120-M-221/10
120-M-221/10
    WECO(威克德诺)
    10 针位端子块 接头,公引脚,带罩(4 面) 0.197"(5.00mm) 垂直 通孔
120-M-221/10 数据手册
TECHNICAL DATA SHEET 120-M-121/-221 Pin strip Plug-in direction vertical to PCB GENERAL INFORMATION Pitch No. of poles Usable with Additonal Information 120-M-121 5 mm 2 - 12 all plug connectors of series 120 Ordering information: ..-M-121: without side wall, not pottable ..-M-221: with side wall, pottable TECHNICAL DATA Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Hole in PCB III 3 250 V 4 kV III 2 320 V 4 kV II 2 630 V 4 kV APPROVALS Voltage [V] Group 15 10 300 300 B D 15 10 300 300 B D, E MATERIAL Moulding Comparative Tracking Index Insulating Group Temperature Range Solder pin 250 V acc. to EN 60998-1 12 A ø 1,4 mm Current [A] 120-M-221 AWG [Nm] PA, grey, V-0 CTI ≥ 600 I -40°C up to 100°C 1,0 x 1,0 mm; tin plated brass OPTIONS / ACCESSORIES • • • • • • • • • Consecutive numbering Special marking according to drawing Self-adhesive marking strip BST-5,00 Pitch of 10 mm for larger clearance and creepage distances Other solder pin lengths on request Coding elements 120-K Connectors equipped with coding elements on request Pin strips with fastening flanges, see 120-M-227 Pin strips with connecting flanges, see 120-M-225 CONFIGURATIONS Poles Item 2 3 4 5 6 7 8 9 10 11 12 120-M-121/02 120-M-121/03 120-M-121/04 120-M-121/05 120-M-121/06 120-M-121/07 120-M-121/08 120-M-121/09 120-M-121/10 120-M-121/11 120-M-121/12 Article number Item Article number 20.806.002 20.806.003 20.806.004 20.806.005 20.806.006 20.806.007 20.806.008 20.806.009 20.806.010 20.806.011 20.806.012 120-M-221/02 120-M-221/03 120-M-221/04 120-M-221/05 120-M-221/06 120-M-221/07 120-M-221/08 120-M-221/09 120-M-221/10 120-M-221/11 120-M-221/12 20.806.026 20.806.027 20.806.028 20.806.029 20.806.030 20.806.031 20.806.032 20.806.033 20.806.034 20.806.035 20.806.036 Length (L) 10,00 mm 15,00 mm 20,00 mm 25,00 mm 30,00 mm 35,00 mm 40,00 mm 45,00 mm 50,00 mm 55,00 mm 60,00 mm Packaging PU Box Box Box Box Box Box Box Box Box Box Box 200 200 100 100 100 50 50 50 50 50 50 further number of poles on request 10.20 A3.22
120-M-221/10 价格&库存
很抱歉,暂时无法提供与“120-M-221/10”相匹配的价格&库存,您可以联系我们找货
