TECHNICAL DATA SHEET
974-D-SMD-DS
PCB connector for SMD
Screw connection 45°-angle to PCB
GENERAL INFORMATION
Pitch
No. of poles
5 mm
2-6
L = pole length x pitch +
1,5 mm
TECHNICAL DATA
Clamping Range
Rated Cross Section
Wire Stripping Length
Overvoltage Category
Pollution Severity Level
Rated Voltage
Rated Impulse Voltage
Rated Insulation Voltage
Rated Current
Torque
solid / stranded / AWG
0,75 - 4 mm² / 0,75 - 2,5 mm² / 18 - 12 AWG
2,5 mm²
6 mm ± 0,5 mm
III
3
250 V
4 kV
III
2
320 V
4 kV
II
2
630 V
4 kV
250 V acc. to EN 60998-1
24 A
0,4 Nm
PCB LAYOUT
Solder paste thickness:
0,2 - 0,25 mm
MATERIAL
Moulding
Comparative Tracking Index
Insulating Group
Temperature Range
APPROVALS
Current [A]
Voltage [V]
Group
AWG
[Nm]
300
300
B
D
18 - 12
18 - 12
0,4
0,4
300
300
B
D
18 - 12
18 - 12
0,4
0,4
Terminal body
Screw
Wire protector
PA HT, black, V-0
CTI ≥ 600
I
-40°C up to 120°C; reflow solder temperature
peak max. 255°C acc. to DIN EN 61760-1
Tin plated brass
M3; zink plated steel, clear passivated
Tin plated tin bronze
OPTIONS / ACCESSORIES
• Consecutive numbering
• Special marking according to drawing
• Self-adhesive marking strip BST-5,00 [1]
[1] To be fitted after reflow soldering process
CONFIGURATIONS
Poles Item
2
3
4
5
6
2
3
4
5
6
974-D-SMD-DS/02
974-D-SMD-DS/03
974-D-SMD-DS/04
974-D-SMD-DS/05
974-D-SMD-DS/06
974-D-SMD-DS/02-T&R
974-D-SMD-DS/03-T&R
974-D-SMD-DS/04-T&R
974-D-SMD-DS/05-T&R
974-D-SMD-DS/06-T&R
Article number
20.874.402
20.874.403
20.874.404
20.874.405
20.874.406
20.874.402.A00
20.874.403.A00
20.874.404.A00
20.874.405.A00
20.874.406.A00
Length (L)
11,5 mm
16,5 mm
21,5 mm
26,5 mm
31,5 mm
11,5 mm
16,5 mm
21,5 mm
26,5 mm
31,5 mm
Packaging
PU
Box
Box
Box
Box
Box
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
Tape-on-Reel
250
250
200
100
100
250
250
250
250
250
Tape
Width
Tape
Height
56 mm
56 mm
56 mm
56 mm
56 mm
14,7 mm
14,7 mm
14,7 mm
14,7 mm
14,7 mm
further number of poles on request
01.20
很抱歉,暂时无法提供与“974-D-SMD-DS/04”相匹配的价格&库存,您可以联系我们找货
