RFHCM1012GD900B05T
RFHCM1012GD900B05T
    WALSIN(台湾华科)
    2 线路共模扼流圈 表面贴装型 90 Ohms @ 100 MHz 100mA DCR 3 欧姆
RFHCM1012GD900B05T 数据手册
Approval sheet RFHCM Series – 1012(0405)- RoHS Compliance MULTILAYER CERAMIC COMMON MODE FILTER Halogens Free Product P/N: RFHCM1012GD900B05T *Contents in this sheet are subject to change without prior notice. Page 1 of 6 ASC_RFHCM1012GD900B05T_V01 Apr. 2019 Approval sheet FEATURES and Application 1. Powerful components with composite co-fired material to solve EMI problem for high speed differential signal transmission line as USB, and LVDS, without distortion to high speed signal transmission. 2. MIPI, MHL serial interface in mobile device. CONSTRUCTION DIMENSIONS Figure Page 2 of 6 Symbol Dimension (mm) L 1.25 ± 0.10 W 1.00 ± 0.10 T 0.50 ± 0.10 P 0.55 ± 0.10 C1 0.30 ± 0.10 C2 0.20 ± 0.15 ASC_RFHCM1012GD900B05T_V01 Apr. 2019 Approval sheet ELECTRICAL CHARACTERISTICS RFHCM1012GD900B05T Specification Common Mode Impedance 90  ± 25% @ 100MHz DC Resistance 3.0  max. Rated Current 100 mA max. Rated Voltage 10 V Insulation Resistance 100 M min.  Agilent E4991A RF IMPEDANCE / MATERIAL ANALYZER  HP4338 MILLIOHMMETER  Agilent E5071C ENA SERIES NETWORK ANALYZER  Keithley 2410 1100V SOURCE METER Test Instruments Operating & Storage Condition (Component) Operation Temperature Range: -40 ~ +85 ℃ Storage Temperature Range: -40 ~ +85 ℃ Storage Condition before Soldering (Included packaging material) Storage Temperature Range: +5 ~ +40 ℃ Humidity: 30 to 70% relative humidity Typical Transmission Chart Impedance vs Frequency Characteristic: Insertion Loss vs Frequency Characteristic: 0 1000 Common Mode Insertion loss (dB) Impedance (ohm) Differential Mode 100 Differential Mode 10 -5 -10 -15 -20 Common Mode 1 -25 10 100 1,000 10,000 10 100 1,000 10,000 Frequency (MHz) Frequency (MHz) LAND PATTERN Figure Page 3 of 6 ASC_RFHCM1012GD900B05T_V01 Apr. 2019 Approval sheet RELIABILITY TEST Test item Test condition Criteria Temperature Cycle A. Temperature : -40 ~ +85℃ B. Cycle : 100 cycles A. No mechanical damage C. Dwell time : 30minutes B.Impedance value should be within ± 20 Measurement : at ambient temperature 24 hrs % of the initial value after test completion Operational Life A. Temperature : 85℃ ± 5℃ B. Test time : 1000 hrs A. No mechanical damage C. Apply current : full rated current B.Impedance value should be within ± 20 Measurement : at ambient temperature 24 hrs % of the initial value after test completion Biased Humidity A. Temperature : 40 ± 2℃ B. Humidity : 90 ~ 95 % RH A. No mechanical damage C. Test time : 1000 hrs B. Impedance value should be within ± D. Apply current : full rated current 20 % of the initial value Measurement : at ambient temperature 24 hrs after test completion Resistance to Solder Heat A. Solder temperature : 260 ± 5℃ B. Flux : Rosin C. DIP time : 10 ± 1 sec A. More than 95 % of terminal electrode should be covered with new solder B. No mechanical damage C.Impedance value should be within ± 20 % of the initial value Steam Aging Test A. Temperature : 93 ± 2℃ B. Test time : 4 hrs C. Solder temperature : 235 ± 5℃ D. Flux : Rosin E. DIP time : 5 ± 1 sec More than 95 % of terminal electrode should be covered with new solder Page 4 of 6 ASC_RFHCM1012GD900B05T_V01 Apr. 2019 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF HCM Walsin Product Code RF device HCM : Common Mode Filter 1012 Dimension code (L*W) 05 G D 900 B Material Code Product identification number Impedance Value Internal Code 1012 = Width 10, Ex: 900=90 ohm Dimension Code (T) T Packing T: Reeled 05=0.50mm Length 12, Minimum Ordering Quantity: 4000 pcs per reel. PACKAGING Type : Paper Carrier Unit : mm Page 5 of 6 Symbol Size Symbol Size A 1.20±0.05 Po 4.00±0.10 B 1.45±0.05 P1 4.00±0.10 W 8.00±0.10 P2 2.00±0.05 E 1.75±0.05 Do 1.55±0.05 F 3.50±0.05 T 0.60±0.03 ASC_RFHCM1012GD900B05T_V01 Apr. 2019 Approval sheet Reel dimensions C Index Dimension (mm) A Φ178.0 B Φ60.0 A B C Φ13.0 Taping Quantity:4000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection. (2) Storage environment condition.        Page 6 of 6 Products should be storage in the warehouse on the following conditions. Temperature : +5 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFHCM1012GD900B05T_V01 Apr. 2019
RFHCM1012GD900B05T 价格&库存
很抱歉,暂时无法提供与“RFHCM1012GD900B05T”相匹配的价格&库存,您可以联系我们找货
