osh:wizfi310_shield:start [Document Wiki]
Document Wiki
WizFi310 Shield
Overview
This document describes the contents of WizFi310 Shield. WizFi310 Shield is a Shield with built-in WizFi310 WiFi module of
WIZnet.
Because WizFi310 Shield is Pin Compatible with Arduino, it can be used in Arduino, and it can be used in Arduino Pin
Compatible development platform. It is also used on the WIZWiki Platform.
In addition, an temprature/humidity sensor and an CDS sensor are built in.
Features
WizFi310
Single band 2.4GHz IEEE 802.11b/g/n
72.2Mbps receive PHY rate and 72.2Mbps transmit PHY rate using 20MHz bandwidth
150Mbps receive PHY rate and 150Mbps transmit PHY rate using 40MHz bandwidth
Low power consumption & excellent power management performance extend battery life.
Easy for integration into mobile and handheld device with flexible system configuration.
Serial Interface : UART
UART Max Baud : 921600 bps
http://wizwiki.net/wiki/doku.php?id=osh:wizfi310_shield:start
5/3/2018
• Soft AP
• Enough memory retention
• Wi-Fi Security (WEP, WPA/WPA2PSK)
• L2 Switching
• OTA(Over The Air F/W Upgrading)
ETC
• Built-in UART to USB chip
• CP2104-GM
• Micro USB B Type Connector
• UART Selector
• J1, J2, J3
• 2.54mm Pin Header
• Built-in Sensors
• Temprature/Humidity sensor : DHT11
• CDS Sensor : GL5537
• Built-in Tact Switchs
• System Reset Switch: SW4
• WiFi Reset Switch: SW3
• WiFi Function Switch: SW2
• Built-in LED Indicators
• D13 LED
• WizFi310 MODE/WiFi LED
• WizFi310 RXD/TXD LED
• Built-in Level Shifters
• The voltage of the RXD/TXD signal changes according to the main board platform voltage.
• Built-in DIP Switchs
• UART RXD/TXD Selector : SW1
• Digital/Analog PIN Selector : SW5
• UART RTS/CTS Selector : SW6
WizFi310 Shield Callout & Pinmap
5/3/2018
H/W Configurations
DIP Switch Configurations
SW1 - RXD/TXD Selector DIP Switch
• ON : RXD/TXD of WizFi310 connect to USB
• It is possible to communicate with WizFi310 using USB.
• OFF : RXD/TXD of WizFi310 connect to J1 and J3
• UART Pin Header, Arduino PIN
• If the jumper cap is not attached to the UART pin header, it will not be connected to the arduino pin.
Pin 1 : RXD
Pin 2 : TXD
SW6 - RTS/CTS Selector DIP Switch
• ON : RTS/CTS of WizFi310 connect to D6 and D7
• OFF : RTS/CTS of WizFi310 not connect to anywhere
• If the state of SW5 is ON, D6 and D7 of UART jumper can not be used.
Pin 1 : RTS - D6
Pin 2 : CTS - D7
SW5 - Aruduino Pin Selector DIP Switch
• ON : Connect to Arduino Pin
• OFF : Not connect to anywhere
Pin 1 : A0 - CDS
Pin 2 : D14 - DHT11
Pin 3 : D9 - WizFi310 Reset Pin
5/3/2018
UART Selector Jumper
• It can be used when SW2 is OFF.
• You have to specify the desired Arduino pin, use Jumper Cap to connect J1 to J2, and J3 to J2.
• Default : J1(RXD) - D1, J3(TXD) - D0
J1 : RXD
J2 : D0 ~ D8
J3 : TXD
Getting Started
Technical Refernce
Datasheet
• WizFi310 Datasheet
Schematic
• WizFi310 Shield Schematic(Altium)
• WizFi310 Shield Schematic(PDF)
Partlist
• WizFi310 Shield Partlist
ETC
Serial Port Driver
• CP210x USB to UART Bridge VCP Drivers [http://www.silabs.com/products/development-tools/software/usb-to-uart-bridgevcp-drivers]
Sensor Datasheets
• DHT11 Humidity & Temperature Sensor Datasheet [http://www.micropik.com/PDF/dht11.pdf]
• GL5537 Datasheet [https://www.kth.se/social/files/54ef17dbf27654753f437c56/GL5537.pdf]
很抱歉,暂时无法提供与“WIZFI SHIELD”相匹配的价格&库存,您可以联系我们找货
