TECHNICAL DATA SHEET
121-M-111/-211
Pin strip
Plug-in direction parallel to PCB
GENERAL INFORMATION
Pitch
No. of poles
Usable with
Additonal Information
121-M-111
5,08 mm
2 - 12
all plug connectors of series 121
Ordering information:
..-M-111: without side walls
..-M-211: with side walls
TECHNICAL DATA
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
Rated Insulation Voltage
Rated Current
Hole in PCB
121-M-211
III
3
250 V
4 kV
III
2
320 V
4 kV
II
2
630 V
4 kV
250 V acc. to EN 60998-1
12 A
ø 1,4 mm
APPROVALS
MATERIAL
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
Solder pin
PA, grey, V-0
CTI 600
I
-40°C up to 100°C
1,0 x 1,0 mm; tin plated brass
OPTIONS / ACCESSORIES
Current [A]
Voltage [V]
Group
15
10
300
300
B
D
15
10
300
300
B
D, E
AWG
[Nm]
Consecutive numbering
Special marking according to drawing
Self-adhesive marking strip BST-5,08
Pitch of 10,16 mm for larger clearance and creepage distances
Other solder pin lengths on request
Coding elements 120-K
Connectors equipped with coding elements on request
CONFIGURATIONS
Poles Item
2
3
4
5
6
7
8
9
10
11
12
121-M-111/02
121-M-111/03
121-M-111/04
121-M-111/05
121-M-111/06
121-M-111/07
121-M-111/08
121-M-111/09
121-M-111/10
121-M-111/11
121-M-111/12
Article number
Item
Article number
10.806.102
10.806.103
10.806.104
10.806.105
10.806.106
10.806.107
10.806.108
10.806.109
10.806.110
10.806.111
10.806.112
121-M-211/02
121-M-211/03
121-M-211/04
121-M-211/05
121-M-211/06
121-M-211/07
121-M-211/08
121-M-211/09
121-M-211/10
121-M-211/11
121-M-211/12
10.806.126
10.806.127
10.806.128
10.806.129
10.806.130
10.806.131
10.806.132
10.806.133
10.806.134
10.806.135
10.806.136
Length (L)
10,16 mm
15,24 mm
20,32 mm
25,40 mm
30,48 mm
35,56 mm
40,64 mm
45,72 mm
50,80 mm
55,88 mm
60,96 mm
Packaging
PU
Box
Box
Box
Box
Box
Box
Box
Box
Box
Box
Box
200
200
100
100
100
50
50
50
50
50
50
further number of poles on request
02.21
A3.24
很抱歉,暂时无法提供与“121-M-211/04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+4.36544250+0.52954
- 750+4.34505750+0.52707
- 1000+4.344951000+0.52706
- 2500+4.344852500+0.52705
- 3750+4.344763750+0.52704
