LFXTAL084882
LFXTAL084882
    IQD
    SMD2
    32.768 kHz ±20ppm 晶体 12.5pF 2-SMD,无引线
LFXTAL084882 数据手册
Quartz Crystal Specification Part No.: LFXTAL084882 Description 3.2 x 1.5mm SMD crystal in a ceramic package with a seam sealed metal lid, hermetically sealed. Model IQXC-217 Model Issue number 2 Frequency Parameters Frequency 32.7680kHz Frequency Tolerance Tolerance Condition Overtone Order Ageing ±20.00ppm @ 25°C ±5°C Fundamental ±3ppm max in 1st year @ 25°C Electrical Parameters Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 12.50pF 1.5pF max Outline (mm) 0.1µW typ, 0.5µW max 70.00kΩ max Environmental Parameters Storage Temperature Range: –55 to 125°C Drop: 150g dummy, 180cm drop (6 directions x 3 times) onto concrete board Vibration: 1.5mm amplitude, 10Hz-60Hz with cycle time 2-3 minutes in 3 directions (X, Y and Z axis) each for 2 hours Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260°C max for 10s max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Recommended Solder Pad Layout Compliant Not Applicable Packaging Details Tape & reel in accordance with EIA-481 Quantities below the standard reel size to be supplied on cut tape. Standard Quantity: 3,000 Pieces Sales Office Contact Details: UK: +44 (0)1460 270200 USA: +1.760 668 8935 Printed on 2 May 23 23:49 using Part Data Sheet V1.0021 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Quartz Crystal Specification Part No.: LFXTAL084882 Typical Frequency Stability Characteristics Sales Office Contact Details: UK: +44 (0)1460 270200 USA: +1.760 668 8935 Printed on 2 May 23 23:49 using Part Data Sheet V1.0021 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFXTAL084882 价格&库存
很抱歉,暂时无法提供与“LFXTAL084882”相匹配的价格&库存,您可以联系我们找货
