KFPDV1607K10T
KFPDV1607K10T
    WALSIN(台湾华科)
    RF 功率分配器/分线器 3.3 GHz ~ 5 GHz 隔离(最小)18dB,1.8 VSWR(最大) 0603(1608 公制),8 PC 板
KFPDV1607K10T 数据手册
Approval sheet RFPDV Series – 1608(0603)-RoHS Compliance LTCC Multi Layer Chip 2-WAY POWER DIVIDER Halogens Free Product 3300 ~ 5000 MHz Working Frequency P/N: KFPDV1607K10T *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_KFPDV1607K10T_V01 Apr. 2020 Approval sheet FEATURES 1. 2. 3. 4. 3 Miniature footprint: 1.6 X 0.8 X 0.7 mm . Low Insertion loss High Isolation LTCC process APPLICATIONS 1. 3300 ~ 5000 MHz Working Frequency. CONSTRUCTION Top view P3 P2 P1 P4 P8 P5 P7 P6 PIN Connection PIN Connection 1 GND 5 FER1 2 IN 6 GND 3 GND 7 FER2 4 OUT1 8 OUT2 *100Ω external resister is required between FER1 and FER2 DIMENSIONS Figure Top View Page 2 of 7 Bottom View Side View ASC_KFPDV1607K10T_V01 Symbol Dimension (mm) L 1.60 ± 0.10 W 0.80 ± 0.10 T 0.70 max. A 0.20 ± 0.15 B 0.20 ± 0.10 C 0.30 ± 0.10 D 0.50 ± 0.05 E 0.20 ± 0.10 F 0.15 ± 0.10 G 0.15 ± 0.10 Apr. 2020 Approval sheet ELECTRICAL CHARACTERISTICS KFPDV1607K10T Specification Frequency range 3300 ~ 5000 MHz Insertion Loss 1.0 dB max. Phase Balance 4∘max. Amplitude Balance 0.4 dB max. Isolation 18 dB min. Input VSWR 1.5 max. Output VSWR 1.8 max. Impedance 50  Power capacity 1 W max. Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Operating & Storage Condition (Component) Operating Temperature Range: -40 ~ +85℃ Storage Temperature Range : -40 ~ +85℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40℃ Humidity: 30 to 70% relative humidity Typical Electrical Chart LAND PATTERN Figure Unit: mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 3 of 7 ASC_KFPDV1607K10T_V01 Apr. 2020 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Resistance to soldering Solder:Sn3Ag0.5Cu for lead-free *Preheating temperature:120~150C, heat JIS C 0050-5.4 No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under *Immersion time:101 sec the operational temperature range within -40 Solder:Sn3Ag0.5Cu for lead-free ~ 85°C. Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 Customer’s specification. *Height:75 cm No mechanical damage. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 *Pressurizing force: 5N (LGA terminal series);5N(≦0603); No remarkable damage or removal of the termination. 10N(>0603) *Test time:10±1 sec Bending test JIS C 0051- 7.4.1 The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 shall be maintained for 51 sec. ~ 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 4 of 7 ASC_KFPDV1607K10T_V01 Apr. 2020 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 5 of 7 ASC_KFPDV1607K10T_V01 Apr. 2020 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE KF PDV 1607 K 10 T Walsin Product Code Dimension code Application Specification Packing RF device PDV : Per 2 digits of Length, Width K :3300 ~ 5000 MHz Design Code T : Reeled Power Divider e.g.: 1607 = Length 1.6 mm, Thickness 0.7 mm Minimum Ordering Quantity: 4000 pcs per reel. PACKAGING Paper Tape specifications (unit: mm) Index Ao Bo D T W Dimension (mm) 0.975  0.10 1.76  0.10 1.55  0.05 0.75  0.10 8.00  0.10 Index E F Po P1 P2 Dimension (mm) 1.75  0.10 3.50  0.05 4.00  0.10 4.00  0.10 2.00  0.05 Page 6 of 7 ASC_KFPDV1607K10T_V01 Apr. 2020 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity:4000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_KFPDV1607K10T_V01 Apr. 2020
KFPDV1607K10T 价格&库存
很抱歉,暂时无法提供与“KFPDV1607K10T”相匹配的价格&库存,您可以联系我们找货
