20160148
    WATTEROTT
    HDC1080 - 湿度,温度 评估板 - 传感器
20160148 数据手册
    HDC1080-Breakout (Humidity and Temperature Sensor) Item number: 20160148 The HDC1080 is a digital humidity and temperature sensor with a I2C interface. You can use the sensor on 3,3V and 5V system with a low current from 1.3 µA @ 1sps, (11 bit RH and Temperature Measurement). Category: Environment The HDC1080 is a digital humidity and temperature sensor with a I2C interface. You can use the sensor on 3,3V and 5V system with a low current from 1.3 µA @ 1sps, (11 bit RH and Temperature Measurement). Features: Relative Humidity (RH) Operating Range 0% to 100% 14 Bit Measurement Resolution Relative Humidity Accuracy ±2% Temperature Accuracy ±0.2°C 100nA Sleep Mode Current Supply Voltage 2,7 V to 5.5 V I2C Interface                                   https://shop.watterott.com/HDC1080‐Breakout‐Humidity‐and‐Temperature‐Sensor/4‐18‐19
20160148 价格&库存
很抱歉,暂时无法提供与“20160148”相匹配的价格&库存,您可以联系我们找货
