TECHNICAL DATA SHEET
121-M-121/-221
Pin strip
Plug-in direction vertical to PCB
GENERAL INFORMATION
Pitch
No. of poles
Usable with
Additonal Information
5,08 mm
2 - 12
all plug connectors of series 121
Ordering information:
..-M-121: without side walls
..-M-221: with side walls
121-M-121
TECHNICAL DATA
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
Rated Insulation Voltage
Rated Current
Hole in PCB
III
3
250 V
4 kV
III
2
320 V
4 kV
II
2
630 V
4 kV
121-M-221
250 V acc. to EN 60998-1
12 A
ø 1,4 mm
MATERIAL
APPROVALS
Current [A]
Voltage [V]
Group
15
10
300
300
B
D
15
10
300
300
B
D, E
AWG
[Nm]
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
Solder pin
PA, grey, V-0
CTI ≥ 600
I
-40°C up to 100°C
1,0 x 1,0 mm; tin plated brass
OPTIONS / ACCESSORIES
Consecutive numbering
Special marking according to drawing
Self-adhesive marking strip BST-5,08
Pitch of 10,16 mm for larger clearance and creepage distances
Other solder pin lengths on request
Coding elements 120-K
Connectors equipped with coding elements on request
CONFIGURATIONS
Poles Item
2
3
4
5
6
7
8
9
10
11
12
121-M-121/02
121-M-121/03
121-M-121/04
121-M-121/05
121-M-121/06
121-M-121/07
121-M-121/08
121-M-121/09
121-M-121/10
121-M-121/11
121-M-121/12
Article number
Item
Article number
20.806.102
20.806.103
20.806.104
20.806.105
20.806.106
20.806.107
20.806.108
20.806.109
20.806.110
20.806.111
20.806.112
121-M-221/02
121-M-221/03
121-M-221/04
121-M-221/05
121-M-221/06
121-M-221/07
121-M-221/08
121-M-221/09
121-M-221/10
121-M-221/11
121-M-221/12
20.806.126
20.806.127
20.806.128
20.806.129
20.806.130
20.806.131
20.806.132
20.806.133
20.806.134
20.806.135
20.806.136
Length (L)
10,16 mm
15,24 mm
20,32 mm
25,40 mm
30,48 mm
35,56 mm
40,64 mm
45,72 mm
50,80 mm
55,88 mm
60,96 mm
Packaging
PU
Box
Box
Box
Box
Box
Box
Box
Box
Box
Box
Box
200
200
100
100
100
50
50
50
50
50
50
further number of poles on request
05.20
很抱歉,暂时无法提供与“121-M-221/05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.21000
- 10+5.15160
- 30+4.62240
- 100+4.09320
- 国内价格 香港价格
- 100+5.49093100+0.66602
- 300+5.46527300+0.66291
- 500+5.46515500+0.66290
- 2000+5.465042000+0.66288
- 3000+5.464913000+0.66287
