TECHNICAL DATA SHEET
950-D-SMD-DS
PCB connector for SMD
Screw connection
GENERAL INFORMATION
Pitch
No. of poles
5 mm
2 - 12
PCB LAYOUT
TECHNICAL DATA
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
Rated Insulation Voltage
Rated Current
Soldering process
Torque
III
3
160 V
2,5 kV
III
2
160 V
2,5 kV
II
2
320 V
2,5 kV
130 V acc. to EN 60998-1
17,5 A
Reflow solder
0,4 Nm
5
solid / stranded / AWG
0,34 - 2,5 mm² / 0,34 - 2,5 mm² / 22 - 14 AWG
1,5 mm²
6 mm ± 0,5 mm
5
2,5
L1
Current [A]
Voltage [V]
Group
AWG
[Nm]
15
300
B
26 - 14
0,4
15
300
B
26 - 14
0,4
L1 = (No. of poles - 1) x
pitch
Solder paste thickness:
0,15 - 0,2 mm
MATERIAL
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
Terminal body
Screw
Wire protector
APPROVALS
0,75
Clamping Range
with wire protector
Rated Cross Section
Wire Stripping Length
PA HT, black, V-0
CTI ≥ 600
I
-40°C up to 120°C; reflow solder temperature peak
max. 255°C acc. to DIN EN 61760-1
Tin plated brass
M2,6; zinc plated steel, blue passivated
Tin plated tin bronze
OPTIONS / ACCESSORIES
Consecutive numbering
Special marking according to drawing
Self-adhesive marking strip BST-5,00 [1]
Special packaging on request: Tray - Bar magazine
[1] To be fitted after reflow soldering process
CONFIGURATIONS
Poles Part number
2
3
4
5
6
2
3
4
5
6
950-D-SMD-DS/02
950-D-SMD-DS/03
950-D-SMD-DS/04
950-D-SMD-DS/05
950-D-SMD-DS/06
950-D-SMD-DS/02-T&R
950-D-SMD-DS/03-T&R
950-D-SMD-DS/04-T&R
950-D-SMD-DS/05-T&R
950-D-SMD-DS/06-T&R
Article number
20.879.502
20.879.503
20.879.504
20.879.505
20.879.506
20.879.502.A00
20.879.503.A00
20.879.504.A00
20.879.505.A00
20.879.506.A00
Length (L)
10,00 mm
15,00 mm
20,00 mm
25,00 mm
30,00 mm
10,00 mm
15,00 mm
20,00 mm
25,00 mm
30,00 mm
Packaging
PU
Box
Box
Box
Box
Box
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
250
250
100
100
100
500
500
500
500
500
Tape
Width
Tape
Height
32 mm
44 mm
44 mm
44 mm
56 mm
12,3 mm
12,0 mm
12,0 mm
12,0 mm
12,0 mm
01.18
WECO Electrical Connectors Inc., 18050 Trans-Canada Highway,
Kirkland, Québec, Canada, H9J 4A1
Phone: 800.724.2928 | Phone: 514.694.9136 | Fax: 514.694.0956
weco@wecoconnectors.com
© Copyright by WECO
All rights reserved. WECO® is a brand of the WECO Group.
Information provided in this document may be changed without prior notice.
Please refer to our website for the full disclaimer.
很抱歉,暂时无法提供与“950-D-SMD-DS/03”相匹配的价格&库存,您可以联系我们找货
