FSSF004GSE-M100
FSSF004GSE-M100
    FLEXXON
    存储卡 4GB SLC
FSSF004GSE-M100 数据手册
Industrial CFast Specification (ACHIEVER SERIES, SLC) Version 1.5 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................. 1 1.1. Introduction........................................................................................................................ 1 1.2. Product Overview .............................................................................................................. 2 PRODUCT SPECIFICATIONS ........................................................................ 3 2.1. Performance ....................................................................................................................... 3 2.2. Power ................................................................................................................................. 3 2.3. TBW (Terabytes Written) .................................................................................................. 4 2.4. MTBF ................................................................................................................................ 4 2.5. Data Retention ................................................................................................................... 4 3. ENVIRONMENTAL SPECIFICATIONS........................................................... 5 4. ATA COMMANDS .......................................................................................... 6 5. PIN ASSIGNMENT ....................................................................................... 9 6. PHYSICAL DIMENSION ............................................................................. 10 7. ORDERING INFORMATION ....................................................................... 11 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s ACHIEVER CFast has SATA III interface, and is fully compliant with standard CFast Form Factor. It supports good performance, high reliability and low power management. It is suitable for heavy-loading or multi-tasking applications. Figure 1-1 ACHIEVER CFast Controller Block Diagram 1 1.2. Product Overview  Flash  SLC Capacity   4GB up to 32GB SATA Interface   Compliant with SATA Revision 3.1  Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface ECC Scheme   Up to 66 bits error in 1K Byte data  UART Function  GPIO  Support SMART and TRIM commands  Low Power Management  Internal data shaping technique increase data endurance  Global Wear Leveling Algorithm  Temperature Range  ■ Operation (Silver) : 0°C ~ 70°C ■ Operation (Diamond) : -40°C ~ 85°C ■ Storage: -55°C ~ 95°C RoHS Compliant 2 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of ACHIEVER CFast Capacity Sequential Read (MB/s) Write (MB/s) 4GB 42 38 8GB 85 77 16GB 168 150 32GB 175 160 NOTES: 1. The performance was measured using CrystalDiskMark with SATA 6Gbps host. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of ACHIEVER CFast Parameter Rating Operating Voltage 3.3V +/- 5% Table 2-3 Power Consumption of ACHIEVER CFast Parameter Power Consumption Idle (max.) 0.42 W Active (max.) 1.3 W NOTE: Power Consumption may differ according to flash configuration and platform. 3 2.3. TBW (Terabytes Written) Capacity TBW 4GB 120 8GB 240 16GB 481 32GB 962 NOTES: 1. TBW may differ according to flash configuration and platform. 2. Samples were tested under JESD218A endurance test method and JESD219A endurance workloads specification. 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s ACHIEVER CFast is more than 3 million hours. 2.5. Data Retention   10 years if > 90% life remaining (@25C) 1 year if < 10% life remaining (@25C) 4 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -55°C ~ 95°C Operating Temperature Silver Grade: 0°C ~ 70°C Diamond Grade: -40°C~ 85°C Storage Humidity Silver Grade: 40°C, 95% RH Diamond Grade: 55°C, 95% RH Operating Humidity Silver Grade: 40°C, 93% RH Diamond Grade: 55°C, 95% RH Shock 1000G, Half Sin Pulse Duration 0.5ms Vibration 80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min Drop 80cm free fall, 6 face of each unit, 2 times each Bending ≥ 20N, Hold 1 min/5 times ESD 24°C, 49% RH, +/-4KV 25 times, Air +/-8KV 10 times 5 4. ATA COMMANDS Table 4-1 Supported ATA Command Set # Command Code Protocol Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Initialize Drive Parameters 91h Non-data Read DMA C8h DMA Read Log Ext 2Fh PIO data-in Read Multiple C4h PIO data-in Read Sector(s) 20h PIO data-in General Feature Set 40h or Read Verify Sector(s) 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out Write Sector(s) 30h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Power Management Feature Set E5h or Check Power Mode 98h E3h or Idle 97h E1h or Idle Immediate 95h E6h or Sleep 99h E2h or Standby 96h E0h or Standby Immediate 94h 6 Non-data Non-data Non-data Non-data Non-data Non-data Security Mode Feature Set Security Set Password F1h PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Execute Off-Line Immediate B0h Non-data SMART Read Log B0h PIO data-in SMART Read Data B0h PIO data-in SMART Read Threshold B0h PIO data-in SMART Return Status B0h Non-data SMART Save Attribute Values B0h Non-data SMART Write Log B0h PIO data-in Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Flush Cache Ext EAh Non-data Read Sector(s) Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Read Native Max Address Ext 27h Non-data Read Verify Sector(s) Ext 42h Non-data Set Max Address Ext 37h Non-data Write DMA Ext 35h DMA Write Multiple Ext 39h PIO data-out Write Sector(s) Ext 34h PIO data-out 60h DMA Queued SMART Feature Set Host Protected Area Feature Set 48-bit Address Feature Set NCQ Feature Set Read FPDMA Queued 7 Write FPDMA Queued 61h DMA Queued Data Set Management 06h DMA Seek 70h Non-data Others 8 5. PIN ASSIGNMENT Figure 5-1 Pin Assignment of ACHIEVER CFast Table 5-1 Pin Assignment and Function PIN # Function PIN # Function PC1 Card Detect Input S1 Signal GND PC2 Device GND S2 SATA A+ PC3 DEVSLP (I) (O/3.3V) S3 SATA A- PC4 N/C S4 Signal GND PC5 N/C S5 SATA B+ PC6 N/C S6 SATA B- PC7 Device GND S7 Signal GND PC8 DASP (Default) PC9 DASP (Optional) PC10 W/P and Q/E Function (Optional) PC11 N/C PC12 GND PC13 3.3V PC14 3.3V PC15 Device GND PC16 Device GND PC17 Card Detect Input 9 6. PHYSICAL DIMENSION Dimension: 36.4 mm(L) x 41.86 mm(W) x 3.30 mm(H) 10 7. ORDERING INFORMATION Capacity MPN (Diamond Grade) MPN (Silver Grade) 4GB FSSF004GSE-M100 FSSF004GSS-M100 8GB FSSF008GSE-M100 FSSF008GSS-M100 16GB FSSF016GSE-M100 FSSF016GSS-M100 32GB FSSF032GSE-M100 FSSF032GSS-M100 11 Revision History Revision Date Description 1.0 2017/04 First release 1.1 2017/10 Update performance, power and TBW 1.2 2019/08 Update capacity 1.3 2019/08 Update part number 1.4 2020/03 Update capacity 1.5 2020/11 Update capacity 12
FSSF004GSE-M100 价格&库存
很抱歉,暂时无法提供与“FSSF004GSE-M100”相匹配的价格&库存,您可以联系我们找货
