210-A-126-SMD/02
210-A-126-SMD/02
    WECO(威克德诺)
    2 接线板 - 线至板 垂直,带板 0.138"(3.50mm) 表面贴装型
210-A-126-SMD/02 数据手册
TECHNICAL DATA SHEET 210-A-126-SMD PCB connector for SMD Screw connection, with solder flanges GENERAL INFORMATION Pitch No. of poles 3,5 mm 2 - 12 TECHNICAL DATA Clamping Range Rated Cross Section Wire Stripping Length Overvoltage Category Pollution Severity Level Rated Voltage Rated Impulse Voltage Rated Insulation Voltage Rated Current Soldering process Torque solid / stranded / AWG 0,14 - 1,5 mm² / 0,14 - 1,5 mm² / 30 - 16 AWG 1 mm² 5,5 mm ± 0,5 mm III 3 160 V 2,5 kV III 2 160 V 2,5 kV L = No. of poles x pitch PCB LAYOUT II 2 320 V 2,5 kV 130 V acc. to EN 60998-1 12,5 A Reflow solder 0,2 Nm Solder paste thickness: 0,2 mm MATERIAL APPROVALS Current [A] Voltage [V] Group AWG [Nm] 10 300 B 30 - 16 0,23 10 300 B 30 - 16 0,22 Moulding Comparative Tracking Index Insulating Group Temperature Range Terminal body Pressure clamp Screw Solder pin Solder cylinder PA HT, black, V-0 CTI ≥ 600 I -40°C up to 120°C; reflow solder temperature peak max. 255°C acc. to DIN EN 61760-1 Nickel plated brass Copper alloy, tin plated M2; copper alloy, tin plated Copper alloy, tin plated Tin plated brass OPTIONS / ACCESSORIES • Self-adhesive marking strip BST-3,50 [1] • White housing colour on request [1] To be fitted after reflow soldering process CONFIGURATIONS Poles Part number 2 3 4 6 2 3 4 5 6 210-A-126-SMD/02 210-A-126-SMD/03 210-A-126-SMD/04 210-A-126-SMD/06 210-A-126-SMD/02-T&R 210-A-126-SMD/03-T&R 210-A-126-SMD/04-T&R 210-A-126-SMD/05-T&R 210-A-126-SMD/06-T&R Article number 20.804.232 20.804.233 20.804.234 20.804.236 20.804.232.A00 20.804.233.A00 20.804.234.A00 20.804.235.A00 20.804.236.A00 Length (L) 14,00 mm 17,50 mm 21,00 mm 28,00 mm 14,00 mm 17,50 mm 21,00 mm 24,50 mm 28,00 mm Packaging PU Box Box Box Box Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel Tape-on-Reel 888 696 576 432 375 325 325 325 325 Tape Width Tape Height 32 mm 44 mm 44 mm 44 mm 44 mm 12,0 mm 14,6 mm 14,6 mm 14,6 mm 14,6 mm further number of poles on request 11.17 WECO Electrical Connectors Inc., 18050 Trans-Canada Highway, Kirkland, Québec, Canada, H9J 4A1 Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956 weco@wecoconnectors.com © Copyright by WECO All rights reserved. WECO® is a brand of the WECO Group. Information provided in this document may be changed without prior notice. Please refer to our website for the full disclaimer.
210-A-126-SMD/02 价格&库存
很抱歉,暂时无法提供与“210-A-126-SMD/02”相匹配的价格&库存,您可以联系我们找货
