functions: Timer, Low Tank Level, Power Failure
Self-Diagnosis with 31 Types of Alarm Codes
Serial Communications and Input/Outputs as Standard
Shaped for Easy Supply of Circulating Fluid
Dustproof Filter
Unfixed Caster for Useful Transportation
Environmental Compliance: RoHS Directive, R407C
Refrigerant
Power Failure Auto-Restart Function
Large Cooling Capacity
Applications:
Laser Machining
UV Curing Devices
X-Ray Instruments
Electron Microscopes
Atomizing Devices
Temperature Control of Paint Material
Packaging Lines
Cooling of Vacuum Pumps
HPLC-10
Cooling capacities: 1.3 kW-1.7 kW
Temperature range setting: 5 to 40°C
Temperature stability: ±0.1°C
Power supply requirement: single phase 100 VAC, 50/60Hz or 115 VAC, 60Hz
Standards: CE, UL, RoHS
Circulating fluid: Tap water or 15% ethylene glycol solution
HPLC-20
Cooling capacities: 1.4 kW-1.9 kW
Power supply requirement: single phase 200 to 230 VAC, 50/60Hz
HPLC-BP1
Bypass kit for use with HPLC-10 & HPLC-20 to maintain minimum flow
rate of 7 l/min to keep the system running properly.
www.wakefield-vette.com
HPLC Series
HPLC-10
Cooling Capacity
Heating Capacity
Pump Capacity
Required Facility Flow Rate
HPLC Series
HPLC-20
Cooling Capacity
Heating Capacity
Pump Capacity
HPLC Series
Dimensions HPLC-10/20
HPLC Series
HPLC-BP1
maintain minimum flow rate of 7 l/min to keep
HPLC Series
Manual HPLC-10/20
Mounting/Installation
Electrical Wiring
Piping
HPLC Series
Operational Display Panel HPLC-10/20
HPLC Series
Communication Function HPLC-10/20
很抱歉,暂时无法提供与“HPLC-BP1”相匹配的价格&库存,您可以联系我们找货
