RAPID-135-6
RAPID-135-6
    WAKEFIELD-VETTE
    INTEL/AMD CPU COOLER W/2 FANS
RAPID-135-6 数据手册
Heat Pipe Assembly RAPID CPU Cooler The Wakefield-Vette’s RAPID CPU cooler is a device designed to draw heat away from the system CPU and other components in an enclosure. Using a CPU cooler to lower CPU temperatures improves efficiency and stability of the system. This RAPID CPU cooler consist of a heat sink, numerous heat pipes and one or multiple fans. These cooling systems are generally referred to as air cooling and are often used in conjunction with systems that are designed to improve airflow. Features & Benefits: • Optimized fins to provide strong thermal performance at varying operating fan speeds • Mounting solution compatible with Intel® & AMD sockets • Direct contact heat pipes at base to ensure optimal thermal performance • Includes quick snap fan connection feature WKV Part Number Description RAPID-100-2 2 Heat Pipe CPU Cooler w/ LED light fan RAPID-135-6 6 Heat Pipe Premium CPU Cooler with two LED light fans RAPID-100-2 RAPID-130-6 Fan Size 92 x 92 x 25mm 92 x 92 x 25mm Power Interface Fan Voltage Fan Speed CPU Wattage Dimensions Weight (grams) (V) (rpm +/-10%) (Watts) 3 Pin 12 2000 3 Pin 12 2000 77 x 92 x 130mm 120 x 117 x 135 Thermal Resistance (C/W) 398 100 .22 735 135 .15
RAPID-135-6 价格&库存
很抱歉,暂时无法提供与“RAPID-135-6”相匹配的价格&库存,您可以联系我们找货
