Quartz Crystal Specification
Part No.: LFXTAL009709
Description
3.2 x 1.5mm SMD crystal in a ceramic package with a seam
sealed metal lid, hermetically sealed.
Model
CFPX-217
Model Issue number
6
Frequency Parameters
Frequency
32.7680kHz
Frequency Tolerance
Tolerance Condition
Overtone Order
Ageing
±20.00ppm
@ 25°C ±5°C
Fundamental
±3ppm max in 1st year @ 25°C
Electrical Parameters
Load Capacitance (CL)
Shunt Capacitance (C0)
Drive Level
ESR
7.00pF
1.0pF typical
1.0µW max
70.00kΩ max
Outline (mm)
Environmental Parameters
Storage Temperature Range: –55 to 125°C
Drop: 100g dummy, 150cm drop (3 directions x 10 times) onto
concrete
Vibration: 1.5mm amplitude, 10Hz-60Hz with cycle time 2-3
minutes in 3 directions (X, Y and Z axis) each for 2 hours
*Measure after 2 hours left at room temperature
Manufacturing Details
RoHS Terminations
RoHS Reflow Temp
NiAu
260°C max for 10s max
Compliance
RoHS Status (2015/863/EU)
REACh Status
MSL Rating (JDEC-STD-033):
Recommended Solder Pad Layout
Compliant
Compliant
Not Applicable
Packaging Details
Tape & reel in accordance with EIA-481
Quantities below the standard reel size to
be supplied on cut tape.
Standard Quantity: 3,000 Pieces
Sales Office Contact Details:
UK: +44 (0)1460 270200
USA: +1.760 668 8935
Printed on 2 May 23 23:48 using Part Data Sheet V1.0021
Email: info@iqdfrequencyproducts.com
Web: www.iqdfrequencyproducts.com
Page 1 of 2
Typical Frequency Stability Characteristics
Page 2 of 2
很抱歉,暂时无法提供与“LFXTAL009709”相匹配的价格&库存,您可以联系我们找货
