TECHNICAL DATA SHEET
120-M-121/-221
Pin strip
Plug-in direction vertical to PCB
GENERAL INFORMATION
Pitch
No. of poles
Usable with
Additonal Information
120-M-121
5 mm
2 - 12
all plug connectors of series 120
Ordering information:
..-M-121: without side wall, not pottable
..-M-221: with side wall, pottable
TECHNICAL DATA
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
Rated Insulation Voltage
Rated Current
Hole in PCB
III
3
250 V
4 kV
III
2
320 V
4 kV
II
2
630 V
4 kV
APPROVALS
Voltage [V]
Group
15
10
300
300
B
D
15
10
300
300
B
D, E
MATERIAL
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
Solder pin
250 V acc. to EN 60998-1
12 A
ø 1,4 mm
Current [A]
120-M-221
AWG
[Nm]
PA, grey, V-0
CTI ≥ 600
I
-40°C up to 100°C
1,0 x 1,0 mm; tin plated brass
OPTIONS / ACCESSORIES
Consecutive numbering
Special marking according to drawing
Self-adhesive marking strip BST-5,00
Pitch of 10 mm for larger clearance and creepage distances
Other solder pin lengths on request
Coding elements 120-K
Connectors equipped with coding elements on request
Pin strips with fastening flanges, see 120-M-227
Pin strips with connecting flanges, see 120-M-225
CONFIGURATIONS
Poles Item
2
3
4
5
6
7
8
9
10
11
12
120-M-121/02
120-M-121/03
120-M-121/04
120-M-121/05
120-M-121/06
120-M-121/07
120-M-121/08
120-M-121/09
120-M-121/10
120-M-121/11
120-M-121/12
Article number
Item
Article number
20.806.002
20.806.003
20.806.004
20.806.005
20.806.006
20.806.007
20.806.008
20.806.009
20.806.010
20.806.011
20.806.012
120-M-221/02
120-M-221/03
120-M-221/04
120-M-221/05
120-M-221/06
120-M-221/07
120-M-221/08
120-M-221/09
120-M-221/10
120-M-221/11
120-M-221/12
20.806.026
20.806.027
20.806.028
20.806.029
20.806.030
20.806.031
20.806.032
20.806.033
20.806.034
20.806.035
20.806.036
Length (L)
10,00 mm
15,00 mm
20,00 mm
25,00 mm
30,00 mm
35,00 mm
40,00 mm
45,00 mm
50,00 mm
55,00 mm
60,00 mm
Packaging
PU
Box
Box
Box
Box
Box
Box
Box
Box
Box
Box
Box
200
200
100
100
100
50
50
50
50
50
50
further number of poles on request
10.20
A3.22
很抱歉,暂时无法提供与“120-M-221/05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+4.95084250+0.60051
- 500+4.92771500+0.59771
- 1000+4.927601000+0.59770
- 1250+4.927491250+0.59768
- 3750+4.927383750+0.59767
- 国内价格 香港价格
- 15+6.0760315+0.73699
- 40+6.0476440+0.73355
- 150+6.04751150+0.73353
- 400+6.04737400+0.73352
- 1500+6.047241500+0.73350
